Question about Pitco Frialator SG14 Deep Fryer
How do i change from nat. to lp gas and what do i need
I have a pitco 14rs trying to change from nat. to lp
  • 979 Answers
You will need a couple of things. You can get them from the LP company. It is not difficult nor is it costly. They want your business and will help you through it. I can't recall what the parts are, but I have had it done once before. Let me know how you do. Make sure you are getting the best price for LP. It should be around 1.60-1.80 per gallon.
Posted on Mar 03, 2009
Looking for the manual, also want to change from LP to NG. Need instructions for same.
To change from lp to Ng the change required is different jets in the burners Nothing more
go to a shop that sells gas cookers. B B Qs and they will have the jets in stock
ask as to adjust the air shroud to keep the air mixture right
Apr 12, 2015 | Grilling
Flames cominhg out of flue
Hi I use to repair every kind of restaurant equipment under the sun..maybe I can help...Is this a new install of the fryer and it never did this before, or did this just start do this..If a new install, the first thing I would check is the gas regulator and see if it is for Nat gas or Lp gas, and find that out..cause it has to match what you have, comming into the building..usuall the gas valve has a sticker on it that says what the water columbs are like for Nat it is like 3-6, and for Lp(propane) it is like 5-12. Ive seen customers buy a used fryer, and install a LP fryer in a Natural gas build, and the valve lets too much gas to the burners, and it will shoot flames out the top..then you would have to buy and convert a gas valve, or use parts to convert it..let me know further..
Apr 20, 2014 | Pitco Frialator SG14 Deep Fryer
Convert from lp to ng
orifice sizes will increase since goin from lp to nat gas.......to convert appliances you will need diff gas valves, nat gas and propane will have diff pressures
Dec 05, 2013 | Heating & Cooling
How do you change a change glo-warm sit 630 from natural gas to propane
You cannot do it. Their is no way. These come in 2 versions. Natural OR propane and they cannot be converted. The pilot is designated as a nat pilot assembly and the gas valve is designated a nat only valve. Their is no way to convert it not without costing a ton of money. You would need a LP gas valve and an LP pilot assembly. It would be better just to sell it to a nat gas user and get an LP one.
Jan 09, 2013 | Kitchen Ranges
Instuctions on how to change a pitco fryer from nat gas to propane
Hi there!
You need to order a gas valve conversion kit (from nat to propane), propane pilot orifice and propane burner orifice,
Gas valve conversion kit consists of a replacement spring thicker than of natural gas valve spring, gas valve cap and a sticker.
Pilot orifice for propane has smaller bore than of natural.
Burner orifice for propane has also smaller bore than of natural burner orifice (one for each burner).
You will be able to find these parts on the list of Pitco Distributor when you visit http://www.pitco.com
Regards.
Jul 08, 2012 | Pitco Frialator E24 Deep Fryer
Pilot stays lit but when you turn on temp switch pilot gets very low and burners will not light
has orifice been changed? Is this a used fryer that may have previously operated on LP gas? If so, there will be insufficient volume of gas (Nat) to the burner. Also check supply pressure at unit. Make sure supply line isn't damaged or distorted in that it may restrict flow to fryer.
Nov 19, 2010 | Pitco Frialator SG14 Deep Fryer
Want to convert heater from natual gas to lpg are jets available for this conversion.heater model no reh210ec thankyou
Dont know if you can get orvices for that heater but almost all gas appliances can be converted for nat to lp and lp to nat,they made a spud kit which is a blank orvice that you drill out your nat gas orvice to I think a 20 drill side and install the spud in and redrill to size usally a nat-gas orvice is around 8 to 10 sizes larger then a lp.The big thing is the gas valve and if it has a built in regulator or not,some valves can be conferted to open up the regulator pressure by the spring or a block off kit and others are fixed and cant be changed,have to replace valve.most nat-gas are at 3" to7" and lp is at 10".Hope this helps you
Jul 05, 2010 | Heating & Cooling
Do you have instructions on how to convert a deep fryer to LP I have a Pitco 35cs I need to convert to LP
Visit http://www.middleby.com and go to PITCO web, you will be able to locate there the nearest authorized parts dealer on your area and ask for the conversion kit (from nat to lp). The gas valve conversion kit consists of spring, cap and instruction manual. you also need to replace the burner and pilot orifice, Nat pilot and burner orifice have larger bore than lp.
Apr 06, 2010 | Pitco Frialator 35CS Deep Fryer
Lazy lighting
Check incoming gas pressure, you may also need to clean out gas orafices. make sure you have the right orafices installed(nat or LP)
Sep 10, 2009 | Pitco Frialator 35CS Deep Fryer
Pitco Frialator SG14 Deep Fryer Logo
120 people viewed this question
Top Pitco Frialator Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Paul Carew
Treefrog15
Treefrog15
Are you a Pitco Frialator Kitchen Appliances - Other Expert? Answer questions, earn points and help others
