Question about Singer 7462 Mechanical Sewing Machine
How do I reset the timing on my Singer 7440 Advance?
The timing on my Singer 7440 Advance keeps getting messed up. I have had it fixed a few times, is there a way I can do this myself?
    Scholar:
  • 69 Answers
If you have had this repaired several times, I am inclinded to believe that the shop is resetting the timing and after a little while it jumps time again. If this is correct, you probably have a gear that is defective. I have seen the gears where the nylon material did not set correctly and actually spins around on the metal. Since the nylon is intact, it does not appear broken and until the technician actually sees it spin, there is no way to know it is defective. You could take it back and ask the tech to check for that.
Posted on Mar 01, 2009
Please share the symptoms of a messed up timing on a Singer Confidence sewing machine. Thank you in advance
A timing issue is usually demonstrated by the needle thread failing to pick up the bobbin thread. First, try installing a brand new needle as a bent/damaged needle will sometimes also fail to pick up the bobbin thread. You can search the internet for sewing machine timing or take it for service.
Dec 07, 2016 | Singer Sewing Machines
Can I replace the plate needle on the singer profinish serger myself
Laura's Blog: Do it yourself serger repair - How to adjust ...
bangerlm.blogspot.com/2007/.../do-it-yourself-serger-repair-how-to.htm...
Jan 30, 2007 - So I recently did something awful to my serger and the needle broke, the ... Plus it isn't really generic, it is basically some notes for some various olderSinger sergers. ... There were two screws on the bottom plate, plus 4 screws in each of ... If you thread the machine and you can't get the lower looper thread ...
How to fix timing on serger - YouTube
? 4:36
https://www.youtube.com/watch?v=BT6kiYyG2bw
Jul 21, 2013 - Uploaded by Jasmine Harris
Up and close detailed view of how to fix timing on your sergermachine ... looper and lower looper should be when the needle is up or down. .... way I can ever take it into the shop, so unless Ican fix it myself I'm out of luck. .... How to fix the upper looper timing on a Singer serger/overlocker - Duration: 11:02.
[PDF]Singer 14CG754 Serger Commercial Grade Manual.
www.sewingmachinesplus.com/media/.../singer/.../Manual_14CG754.pdf
Jan 10, 2016 | Singer Sewing Machines
Singer 5625 timing is off.
I had problems with my timing one time and had to put it
in the shop - I learned to be careful what you touch.
Mar 29, 2014 | Singer Sewing Machines
Singer advance 7422 bobbin jumps
Did you get it fixed? Here is a video that may help.
Mar 20, 2014 | Singer Advance 7422 Electronic Sewing...
I have Singer 5040c machine i was cleaning this machine it was working fine before, but machine is breaking needle all the time ,i can't sew anything, i just remove belt from bottom part cleaned it...
Your machine needs a professional to fix your timing and tune it up. You may have messed up the timing when you took off the belt. It is worth getting it fixed.
Sep 19, 2010 | Singer 5050 Mechanical Sewing Machine
I need the proper instructions on how to adjust the timing on my 7422 singer advance sewing machine. I used the buttonhole ...and ever since the machine is missing stiches and half of the other stiches...
You can try a whole new needle, inserted with the flat side facing away from you. Sometimes a burr or slight bend causes you to miss stitches. I would not attempt to set the timing myself as you may cause some damage. You can also call Singer customer service at 1-1800-4singer and they can advise you. Be very cautious of advice on the internet.
Sep 11, 2010 | Singer 7422
I have a Singer Sewing Machine Model 4562 T I
yes you can get help from youtube.
How to Fix / Repair the Hook Timing on a Sewing Machine
Oct 16, 2009 | Singer 132QRFB Mechanical Sewing Machine
Singer 7462 Mechanical Sewing Machine Logo
250 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
