Question about Zoom (56600000) DSL Modem
Configuring ppoe connection with zoom modem
The default gateway number for the modem.how to configure ppoe for the zoom modem.
  • Anonymous Mar 11, 2008
    Configure PPPoE
    Scholar:
  • 125 Answers
Your external (WAN) IP should be set to DHCP for most ISP's. Your internal IP will be the default gateway for everything in your LAN to get sent to. If you can log into the zoom with your browser, try that IP address for your gateway. If not can you let me know some more details on your zoom model.
Posted on Aug 08, 2007
SOURCE:
Router ERR_CONNECTION_RESET error
See the manual , pages 5-6 (link below) for the location and operation of the factory reset button on the back of the router. This will restore factory defaults, which means you will have to set up your router to match your network devices again, or just start over with new network settings.
http://www.cisco.com/en/US/docs/video/at_home/Cable_Modems/2300_Series/4042831_A.pdf
Apr 16, 2014 | Computers & Internet
The HP M111 working perfect until It looses power. After the power loose the unit falls off the network and needs to be reset to fatory defaults
if you are using a ppoe connection then save your isp account user name/password in the modem weather it be a cable modem or a dsl modem and then setup and configure your access point device and SAVE your settings in the device.
if you using a dhcp connection from isp modems then just connect your access point device and setup amd configure your settings and SAVE them as well.
the only thing that i can think of is that you are not saving your settings and configurations. then when you you loose power the device reverts back to the default settings. also note that if there is some kind of "auto-configuartion" in the access point you may want to change that to manual configuration and create a new user name/password for your access point as well. please you MUST be hardwired connection when setting up the access point for the first time. please refer to the user guide for your access point for more detailed help on settings and configurations and how to save them in your device.
Aug 25, 2011 | HP ProCurve M111 (J9389A) 802.11a/b/g...
Hi i ahve a zoom modem, im not at my house right now so i don't know the version of my modem. The internet light is red and everything else is solid green, i tried restarting and holding off for 30 seconds...
u have to configure it to connect to the internet once again through ur default gateway and to look for that open a command line in windows and type ipconfig and u should see ur default gateway. then type that in ur browser and VOILA!
Aug 11, 2010 | Zoom (5590-00-03) Wireless Router (G66115)
Can't access Config Manager for Router - Zoom x6 5590
- Reset the router (10 seconds)
Access the configuration page (10.0.0.2)
or
Try to assign a static IP address to the computer (IP 10.0.0.52 Automated SubnetMask, Default gateway 10.0.0.2)
(Note: Make sure that your computer is physically connected to the LAN ports of the router and your modem is connected to the WAN or Internet port.)
Mar 08, 2009 | Zoom X6 Adsl Wireless Gateway Rohs Router
DSL connection not being shared by Linksys RV042 Dual Wan router
Looks like your "modem" is actually a gateway, as is common with DSL devices. It's acting like a modem and a router. So you're actually connecting a router to your RV42. You could get this to work a couple ways.
1. Leave the modem acting like a router and configure the WAN connection on the RV42 as a static IP, and use the IP of the modem. You may also be able to use "obtain IP automatically" in the WAN connection. This way, the modem stores your PPOE information and just forwards the traffic to the RV42. Any devices behind the RV42 won't know the difference.
2. Configure the modem as just a modem (no routing). Your ISP should be able to talk you through this, but in the modem configuration you can look for what's usually called "bridged mode." Then you would enter the PPOE information in the RV42. This is my preferred method.
Feb 24, 2009 | Linksys RV042 VPN Router
Modem automatically not configured ( Network Adapter)
This happens with almost all the modems and routers. You can try resetting the modem ( you can find the reset button at the back side or underneath the modem ). After the reset, the modem should get auto configured.
Thank you
Apr 29, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
My toshiba computer does not work with my wireless internet
what brand of wireless modem you have, what os are you using?did you switch on the wireless in your laptop? sometimes we overlook the most simple things, it happens to me..
ok, you have to configure your laptop to connect to your wireless modem, how? just connect first your laptop with wire to the wireless modem, does it work? if it does work you can take the default gateway ip add from your pc by typing IPCONFIG on the command prompt , then type it in your internet explorer address bar.
example default gateway..... 192.168.1.254
and supply the username and password, you can now configure your wireless connection wep/wpa configuration.
Apr 01, 2008 | Computers & Internet
Zoom adsl x6
If the Internet light is off it means you are not either authenticated at your provider or your configurations are wrong on the modem. If you go to your command prompt and type ipconfig and check your IP address and your default gateway. The IP address on your default gateway would be your router put that IP address on your browser and should be able to see your modem setting and any error messages that could help resolve your issue
Feb 18, 2008 | Zoom X6 Adsl Modem/router Rohs...
Accidentally switched to 64 bit encryption and now the internet connection doesn't work
http the router through its address (you'll find that in the manual). once you access the router, you'll be able to change all the settings.
Dec 26, 2007 | Zoom (5590-00-03) Wireless Router (G66115)
Zoom (56600000) DSL Modem Logo
1,005 people viewed this question
Top Zoom Computers & Internet Experts
Paul Castley
Paul Castley
Prashant M
Prashant M
micky dee
Are you a Zoom Computer and Internet Expert? Answer questions, earn points and help others
