Have a Hitachi Maagic Wand - head does not vibrate although it is on....
  • jayweston Feb 28, 2009
    Does not have a battery..is all-electric...head does not vibrate while unit is on and connected....
    it is not a phone..and therefore the solution is not valid.....I wish to withdraw the query as service is not acceptable, and do not charge me for it...jay weston
  • 679 Answers
First check the electric chord, for a burn or short, if that is not the problem, the connection into the handle may be burnt from rubing, after looking at a diagram, I would have to see the product as without a picture or hands on approach, it is a good guess that you will get at most. If you are handy, try to take the handle apart, and look at where the chord enters that connector that goes into the handle. I would bet that is the most likelly place for a problem like a short circuit occured. If you have access to a new line chord that would be the best way to find out. Make sure it is unplugged before you start. If it's the motor itself, you are better off with a new unit, as replacing parts usually costs more than a new unit. First you should see if it is covored by a warantee either by the manufacturer or the store from where you purchased it, best wishes
Posted on Feb 28, 2009
    Novelist:
  • 125 Answers
Does it sound like the motor is running? just the head is not moving? if the motor is not running, I would say you have a bad switch, broken wire, or possibly a bad motor. The other possibility is that the motor is ok, just the gear that drives the head portion is bad. Either way, they look like they are not super expensive, might be just as easy to get another, but it doesn't hurt to try and look/repair yourself, it's just how far do you want to go.
Hope this helps, and thank you.
    Genius:
  • 1,550 Answers
You need to disassemble the unit to fix the problem.
You are facing this problem due to a smaller spring has been unlodged from its position inside the pda .
You need to open the pda with tools like small slot head screw driver ,nose pliers etc .
Hope this helps .
  • 19,396 Answers
If the phone does not vibrate, and vibrate option is on, that means that the ******** device is broken.
To fix it there is need to disassemble and to test the contacts to ********, and eventually replace ********.
The job must be done at a repair shop, as it is quite complicate.
  • Ginko
    Ginko Feb 28, 2009
    If the unit is less than one year old, then I suggest to call Hitachi Phone number listed on the instruction.
    Hitachi will send you a replacement unit.
    Brigadier General:
  • 3,614 Answers
do removing the batter for a while, and check i again.
The small spring in the head of my hitachi magic wand is broken. How can I remove it to take it to the hardware store & replace it?
I have a doctors tool called forceps that work wonderfully for grasping small parts . check the sporting goods department at walmart .
May 27, 2015 | Health & Beauty
I fixed my hitachi magic wand, but now I cannot get the silver ring back on during the final steps of reassembly
rotate the head/neck part, one of the sides is not aligned with the notches in the bace of the neck. rotate it to fit right then you should be able to fit it on easily
Jul 16, 2011 | Hitachi Magic Wand Hv250r Hand Held...
It seems to have power going thru it..but no vibration...help
The small sping has come out of the shaft from the motor.If you open the unit you will see that the motor has a little impeller and a shaft with a slot in it. The little spring inside of the massager head is suppose to ride inside of that motor shaft with the little tab on the spring lining up in the slot. It's really flimsy and after I fixed mine it fell out again after 5 minutes of use. It needed a stiffer spring or a different way of engaging the motor shaft. I'm still working on this...
Apr 09, 2011 | Hitachi Magic Wand Hv250r Hand Held...
Vibration from my shower panel
Sounds like the pipe going to the shower head is vibrating. Not secured tightly indige the wall. That is about the only thing it could be in my opinion. Hope this helps you out .
Kurt
Mar 26, 2009 | Home
Sounds like its working, but nothing happens
I had the same problem with mine, it's due to the fact that the smaller spring has become un-lodged from the ******** itself.
You will need:
1. Roll of electrical tape.
2. Utility Knife
3. A small slot head screw driver OR a pair of needle nose pliers.
The solution is to unscrew the silver ring so that is can be moved up and down. Now, you need to use a utility knife and cut the blue rubber off of the spring. Once you have the blue rubber but off you can see a large spring with another smaller spring inside. Push the head of the ******** till the larger spring's coils are an 1/8 to 1/4 of an inch apart. Next take either the small slot head screw driver or a pair of needle nose and jam the smaller spring back into the hole in the center of the white plastic piece inside of the larger ring. Next plug it in to make sure the vibration is working, reattach the silver piece and tape the larger spring with electric tape.
Oct 25, 2008 | Hitachi Magic Wand Hv250r Hand Held...
Screw drop
Only way to find the screw will be by opening dishwasher panels and looking for it. But since there are not any electrical parts in the machine's side, you can leave the screw there and not to be worry about. Good luck!
Aug 17, 2007 | LG 24 in. LD-12BS6 Stainless Steel...
Computers & Internet Logo
David Payne
David Payne
