Question about IBM TravelStar 40GN 30 GB Hard Drive
Panasonic kxp-2123 old d-m printer paper will not feed
I know this is "old" but it worked like new until someone in our home hand feed paper into printer by turning the roller. After that it will no longer feed paper, although it goes through the rest of the printing motions. I can change all the settings but it will not Auto Feed, Form Feed or Line Feed paper. I remember in college my instructor stressing "Not to manually feed paper"
Can you help me, I love this printer it is so cheep to use and the ribbons last forever.
Thanks, Deb
checkitright
  • 1362 Answers
SOURCE: Info print 1140
when you go to the menu of the printer is the paper TYPE set correctly?
tray 2 should be letter ( if using plain paper)
tray 3 legal, label etc...
and tray 1 should be any
Posted on Oct 19, 2007
Bubbabear64
  • 2794 Answers
SOURCE: IBM Infoprint 1512 out of paper message
It could be a problem with the paper feed roller above the tray or a sensor problem.
It should be looked at by a service technician.
Posted on Jun 12, 2008
  • 65 Answers
SOURCE: IBM 4232 Printer Problems
in the PRINTER SETUP menu there will be FORMS DEVICE
select and set
Continuous Forms — F1 or F2
Dimensions
Forms Min Max
Width 3in - 15in
Length 3in - 14in
Posted on Jan 17, 2009
SOURCE: Can hardly read print after putting on new ribbon
You have to make a platen adjustment (on the left side move it back).
Posted on Apr 14, 2009
  • 3594 Answers
SOURCE: Typewriter is working fine but won't type anything on the paper - new ribbon / new printwheel - no impression. Appears to be stuck on a "stencil" setting.
Put in a mulit part form, if it prints on the copies the ribbon isn't lifting, if it dosen't the plastic cap on the print solenoid needs replaced.
DickyO
Posted on Apr 30, 2009
Need a user manual for adding machine EC-3017
The feed roller turns to mush on these old calculators. I suspect that is the problem with this one. You might get it to work if you replace the mushy roller by a new piece of rubber tubing. However, you have to be mechanically inclined to take the printer apart enough to get to the mushy roller. I have this exact same calculator in my hand right now and when I folded printer paper on a 45 degree angle and forced it through the printer until I could pull it through, the paper was gooed up down the center where the mushy roller rubbed off onto the paper. The calculator still works great electronically!
Dec 13, 2013 | Radio Shack Office Equipment & Supplies
No power Panasonic kxp 4420
I would like to buy your Panasonic KX-P4420 Laser Printer in any condition working or not. Pete (847) 201-1612
Feb 12, 2011 | Panasonic KX-P4420 Laser Printer
I have a panasonic kxp 1180 and want to use it with my mac pro, the 1180 doesnt have usb port?
Since I don't visit the "dark side" LOL I don't know if this will help. I have a USB to Parallel (try a search engine) adapter that works on my PC's. http://www.cablestogo.com/product.asp?cat_id=1537&sku=16898
Carl
Sep 22, 2010 | Panasonic KX-P1150 Matrix Printer
Printer is saying manual feed insert paper. Will not print
To load paper or other media in the Manual Feed Slot (directly above the Paper Tray)
You can load envelopes and special print media one at a time into this slot. Use the manual feed slot to print or copy on labels, envelopes or thicker paper.
1. Slide the paper guides to fit the paper size.
2. Using both hands put one sheet of paper in the manual feed slot until you feel the front edge of the paper touch the paper feed roller. Let go of the paper when you feel the machine feed the paper in a short distance.
Note: When you put paper in the manual feed slot, please remember the following:
■ The side to be printed on must be face up.
■ Put the leading edge (top of the paper) in first and push it gently into the slot.
■ Make sure that the paper is straight and in the proper position on the manual feed slot. If it is not, the paper may not be fed properly, resulting in a skewed printout or a paper jam.
■ Do not put more than one sheet or envelope in the manual feed slot at a time or you may cause the machine to jam.
■ You can remove smaller sizes of printed paper from the output paper tray more easily if you lift the scanner cover using both hands as shown in the illustration.
You can still use the machine when the scanner cover is raised. You can return the scanner cover to its home position by pushing it down with both hands.
If you would like to disable Manual Feed Mode, check that the manual feed mode is not selected in the printer driver.
Here is a copy of the User's Manual for the Brother MFC-7820N.
Jul 07, 2010 | Brother MFC-7820N Laser Printer
Printer offline mode
plz try by with new cable, if the problem is not solved then check your port
Nov 12, 2009 | Panasonic KX-P1150 Matrix Printer
Paper feed not move
If I recall the KXP series, it is a track feed printer as well as sheet feed, there should be a lever on the top that you can move to different positions, one position is for feeding paper without the rollers, when the lever is placed in a different position it releases the rollers so the printer can feed the paper. The open position is for installing paper or clearing paper jams. Also if I recall, the lever is on the right side near the roller on the end. When you move the lever, and turn the roller, you fill feel it grab the paper. There is also a switch on the front for line feed and page feed allowing you to tear off a page and then pressing it again will reverse the paper to print position.
Aug 30, 2009 | Panasonic KX-P3696 Matrix Printer
Paper does not feed
Take it apart and clean the roller assembly.
Fan the paper stack before placing it in the tray.
Insert about 25 sheets at a time
Apr 15, 2009 | Dell Office Equipment & Supplies
Sending Reverse Line feed to Epson LX-300+II USB printer
Hi Shery,
I went through the manual of LX300 printer series.I believe that if u read that manual, you can Fix the problem as it has all instruction about the Reverse feed and pull tractor mechanism.
Download Manual
http://ftp.epson.com/pdf/lx300p/lx300ppg.pdf.Any issue contact me.
Thank you
Riz (zyrixdown3@gmail.com)
Feb 11, 2008 | Office Equipment & Supplies
Adjust Upper Bin displays on my printer
How old is your machine? check if the printer supports that thickness. if so check the setting of the printer if it match with your actual paper. if your printer is older and your place is dusty try to clean the rollers under/inside the paper tray.
i hope this will help.
Nov 23, 2007 | Minolta magicolor 2200 DeskLaser Printer
IBM TravelStar 40GN 30 GB Hard Drive Logo
90 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
