Question about Intel Motherboard
Remove viresfrom pc vrice
I need to remover vries from my pc
  • 385 Answers
Go to http://free.grisoft.com and download the free version of AVG Antivirus. Update it and scan your PC. Another software that works excellent is Malwarebytes Antimalware. You can find it at http://www.malwarebytes.org.
Thanks and good luck!
Lolita
Posted on Feb 28, 2009
My iron temp cuts off and only stays at a low temp even thou it is at it highest settings regards Mike
It is possible that the BIMETTALIC cut off is OFF set and so the cut off happens vry early .
You might need to remove the unit and get access to see if this can be set to higher level- tighter- so that the bimetal takes more heat to cut off. This will provide you a higher heat.
You can calibrate using the highest/lowest settings.
Aug 08, 2011 | Philips GC 148 Iron
Every one says that pulsars engine is bad it has power perfomance but the won't last!
no nt at ol....pulsar engine are vry good.......if u drive ne bike vry hard it ll show problems.....
Dec 16, 2010 | 2007 Bajaj Pulsar 180
Intel Celeron Cpu Can this be removed from your laptop my laptop is running vry slow I opened the back & it has RAM but ther i a spac whre somethig has been removed I bought this laptop scond hand and...
Well the cpu can be removed, but the only way to improve it would be to buy a faster cpu that is compatible with you laptop hardware and the motherboard in the laptop. The easiest and cheapest way to make it faster is to upgrade the ram. you can upgrade the 512 ddr2 to 2gb ddr2 i believe. The wireless issue is either a driver issue or a faulty wireless card. The wireless cards are fairly cheap. The driver can be found here at the link below and you can see if it fixes it. hope this helps let me know if you need anymore help
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=3375995&prodTypeId=321957&prodSeriesId=3375953&swLang=8&taskId=135&swEnvOID=1093#11395
ps. im am not sure which wireless card you have installed on you machine but you can try all the drivers and it will not install if is not the right one. if it is the right one it will install and hopefully fix this silly issue.
Nov 05, 2010 | HP 530 Notebook PC
How can i unlock my puk code ????????????????it vry vry urgent........
find the paper of your sim tehn you will see the puk code or else you better buy a new sim card
Jul 26, 2010 | Nokia N73 Cellular Phone
Wnt to download audio output device in compaq presario c700 . plz give me d link so that itcan be done. thank you vry much.
wnt to download audio output device in compaq presario c700 . plz give me d link so that itcan be done. thank you vry much.
May 01, 2010 | Compaq Presario 700 470024-192 Notebook
Canon dk100i battery change
it's very easy you have to unscreww on the back of the calculator the 2 small screws and then remove the top and be carefull not to unplug the small wires. Inside you will see the battery holder and you will need to remove the battery carefully by pushing from the side of it with something vry small (like a dime) and then replace it by a new battery type CR2016. Then you put back the cover and the screws.
After that you will have to do a reset with a small pin or with the tip of a pen.
Then it will work as a new one.
I just did it yesterday and itis working pretty well.
Good luck
Regis from Montreal, QC Canada
Apr 03, 2009 | Canon DK100I Calculator
How to open a back flap of nokia 3600slide
check d back side of d phone. at d bottom thr a thin rectangular button. press it and pull out d flap..
Jan 22, 2009 | Nokia 3600 slide Cellular Phone
Remove the sino gusto virus
Depending on how long the virus has been in the system, an anti virus program may not fix the damage. I suggest reformatting the hard drive with a full NTFS format and installing a new operating system.
Aug 19, 2008 | Dell Inspiron 1300 Notebook
Vry strange prob...
MESSEGING
SIM MESSAGES
I HOPE IT WORKS and don't forget to rate me SOLVED.
Nov 16, 2007 | Nokia N70 Cellular Phone
Audio, but no video
yes the brown ribbon is ripped and you need it replacing its vry cheap abot 50 quid and 20 for fitting thanks
Nov 12, 2007 | Kenwood Excelon KVT815DVD Car DVD Player
Intel Motherboard Logo
23 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
