Question about Microsoft Excel for PC
How to change a word to afigure automaticll if change in excel sheet
  • Gerald Russell
    Gerald Russell May 11, 2010
    could you give me an example?
    do you mean if I change value in column B to "Joe" change the value in column C to 200? (or "john" = 300 etc.)?
  • 407 Answers
There are lots of ways of doing this - But it depends on how complex your fomula needs to be, or it may be a case of changing the format of the cell..
IF function will work well for a small range
LOOKUP will work well for a larger range assuming there will be duplications
Posted on May 22, 2009
My excel is starting right to left in window 7
The default worksheet direction in Excel 2007 or 2010 is Left-to-Right. To change a worksheet direction to Right-to-Left, follow these steps:
  1. In Excel Ribbon click on the Page Layout tab.
  2. In the Sheet Options group click Sheet Right-to-Left. The sheet direction will be changed. Column A will now be to the far right. Columns B, C, D.. etc. will follow to the left.
- See more at: http://www.exceldigest.com/myblog/2012/04/29/how-to-change-worksheet-direction-in-excel-2010-to-right-to-left/#sthash.lSG25YXq.dpuf
May 27, 2014 | Microsoft Excel 2010
What is exel sheet extension in office 2010 ?
Excel Workbook
.xlsx
The default Excel file format. Cannot store VBA macro code or Microsoft Excel 4.0 macro sheets (.xlm files in Excel 4.0).
Excel Macro-Enabled Workbook
.xlsm
Uses the same basic XML format as the Excel Workbook, but can store VBA macro code. Users saving an Excel workbook that has VBA code or Excel 4.0 macro sheets (.xlm files in Excel 4.0) are prompted to use this file format.
Excel Template
.xltx
The default file format for an Excel template. Cannot store VBA macro code or Excel 4.0 macro sheets (.xlm files in Excel 4.0).
Excel Macro-Enabled Template
.xltm
Can contain a VBAProject part or Excel 4.0 macro sheets (.xlm files in Excel 4.0). Workbooks created from this template inherit the VBAProject part or Excel 4.0 macro sheets that exist in the template.
Excel Add-In
.xlam
A supplemental program that runs additional code. Excel add-ins use the Open XML file format to store data, and they support using VBA projects and Excel 4.0 macro sheets.
Feb 21, 2011 | Computers & Internet
I export to excel .excel sheet format is different. i want excel sheet format how to change the excel sheet
you should export data in xml format from tally your problem will solved for any problem kindly contact 09310947557 (Narendra Chaudhary)
Jun 20, 2010 | Tally T2245 Matrix Printer
I cant print on A3 paper through microsoft excel on hp1280
in excel sheet please change the page size to A3 and try to print ..... if you are using office 2007 go to page layout then go to size icon there change the page size to A3 and check .......... if you are facing the same problem please post your comment ............. while you giving print please select the document which one you want to print ..........
Dec 31, 2009 | HP DeskJet 1280 InkJet Printer
How to sende information from a sheet to another?
You can link to the original sheet or copy and paste - Linking might be easier as you only have 10. - Can you not use worksheets rather than excel. If you want to make it more autonomous you can index or look up the first sheet so any changes you make will be reflected back in your employee sheets.
May 26, 2009 | Microsoft Office Excel 2003 for PC
Unprotect an Excel sheet
Print or convert it to pdf then you may copy/paste from the pdf to a new unprotected sheet.
Doesnt work for formula.
Feb 18, 2009 | Computers & Internet
Excel problem
Is the stock register an excel spreadsheet?
May 10, 2008 | Computers & Internet
How to Export trial Balance from Tally 9.2 version to Excel sheet
you select the trial balace--and press Alt+E or click export---then the export details screen came,
Language: Default(all language)
Format: Excel (spreadsheet)
Output file name: trial bal.xls (any name you select)
Excel (spreadsheet) formating: yes
other details you select and accept the screen. then minimise or close the Tally, you open the tally file name at my computer. at the time you can see the file trialbal.
Mar 20, 2008 | Computers & Internet
How to Crack Excell sheet's Password
http://www.straxx.com/excel/password.html
Mar 03, 2008 | Computers & Internet
How can i change my old excel sheet password
Dear shiltu, you first have to remove your password. Press the old password and have access to the document. Now remove the password. Set new password and save it. You're done :)
if that has helped you please press fixya.
Dec 22, 2007 | Microsoft Excel for PC
Open Questions:
See all Microsoft Excel for PC Questions
Microsoft Excel for PC Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
