Question about Maytag Atlantis MAV6000 Top Load Washer
Whinning noise my maytag, makes a whinning noise on spin cycle, and now im getting it in the agitation stage also..is this a do it yourself fix...thanxs
  • suzydonato Mar 02, 2009
    thanxs yes it sounds like a jet plane on take off..
  • WRMtech
    WRMtech May 11, 2010
    does this sound like a "scraping" or "marbles"? if so you could have the bearing in the pump failing. If it is more of a sound like a jet plane on take off, it could be the main bearing unit. Either one will require you to have a service company.
  • 70 Answers
If your unit sounds like a jet plane, your tub seal and bearing must be changed. You would need tohave a service company do it. There are special tools rewuired that cost upwards of 125.00( just for the spanner wrench) the labor ranges from 110-145.00
Posted on Mar 02, 2009
We have a Maytag Performa PAV2200 Washing machine...lately, during the spin cycle it makes a loud whinning or scraping type of noise during the spin cycle and sometimes during the wash cycle.... we took...
Might be the tub bearing going out. Is she leaking any?
Here is a visual inspect and repair of the tub seal:themobilian_1841.jpgthemobilian_1842.jpgthemobilian_1843.jpgthemobilian_1844.jpg
I used a pipe wrench to unscrew this top portion of the seal (lefty loosey)themobilian_1845.jpgthemobilian_1846.jpgthemobilian_1847.jpgthemobilian_1848.jpgthemobilian_1849.jpgthemobilian_1850.jpgthemobilian_1851.jpgthemobilian_1852.jpg
Those 6 springs are pretty tough to get back on there without the special tool
other than that it all goes back pretty easy.
Service manual and more HERE
Mar 12, 2011 | Washing Machines
Making loud noise in the spin cycle and now does not spin at all
Sounds like the tub bearing is gone. Get it checked out though. It could be the pump bearing, a cheaper fix. Or as bad as the tub bearing, a motor bearing.
Feb 26, 2010 | Maytag Washing Machines
Making an awful ratcheting noise during aggitation and spin cycles
Under the agitator there is a rachet mechanism that works the agitator. If it is stripped, it will skip until the next good tooth.. when it fails entirely the agitater will stop going back and forth. Its nylon and age along with overloading hastens its dearg.. If you can get the parts you can replace it yourself without difficulty. There is a single bolt in the center of the agitator top . Remove and loft agiyator straight up.
Jun 03, 2009 | Maytag Legacy Series Top Load Washer
Washing machine won't agitate
it sounds like the transmission is shot. Not knowing the cost of parts if you can replace the transmission yourself then yes it could be worth fixing however if you can't do the job yourself adding cost of parts and labor it may not be worth it
Jan 01, 2009 | Maytag Atlantis MAV6000 Top Load Washer
LOUD NOISE IN SPIN CYCLE
you have a bad tub seal asm. remove agitator, spin basket and tub asm. remove seal and install new one. good luck
Dec 15, 2008 | Maytag Performa PAV2200
Agitation issues. Everything else appears/works normally.
I just encountered the same problem. I think the operation of the machine is such that the motor turns one direction for the spin cycle, and the other direction for the agitate cycle. I am replacing my motor, as I think i have a bad winding on the reverse. I will let you know.
Jul 03, 2008 | Maytag Performa PAV2200
Agitator is making noise
bearings in the transmission are going out. they are fairly cheap if you can change them yourself.
Mar 29, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Im tryin to fix my washermachine
To check the agitator, grab hold of is and see if there is any movement, to remove , first remove the softener cap (14) by pulling, look inside, secure or remove the securing bolt (4) using a long socket extension, once undone remove the top agitator (1) then the bottom agitator (15), check the condition of the splines, refit in reverse order.
Mar 18, 2008 | Maytag PAV2300 Top Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
208 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
