Question about Intertherm P3RA-036K Air Conditioner
After the heat has been on for a while it will all of a sudden start cycling off and on very quickley, so i will have to shut it off.
  • 3,361 Answers
Your contactor is defective and or a loose wire connection to the contactor.
Posted on Mar 04, 2009
Why is my 1982 wb statesman engine reving at 3000 revs at start up all linkages and cables in correct positions.thanks
sounds like dashpot i stuck when u accell quickley and then return to idle their is a dashpot that keeps the plate from snapping shut iy lets it close slow if it is out of adj or just stuck it could hold yout throttle plate open
Nov 22, 2014 | Cars & Trucks
Ge front loader dcvh515efoww - dryer shuts off when put on heating cycle
Did you pull the dryer out or forward sounds like you may have pinched the exhaust which restricts air flow exiting the unit this will cause it to heat briefly shut down heat shut down and continue this cycle the fact that it worked before makes me think it something simple it will not tumble in any cycle if door switch not installed correctly.
Mar 21, 2014 | GE Dryers
I have a Whirlpool LER4634PQ1 it was working just fine then all of a sudden the dryer just keeps running the knob on the dryer doesn't move and the air isn't warm. Any suggestions on what to s
there is a cycling thermostat in line with the high limit thermostat and timer circuit,on timed dry its disabled and the timer will run no matter what,on any sensor dry setting it uses the heat of the element to heat this cycling thermostat to move the timer as the clothes get drier as the heating element heats the timer doesn't move,when the heater cycles off from the high limit thermostat then timer moves again,you need to find out if its a bad heating element,thermal fuse or possibly even a circuit breaker in the homes electrical panel tripped out on one of the 2 phases that gives you the 240 volts required to operate the dryer element,the breaker may not show its tripped,so shut it off and back on and try this first
Dec 11, 2012 | Whirlpool Dryers
Bosch Axxis WTE86300US turns itself off after ten minutes, won't turn back on for a few minutes after that
I would bet you have a bad sensor. There are a couple of sensors that monitor heat. When it gets too hot they shut it down as a safety precaution. Once it is cool enough it will start up again.
Sep 26, 2012 | Bosch Dryers
Hi i have a wr400 99model and have just done an oil filter n oil change then i started my bike it all seemed fine until five minutes of the bike running the header pipe started to glow red i drained the...
All the wrf's,250 426 400 etc. WILL heat up and boil if they are left running without being ridden.They need air to be flowing over the radiator.1 minute can be enough to get them hot if the choke is used.You wrote that this happened after an oil change.Did you previously let the bike sit and run?.Check your air filter is clean as this can enrich the fuel/air ratio and create extra heat.Main thing is ,shut the bike down if you are stopping for more then a very short time.To satisfy yourself,take the bike for a slow ride as it is warming up.It can take up to 1 mile to get proper temp. into the entire motor.Hope this helps
Apr 24, 2010 | 2000 Yamaha WR 400 F
Furnace starting
Hint number 1, get HVAC license. One mistake or misunderstanding and you could blow your house up.
Feb 21, 2009 | Heating & Cooling
Intertherm P3RA-036K Air Conditioner Logo
27 people viewed this question
Top Intertherm Heating & Cooling Experts
Dennis Boxerman
Dan Webster
Dan Webster
Bill Long
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
