Question about Esky Flight Simulator R/c Helicopter Kit
Throttle goes wide open
Just purchased a received a 2.4 ghz coco Lama v3 rc helicopter. Either the receiver on the helicopter or the transmitter is defective. I have flown several helicopter and so I know how sensitive the throttle lever is. Anyways when flying the helicopter for the first time, I slowly advanced the throttle level and the throttle on the helicopter went full throttle and the lever was only half way open and I immediately tried closed the throttle moving the level downwards and the helicopter would not respond, but continued to run at full throttle striking the ceiling and breaking the blades.Came crashing down and was still running full throttle .
I read and did everything according to the instruction sheet. I feel that either the receiver on the helicopter or the transmitter is defective,
Any help appreciated.. Bob
I had the same issue. There are control-reversal switches on the controller. They are labelled. Teverse the thrust switch and try again.
Posted on Nov 07, 2012
  • 68 Answers
Its is probably a faulty potentiometer in the transmitter's throttle channel. Take it back to the store if possible otherwise see if you can get another transmitter and bind it to your helicopter. The binding process will be in your instruction book.
Posted on Aug 31, 2009
jyackle5
  • 8197 Answers
SOURCE: Building a RC helicopter for college
You might want to get on google and search how to build Remote Control Helicopter. you will find a lot of useful info. If you have never flown a RC heli thought I suggest you get a sim for the computer. I have been flying now for 10 years and they are not that easy to fly. I still have problems and always am learning some thing new. here is one link to look at.
http://www.angelfire.com/blues/heli_project/
Posted on Jan 30, 2010
micromend
  • 748 Answers
SOURCE: my rc helicopter can not fly it spin in floor
Hi
This type of helicopter uses a fixed pitch blade. Have you recently replaced one or all the blades? If the blades are correctly positioned then once the motor comes to speed, the pitch of the blade creates enough lift to overcome the force of gravity. The problem you're having can only be that the motor is not coming to speed or the blades have been replaced but the pitch is now at the wrong angle.
Posted on May 13, 2010
  • 906 Answers
SOURCE: find charger for world tech rc helicopter skyhawk
good day,
hope this link below will help tp solve your problem.
toys
Posted on Jul 29, 2010
SOURCE: we have two gyros S107G remote control
Had the exact same problem. Found the solution on an Amazon posting:
1. To enable this function make sure both remotes and both helicopters are off.
2. Set the first remote's channel switch to the leftmost position (it says A, B, and C, but the s107 only supports 2 channels). Turn the remote on.?
3. Turn the helicopter that you would like to bind to the remote on and set the helicopter down on a flat stable surface for about 5 seconds. Try the throttle and the helicopter should respond to this remote.?
4. Next, to enable the second helicopter, set the second remote's channel switch to the rightmost position (it says A, B, and C, but the S107 only supports 2 channels). Turn the remote on.?
5. Turn the second helicopter on and set the helicopter down on a flat stable surface for about 5 seconds. Try the throttle and the second helicopter should respond to this remote.?
This worked for us.
Posted on Dec 26, 2010
Testimonial: "excellent help. thanks a ton. now we'll just hope for no mid-air collisions. appreciate it!"
SOURCE: I BOUGHT TWO HELICOPTER FOR
I have exactly the same problem. It used to work fine for a long time but all of a suffen i got this problem. Do not yet know how to solve it.
Carl C
Posted on Feb 01, 2011
Skygiant rchelicopter when i sync it and then give it throttle all the lights on the helicopter syart flashing red and it dosent do anything
I bought 2 off brand ,of the same remote controlled Helicopters which cost about $30.00 each. The controller has A_B_C setting helicopter has none, You can set them up any way, either all on one or separate channels per controller which is channel A.
1st turn off Helicopter switch to off and controller off .
Set controller -1 to channel C , , then (controller-1 ) throttle knob to max, turn power on to controller -1 , throttle down and up 3 cycles and left and right 3 cycles
Turn on Helicopter 1 with controller -1 still on, it should work on channel C
Jun 11, 2014 | Team International Hawk Talon V3 RC Indoor...
Rc helicopter loses connection
Check the transmitter crystal (if it has one) and check the wires in the heli's receiver unit.
