Question about Amana Kitchen Ranges
The oven door handle on our Amana ARH6700WW is loose, how do you tighten it?
Skill Will
  • 53 Answers
SOURCE: How do I tighten the
hi,
Remove the door from the oven, most doors you just open to the first stop point and lift up on the door, if yours doesn't let me know. Then, most doors have screws on the top and bottom, some also have them on the side, remove those screws and the front and back of the door will separate, the screws that hold the handle are in there. Remember to use caution with the glass when separating the door panels.
Posted on Apr 06, 2008
rickzilla
  • 706 Answers
SOURCE: I have a Maytage MER5775RAW electric stove and need to take the door apart
Try this website..it shows and exploded view and a parts list if you punch in your model number.. http://www.pcappliancerepair.com/model-display.php
Hope that helps...
Posted on Aug 22, 2008
aborcass
  • 2651 Answers
SOURCE: MAYTAG PERFORM OVEN DOOR,THE HANDLE IS COMING OFF.
in your user guide it explains procedure to remove the door, after emoving the door and layingit flast on conter /table ita amtter of removing sccrews holding on glass, and top trim to get to the screws that holdon hanlde, a little patience is all thats required not hard here
Posted on Mar 07, 2009
SOURCE: I have a kitchenaid electric range and the oven
My son came and pulled the door straight out not up and we were able to take it off and take it apart and tighten the handle and clean the inner glass. It now looks and works like new.
Thank you
Karen
Posted on Aug 09, 2009
  • 296 Answers
SOURCE: Handle on oven door is coming loose
can the inside skin of the door be removed by unscrewing screws?If so, this should access the screws for the handle...be sure to replace any insulation properly.
Posted on Mar 06, 2010
Oven door handle one side not attached to door other side loose
look around the outer edge of the door a few screws hold the 2 halves together caution do it on a flat surface as the glass can fall out .
Sep 01, 2016 | Neff Ovens
How to tighten loose handle
Remove the door gasket, that should give you access to removing door plate. Door handle may need to be replaced.
Oct 26, 2013 | Combi Steamer electric built in steam...
Freezer door handle loose
u could always set the handle in place where it needs to be and use caulk or super glue to go around the handle and that should help it stay in place if that doesnt work the website www.amana.com to see if it has warranty for the broken handle good luck
May 26, 2009 | Amana ABD2233DES Bottom Freezer...
Amana, model # AFD2535DES, bottom drawer freezer handle loose
sure , if you look underthe handle is there perahps a small screwhole in which you can tighten handle??this may be prior year in which case if there are no screw holes present you need to grab hold of handle and with a "brisk" pull to the right it will come off hiddenclips, the clips can be t ightened and resecure by snapping back the oppisite way the handle pullled off
Feb 12, 2009 | Amana AFD2535DES French Door Refrigerator
Bottom freezer door handle loose
There is a plastic card that you are supposed to slide under the right side of the handle. Once you have done this correctly the whole handle should slide off to the left.
Nov 14, 2008 | Amana ABB1927DE Bottom Freezer...
Loose Oven door handle
You may have to get some loctite brand paste in a tube for applying to the threads of the bolts that hold it on.
This will prevent the screws from loosening.
Another way would be to get some spring washers or star washers at your local hardware store such as menards.
Jul 02, 2008 | Smeg SE399X/5 Stainless Steel Electric...
Loose handle on fridge freezer door.
that handle is just pressure fit on the clips securing to the door. grab hold ad PULL.and i mean PULL the the right. it will snap off just make sure you really PULL it. after that you cantighten the brackets on refig and inside the handle as well
Mar 08, 2008 | Amana AFD2535DES French Door Refrigerator
I would try putting some locktite on the threads so It wont come losse anymore.
Nov 07, 2007 | Ovens
Kitchen Ranges Logo
63 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal DeAngelo
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
