Can i convert my dyna glo 75000 btu propane
Can i convert my dyna glo pro 75000 btu propane torpedo heater to natural gas?
  • Anonymous Mar 12, 2014
    This is a aerothermes unit heater, natural gas.Normal input capacity 125,000 BTU/HR.
    Thermal output capacity 100,000 BTU/HR,
  • 137 Answers
I'm sure you can, contact the manufacturer and ask if they have a natural gas jet or orfice for your model heater, these are usually very easy to replace.
Posted on Feb 28, 2009
I have a dyna glo RMC 40 NGT vent less wall heater that I would like to convert to propane, I need to know which conversion kit to buy, and where. Thank you.
dyna glo natural gas heater Questions & Answers - Fixya
www.fixya.com > Forum > Tags
dyna glo ventless rmc50 ngt can this heater be changed from natural gas to propaneuse, ... Dyna Glo Natural Gas conversion to LP Gas I have a Dyna-Glo natural gas space ... Question about D-E36 Infra-Red Wall Mounted Panel Heater ... dyna glo heater model #RMC-40GT I believe on your particular model , that you ...
Parts for Dyna Glo, Thermoheat and Dyna Glo Pro Heaters
spaceheaterparts.com/category.sc?categoryId=13
Shop Dyna Glo, Thermoheat, Dura Heat, Workhorse LP and oil fired htrs ... Circuit Board 2201181 Dyna Glo & Thermoheat 150k Nat Gas Htr RMC-FA150NGDGD ... This spark plug (ignitor) is used on Dyna Glo and Thermoheat 40K btu LP.
Propane Wall Heaters - Walmart.com
www.walmart.com > ... > Heaters
WalmartDyna-Glo IR18NMDG-1 18,000 BTU Natural Gas - Infrared Vent Free Wall Heater. $170. ... Dyna-Glo 40K Liquid Propane 360-Degree Tank Top Heater. $88.00 ... Dyna-Glo Deluxe RMC-FA125DGD Portable Gas Powered Forced Air Heater.
1352062 Dyna Glo Natural Gas conversion to LP Gas
162.220.53.34/F/.../t1352062-dyna_glo_natural_gas_conversion_lp_gas
Jan 12, 2016 | Heating & Cooling
I need a thermocouple for a dyna glo natural gas wall heater
Billy here's a link to A & B Sales. They have what you're looking for. Whether your heater is Natural Gas or Propane makes no difference when it comes to thermocouples.However the length of the tubing does when it's a wall or stand type vent-free heater.
http://www.aandbsales.com/2.html
Hope this helps you & thanks for choosing FixYa.
Sep 21, 2011 | Rinnai Desa Vent-Free Infrared Gas Heater:...
I have a dyna glo 30000-50000 btu propane heater, I would like to switch to natural gas .Is this possible?
It may be possible, but I have never seen a conversion kit for them.
Also given that the only thing of value in one of those is the gas valve it is probably much more cost effective to just sell the one and buy the other...the difference would be the cost of the conversion kit and you have no labor involved except removal and re-installation...and that takes all of a few minutes...
heatman101
Oct 13, 2010 | Dyna Glo "" Natural Gas Heater Mn200tba
We have a dynna glo zero clearance for Natural Gas
Before you attempt to covert to lp. You need to check the flue. Black smoke is cause by incomplete combustion. So it may be now plug with black soot. Heat-exchanger may be damage Before you invest in a lp kit. Make sure it is worth it. To convert you need the main burner orifices and lp spring for gas value. Once you replace these parts you must adjust gas pressure, nat gas is measured at 3.2 - 3.5wc lp is measured 10.5 - 11.00 wc. In my honest opinion this is to dangerous for customer to attempt. Please a HVAC contractor inspect unit and install lp kit.
Nov 20, 2009 | Dyna-Glo D-E37 Wall Mounted Panel Heater
I have a RMI-70LP Dyna-Glo 18,000 btu unvented room heater. Can it be converted to natural gas?
These can be converted by changing the orface on the heater and also the regulator. Best to contact your gas company or Dyna Glo to obtain the correct orface for that particular heater.
Oct 08, 2009 | Dyna-Glo Heating & Cooling
Dyna-Glo natural gas space heater to propane gas.
Yes it is possible and a good idea. You need to have a regulator installed to reduce the pressure to the heater and this is a simple procedure. Contact your local Propane distributor and they will probably do this free to get your business.
Ray
Dec 08, 2008 | Dyna-Glo Heating & Cooling
Yes and most larger hardware stores will carry the parts ( it should only be a connector and a small adjustment...cost...maybe $6.00 to do
Dyna glo ventless rmc50 ngt
All gas heaters can be converted from one type of gas to another, be it natural or propane. The problem is getting the orifice retrofit parts that fit that particular brand. If the manufacturer doesn't make them, then you are left with no choice.
Mar 12, 2008 | Heating & Cooling
Heating & Cooling Logo
581 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
