Question about Whirlpool Refrigerators
Refrigerator stopped cooling.
I have an 11 yo whirlpool refrigerator (ED20ZK) that suddenly stopped cooling, but still runs. It didn't cool for two days then all of a sudden started working again. When I moved the temperature control settings back down to normal levels, it shut off and has again stopped cooling (even though a can hear the fan/blower working). What do you suppose the problem is, and, is it worth fixing vs. replacing the unit?
  • 116 Answers
SOURCE: Sears Kenmore 53652300, doesn't cool
This usually indicates that the compressor is working too hard and drawing too much current. The click that you hear is a safety shut-off. Possible causes of this are numerous and usually require having a professional come in to fix the issue, it can range anywhere from a faulty compressor to a bad start relay.
There is in most cases a temporary fix, it is called a hard start relay/capacitor. It is usually available from an appliance parts retailer for around $15 to $20. Installation instructions are included, just be sure to unplug your refrigerator first and make sure that someone following you can repair from where you left off. This relay assembly can normally get you up and running but it should not be used as a permanent fix. This will not correct for a refrigerant leak in the system.
Check your refrigerator owners manual before making any repairs or modifications to your refrigerator, there may be an extended warranty on the sealed system and compressor.
Posted on Aug 01, 2008
SOURCE: Kenmore 52603100 refrigerator was icing up, now has stopped cooling!
Here is your problem:
There are two temperature sensor wires; one should be routed around the vent on the upper left corner of the "ceiling" of the fridge. It will route inside the plastic cover in the back upper corner.
The second one is critical. It originates inside the cover and must pass through the wall of the fridge into the freezer and rest just inside a hole in the rectangle that passes through from one side to the other. If the very tip of this sensor is not well inside the freezer, the system will think the freezer is too warm, never turn off and the lovours inside the plastic housing described above will jam with ice and get stuck. This piece will have to be replaced but will continue to freeze and break until the sensors are placed in the correct locations. Don't ask me how I know all this.
Good luck.
Posted on Oct 15, 2008
Sea Breeze
  • 4654 Answers
SOURCE: refrigerator not cooling
You model if the ARB1950C has a defrost timer inside the fresh food compartment and behind the temperature control panel. Need to see if you can manualy turn the timer clockwise until the compressor stops. During that time of 25 minutes the freezer should be in defrost. I believe your timer needs replaced based on how you explained what is happening. The part number for your timer is 67001036 and can be found at the links below. If it stays longer that 25 minutes then it's sticking in the defrost section of the defrost timer and will need to be replaced. If your refrigerator does not restart after about 25 minutes then slowly turn the timer through the opening in the plastic cover. There may be a plug covering the hole to make the hole not so visible. If you should have problems fell free to let me know, Thanks Sea Breeze
appliancepartsse@yahoo.com
http://servicepartstec.blogspot.com/
http://appliancepartsse.blogspot.com/
Posted on Aug 17, 2009
aasc
  • 1606 Answers
SOURCE: whirlpool refrigerator stopped cooling. the
You have a bad overload/relay . This is the piece pluged onto the side of the compressor , with 2 or 3 wires going to it . The part number is 8201786 . It is easily replaceable and instructions come with it . Price is around $60.00 .
Posted on Nov 13, 2009
  • 2468 Answers
SOURCE: not cooling
your ptc overload on your compressor has gone out and needs replacement,locate the compressor and unplug the overload off the compressor and take it to an appliance parts place and purchase the correct replacement ptc overload and plug it back in and your good to go
Posted on Jun 18, 2010
Hello, We have a Whirlpool Gold bottom freezer
I don't know about Whirlpool refrigerator freezers, but my Amana has a temperature control in the freezer that regulates the overall cooling, and then the control in the refrigerator compartment controls how much of the total cooling is sent to the refrigerator section. My advice would be to lower the temperature setting of the freezer, and see if the temperature lowers in the refrigerator as well. Also, you can go to the Whirlpool website and they can help you further.
Aug 02, 2013 | Refrigerators
Whirlpool refrigerator not cooling after storm
Assuming that both freezer and refrigerator temperatures have risen and the humming sound that you heard was followed by a sudden click more than likely the start device on the compressor has gone bad. This is a common problem with all Whirlpool refrigerators (KitchenAid is Whirlpools top of the line product and suffers the same problem).
May 11, 2012 | Refrigerators
Whirlpool refrigerator model: ET8CHMXKQO 3 does not cool or freeze
unplug for 15mins after to remove the freezer to 3 feet from the wall. after those 15mins plug back
Mar 10, 2012 | Whirlpool Refrigerators
11 YEAR OLD SIDE BY SIDE SUDDENLY STOPPED COOLING BUT THE FAN RUNS AND DOSE NOT SHUT OFF.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jun 08, 2011 | Whirlpool GS6SHAXLT 25.5 Cubic Foot Side...
My whirlpool refrigerator stopped getting cold but freezer works
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Nov 27, 2010 | Whirlpool Refrigerators
All of a sudden, water started comming from the freezer. Seems the freezer stopped (refrigerator) cooling/ What do you think is the problem, and is it a major situation. ????
heatman101
Nov 24, 2010 | Whirlpool GS6NBEXR Side by Side...
I have Whirlpool ET8MHK Top Freezer Refrigerator and all of a sudden it stopped cooling. I had to crack up the setting to coldest to work. what part needs to be placed?
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Aug 29, 2010 | Whirlpool ET8MTKX Top Freezer Refrigerator
11 years old. Just stop cooling both freezer and
hello mam
the compressor of your refrigerator is out of service and should be recharged by the refrigrant so to do this work please call the engineer and check the work to be perfect and if he dont do it you should buy a new one.
Sep 27, 2009 | Refrigerators
My whirlpool ET8MTMXKQ01 'runs' but suddenly stopped cooling the freezer and refrigerator compartments, even when set to the coldest setting/ tje refrogeratpr was made in 11/01. never had any problems...
Switch off completely for a day and give a good defrost. If when you retry and it still does not cool,(assuming the compressor is running) then you have either got a blockage or an internal leak. Need to then get a technician to sort out.
Sep 21, 2009 | Whirlpool ET1FHTXM Top Freezer...
Refrigerator is not cooling but light is on.
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
Jul 04, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerators Logo
91 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
