Question about Nintendo DS Lite Console
Ds is plugged into charger. But when i try to
Ds is plugged into charger. But when i try to turn it on it just flashes off. help
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 117 Answers
What is the orange charging light doing? If it is just flashing on, or only staying on or a minuet, that means you need a new battery. The orange light foes on when the battery has been charged to its maximum capacity. After each charge, the capacity is decreased. So if the orange light is on for only a short time, get a new battery.
Posted on Mar 01, 2009
@ Samuel
So what your trying to say is to get a new DS charger?
Posted on Nov 25, 2011
Deni-YO
  • 10 Answers
SOURCE: charger stuck in ds lite
Gently wiggle the charger from side to side, not too much incase you break the pins. it may be a little stiff to start with. Apply a fair amount of force and have lots of patience : )
Hope this helps,
-Deni-YO
Posted on May 18, 2008
vinzen
  • 217 Answers
SOURCE: DS Not turning on - both screens flash
Try this if you haven't yet.Take the battery out,read the voltage with a meter,If low your charger is not working.Also if no meter try reinstall batery.Good Luck. DS's are unpredictable,you could not touch it for another month and it will work.
Posted on Sep 05, 2009
rulds2008
  • 3866 Answers
SOURCE: DS Charging Diffuculties
( times out of 10 here its the battery if by replacing the battery it still does not charge you got a bad charging unit inside the DS and your repair bill will be under $75 bucks to replace the chargin element inside.
Like my advice please accept and rate it today. We accept all postive answer ratings , Thanks.
Posted on Oct 09, 2009
Testimonial: "thanks"
  • 69 Answers
SOURCE: DS Lite turns on for a brief second. Then turns
This could be two things first try a new battery.You can get on ebay for $2 dollars.If that doesn't fix the problem then it should be a fuse. To get to the fuses you will need to take it apart. If you have a warranty don't send it back.There are a lot of ds lite repair videos on utube. To help you find the fuses.
Posted on Feb 23, 2010
  • 50 Answers
SOURCE: nintendo ds won't turn on.when charger plugged in
Your problem isn't with the screen it is with the fuses.
your fuse or fuses are dead. however, it is fixable, but it is extremely difficult.
1. if you don't have the time or the means or the wants to solder it, then sell it on ebay and you can get a fairly good price and someone else will fix it
2. if you do want to go through with this then you will need a meter, a soldering iron, and a lot of time and patience.
If you are interested, just notify me
Posted on May 23, 2010
Ds light green,dim green, amber then off when power is turned on
Sounds like you need to send it in for repair. I had sent my console to VideoGame911.com and they repaired mine at a great cost and got it back at the end of the week. Give them a try, they are cheaper than a manufacturer. Good luck!
May 04, 2013 | Nintendo DS Lite
Orange light flashes and wont charge
This usually means you either might have a faulty charger cable. Or it is connected to the wi-fi. I am guessing it is off. Try letting the ds run completely out of battery to the point where you cannot even turn it on. Then plug the cable into the ds first. Then plug the charger into a different outlet. Hopefully this solves your problem. Good luck :)
May 06, 2011 | Nintendo DS Lite Console
My ds lite turns on but it will not charge. It's not the battery or the charger. I have tested the fuses with a multimeter and both fuses read 0 ohms. The orange charge light does not flash briefly when I...
You can try buying another battery, or by buying a charging station that could just charge your battery (incase its the charger port on the ds thats broken).
Feb 28, 2011 | Nintendo DS Lite Console
When The DS Boots the top screen flashes for a second and the whole unit turns off.
You should try charging the DS system if the light is red. Make sure both the outlet you plug the DS into, the charger, and the DS charging port are not damaged. If this does not work, try visiting this website: http://www.nintendo.com/consumer/index.jsp or calling Nintendo Customer Service at 1-800-255-3700.
Hope this helped,
Alex
Mar 17, 2010 | Nintendo DS Lite Console
Oct 09, 2009 | Nintendo DS Lite Console
Sep 05, 2009 | Nintendo DS Lite Console
My ds wont turn on all i do is plug in the charger then flick the switch really fast then the light turns on for half a second then stops wat do i do I came home one day from a trip, I decided to use my DS...
Do any screens flash?
I would say its a fuse / grounding out / or battery is destroyed.
If you can, try a different battery.. Has your battery and/or DS had any previous water damage?
May 30, 2009 | Nintendo DS Console
Nintendo DS Lite - does not charge
i would suggest trying to find what the issue is, if you know anyone who has a different charger, try it on your daughter's ds. if it still doesn't work, it's a DS problem...if it's under warranty, go to whatever store you bought it at and have them fix or replace it. If you try the different charger and it DOES work, then the only problem is the charger...so then all you have to do is go buy a new charger...hope this helps.
Feb 05, 2009 | Nintendo DS Lite Console
Blank Upper and Lower Screens
Try plugging it into the charger and turning it on. If it still doesn't work, you probably broke the internatl port for the charger which is why it's turning on then back off right away because it's not able to charge anymore. If you stil have your warrenty, I would try to take it back.
Oct 23, 2008 | Nintendo DS Console
Power problems with DS Lite
Really sounds like a dead battery. The DS will not work if the battery is bad even when it's plugged in. You get the quick flash of the power light and that's it.
Mar 29, 2008 | Nintendo DS Console
Nintendo DS Lite Console Logo
306 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