You should turn heli on wait 3-secs then turn transmitter on.
Dec 26, 2013 | Toys
Where doI find the slot to recharge my helicopter
with most rc helicopters you have to disconnect the receiver unit from its battery and connect the charging lead to the battery lead the charger should have 2 leads 1 for the transmitter & 1 for the receiver
hope this helps
Aug 08, 2011 | xheli Exceed RC 24Ghz WarHawk 300 4Channel...
I BOUGHT TWO HELICOPTER FOR CHRISTMAS FOR MY TWO SONS. THE ESKY LAMA V4 AND THE BIG LAMA. THE BIG LAMA WORKS GREAT AND FLIES WELL, BUT THE ESKY LAMA V4 ACTS STRANGE. WHEN YOU CONNECT THE BATTERY THE SERVOS...
Carl C
Jan 09, 2011 | Esky Toys
Hawk talon v3 - bottom rotor won't spin
I just got one for Christmas too. Had it flying for 10 seconds, and lost control. I have to work on my piloting skills! After that initial crash, I prepared for another take off and realized my lower rotor was not spinning. It turns out that the tiny vertical gear that powers the lower rotor gear fell off its axle. The axle is connected to the sensor that receives the signal from the throttle. Luckily, I found that tiny gear sitting inside the head of my helicopter. After spending 2 hours trying to place it back on the axle, I got it running again. The rotor was spinning again, but it wouldn't take off. I did some troubleshooting, adjusting the trim multiple times. Then the gear fell off again. I found it and noticed that I had damaged the plastic teeth from using my tweezers to reinstall it. You can go to Team-RC.com to buy a complete gear system for $6.95. You won't need to replace all of the gears, just the one that fell off, and it's always a good idea to have spare parts just in case.
Happy flying
P.
Dec 28, 2010 | Team International Hawk Talon V3 RC Indoor...
Where can i find a 2 channel receiver for a 2 motor boat. Right/left and throttle?
Hi DM,
A hobby store, garage sales, craigslist. etc. Another boat.
You need to have the Transmitter and Receiver paired to the same frequency.
You'll find most on either 27MHz or 49MHz. There are also six or so sub frequencies under each you need to worry about.
I can't be more specific than that with the information you supplied.
The motors or example, fuel or electric? Makes a difference.
Best regards
Mike
Jul 22, 2010 | SYMA Toys industrial 2-Channel New Syma...
Hi ihave brought helicopter ftw 730 but the remote control was not its own .the helicopter ftw 730 remote control frequency is 40 mhz but the one i have is 27 mhz so how can i make as 40 mhz remote...
Unfortunately you can't. You will need to change the receiver or the transmitter so they are both the same frequency range eg 40mhz or 27mhz. Then you will need to check the crystal is the same frequency for the Transmitter and receiver eg 40.25mhz. NB. you can't put a 27mhz crystal into a 40mhz set or vise versa it won't work.
Aug 21, 2009 | RC Remote Control Rc Mini Helicopter
Receiver problems right out of the box!!
You may have to "bind" the receiver to the transmitter again. See the instructions that came with the transmitter on how to do this. If this not the problem the hobby shop is obliged to make sure it works so take it back before it get damaged.
Mar 16, 2009 | Walkera HM5#10 RC Helicopter
Lama v3 spins counter clockwise with no lift off
WOW! I have experienced the same spinning action . . all new parts etc. I have repaired 6 Coco's but this one has ate my lunch . . . when you power up it spins to the left . . . the more throttle the faster it spins . . have changed the 4 and 1 also and adjusted . . . over and over . . . does the 4 in 1 control the rudder action?
Jan 30, 2009 | Esky Honey Bee King 2 RC Helicopter
Lama v3. going in circles
looking from the above top roters should rotate anticlockwise bottom roters should rotate clockwise also check blades are fitted right way round. I only sugest this because you have replaced the 4 in 1 and could have put on connections wrong wa round easy mistake good luck
Nov 12, 2008 | Esky Honey Bee King 2 RC Helicopter
Esky Flight Simulator R/c Helicopter Kit Logo
831 people viewed this question
Top Esky Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you an Esky Toy Expert? Answer questions, earn points and help others
