Question about Sun Java Programming Language (cdj-275)
Error to compile java program
When i comile the program using syntex ''javac filename.java'' in Dos
a message display on screen- 'JAVAC' is not recognized is as an internal or external command, operable program or batch file.
Please give me solution.
    Scholar:
  • 136 Answers
The main cause of this error is you havent set the environment variables correctly, you can do it as follows
Right click on "My Computers" select properties the click "Environment variables" then under "User variables for pcname"
select new and add the following paths
1)var name:path
var value:C:\Java\jdk1.5\bin
2)var name:classpath
var value:C:\YourJavaCodeDirName
click ok and its done
Posted on Jun 23, 2009
    Sergeant:
  • 261 Answers
First off I assume you actually installed a JDK already before trying to compile the code. If not then you need to do that.
Secondly this error is because Windows cannot find the javac executable on your command. It could be because the JDK is missing or not installed or that Windows does not know where to look to find javac.exe from. You can simply run javac with the full path instead
ex.
"C:\Program Files (x86)\Java\jdk1.7\bin\javac" filename.java
Posted on Jan 30, 2015
U c dat u had given a proper path
C:\path=path of ur file
Posted on Mar 02, 2009
Problems changing variables on windows 7 for Java jdk1.7.0. I have no path variable any ideas thankyou
If your trying to add javac.exe to your path variable do the following
  • Right Click Computer
  • Select Properties
  • On the left select Advanced System Settings
  • Select Environment Variables
  • Under System Variables scroll down to Path
  • Append the path and exe to the Path variable
If memory serves javac.exe is located in C:\Windows\System32 so append ;C:\Windows\System32\javac.exe
Comment if you need more help
Sep 13, 2011 | Sun Computers & Internet
Java Vitual Machine Launcher prompts this message "Could not find the main class. Program will exit" How can I solve this problem? I need urgent assistance.
You need to compile the .java file you have, and run the .class file that is produced.
Open up command prompt, go to your working directory. If your file was called Hello.java: In command prompt type "javac Hello.java". Now, in the working directory, you will see a new file, Hello.class. Run that file by "java Hello.class". Hope this helps!
Thanks for using FixYa
Aug 20, 2011 | Sun Java Programming Language (cdj-275)
Ple tell me how to run the "javac" command in my laptop iam already installed the 1 6 version of java, and I set path is "C:Program Files (x86)Javajre1.6.0_16in", "java" command is exetues but java c...
javac is the JavaCompiler, You've downloaded the Java Runtime. You need to download the SDK, which includes javac.
http://java.sun.com/javaee/downloads/index.jsp
Jan 24, 2010 | Sun Java System Web Server 6.1...
Java is not working
Hello there :
first you are going to want to ensure that your your current version of java is installed correctly and is not corrupted and if it needs to be reinstalled
download the latest java version and reinstall this . www.java.com
this should be able to take care of the problem that you are having ok?
best regards michael
Aug 23, 2009 | ArcMedia JavaScript Source Code 3000 Pro...
Javac unable to compile java error or batch file?
first of all you have to set path for your jdk
have you done that???????
if not then go to youtube.com and search for that vedio.
if yes, then i think you have not named the project properly
when you are to save your project, name it in the "name of the main class.java"
for example:
class Manju
   public static void main(String arg[]s)
       ___________________________;
save it as Manju.java and then compile
no matter what other classes are being related to the project.
this much i only know
if you wanna contact me or chat with me, my email id is linushwahs@gmail.com
May 16, 2009 | Microsoft Windows XP Professional
Can anyone tell how run java program in cmd prompt???
You need to type:
If it's a program.class
java program
or of it's a program.jar
java -jar program.jar
regards
Apr 03, 2009 | Sun Java Programming Language (cdj-275)
How to run java code in cmd prompt...
javac filename.java to compile and java filename to execute
Mar 21, 2009 | Computers & Internet
JAVAC IS NOT RECOGNIGED AS AN EXTERNAL OR INTERNAL COMMAND OPERABLE PROGRAM OR BATCH FILE''
Your PC - not the calculator - printed this message. It means that the PC tried to execute the Java compiler, but couldn't find the program. Either the Java compiler is not installed, or the PATH environment variable is not set correctly.
To install the Java compiler follow the instructions for installing J2SE at java.sun.com To fix the PATH environment variable: right-click on My Computer, select Properties, select Advanced System settings, select environment variables, edit or create a new variable called PATH in the system or user settings with the path of the javac.exe program. This is often found in c:Program FilesJavain (it's in a java...bin directory somewhere)
Mar 02, 2009 | Texas Instruments TI-83 Plus Calculator
Cannot install/uninstall Java
hi,
It is not necessary to install java in order to use java.
Just download java highest version, copy and paste the java software in the system drive(eg C:,D:,....), Then set path the java file.
Example, if you have the java file in your C drive, do the following steps
1. Goto start->Run-> type command. Command prompt(black screen) will open.
2. if it shows as C:> follow the steps, else Goto step 6.
3. set path="c:\Java file name"
4. type javac
5.after typing if u find compiler then Java is installed in your system.
6. Example... if it shows as F:> and if u have saved your file in C:, do the following.
7. cd..
8. cd..
9. cd C
10 .then it appears as C:>, follow from the step 3.
thank you.
May 07, 2008 | ArcMedia JavaScript Source Code 3000 Pro...
Computers & Internet Logo
244 people viewed this question
Top Sun Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Cosma Papouis
Cosma Papouis
Are you a Sun Computer and Internet Expert? Answer questions, earn points and help others
