Question about Elna Sewing Machines
How do you thread the bobbin
I was given an elna 38 type and am having a problem with putting the bobbin in and when i try to sew anything it blocks it selve up with the thread can anyone help
    Scholar:
  • 69 Answers
When you drop the bobbin into the case, there is a slot that the thread will slide in to. Gently continue pulling on it and it will feed itself through and come out at a small cut out. Then place the thread over the bobbin and rotate the handwheel to pick up the thread. If the bobbin case is not threaded properly, the threads will knot up and jam the machine. If you'll look closely at the bobbin case, you will see that there are actually two thin pieces of metal...the thread will actually slide between those two pieces.
Posted on Mar 01, 2009
Elna 6005 - I need to move the tension dial to 9 to get an even stitch. I re-treaded the machine and bobbin and it is still the same. Any solutions?
it is common when threading a machine for the top thread to get behind the tension plates and not between them
this makes it bind up on the mount bolt and gives false tension settings
even threads also depend on the bottom thread tension which is adjustable by the tiny screw that holds the spring clip that you pass the thread under when you put the bobbin back in the case
try going google --type in-- workshop manual for elna 6005 --and see if there is a pdf version available,
Sep 06, 2015 | Elna Sewing Machines
Tip
Have you acquired an early Swiss Elna Sewing Machine??
There are still many of these Elna Supermatic sewing machines around and being used; they might not have all the electronic bells and whistles of a new model but they are a very well made solid metal case machine, parts can still be found and they will produce a good quality stitch and handle a wide range of fabric types.
Maintaining these early models means regular cleaning and oiling. Each time you get your Elna out to sew you need to remove the needle plate and open up the bobbin cover, take out the bobbin then using a little brush carefully remove all lint and fluff that you can see from the race, around the feed dogs and in the surrounding area. Your model may have marked red dots for oiling points, usually one in the middle of the bobbin holder, and often another red dot nearby in the race area. Plus a couple on the body area sometimes or top of the machine. Oil these marked points with a drop of good quality clear sewing machine oil when you get the machine out to sew, especially into the bobbin holder, then run the machine slowly without a bobbin or thread for a few seconds to spread the oil through the moving parts.
Use Swiss Elna metal bobbins only, they are very distinctive and only have holes on the top with a smooth underside and are slightly dished. Always wind the bobbin with holes on top and load it into bobbin holder same way; this way you always have the thread coming off the bobbin in the right direction.
It is important to always click the bobbin thread into the tension spring on the outside of the bobbin holder, there is usually an audible sound as you get it into tension. Just hold the thread tail with one hand and pull it around into the groove on the outside of the bobbin case, then put a finger onto the bobbin to hold it still, and push down on the thread tail with your index finger to push it down into the tension spring, you should hear it click in. Lift the thread tail vertically to check, the thread wont come out if its in fully.
Whenever you start a new seam ALWAYS hold the two threads at the back of the needle plate firmly as you start stitching until you've completed 4 or 5 stitches, to keep them clear of getting pulled back into the bobbin race. This saves those horrible jam ups happening when you start a seam.
Change your needle regularly to ensure it is sharp and use the right sized needle and type for the fabric you are sewing; these machines take the standard 130/7H needle system, and always install flat shank to the back of the needle bar.
Happy sewing on your vintage Elna.
on Oct 02, 2011 | Elna Sewing Machines
Thread from the bobbin is not getting looped
If the bobbin case rotates freely it is probable that the pinion gear is broken. Replace the gear, retime machine and voila it works again. Trouble is tough to find the gear anymore good luck it is a good machine and worth the effort
Jan 09, 2014 | Elna Sewing Machines
I can't get the bobbin thread to the to thread correctly in the machine in order to sew
try changing the needle
try rethreading the machine top & bobbin
make sure the bobbin is inserted correctly into the bobbin case, some
bobbins only go one way.
clean under the needle plate & in the bobbin area for lint & threads
May 01, 2012 | Elna Sewing Machines
How do you put a bobbin in a elna so i can use it to sew
Drop in a full bobbin with the holes side upwards (I'm assuming this is a Swiss Elna sewing Machine horizontal bobbin design as you haven't given the model number).
Now, hold the thread tail with your right hand and pulll the thread clockwise towards you while holding the bobbin still with a finger from your left hand. Bring the thread tail around towards you until it goes into the little slot, then press downwards onto the thread tail close to the bobbin until you hear it click into the tension spring. Test by lifting the thread tail upwards, it should stay in tension and not come back out of the groove.
Now close the back slide cover over the bobbin leaving the bobbin thread tail visible out to the right.
Now manually turn the flywheel towards you while holding the top thread tail and take the needle down into the bobbin holder area and back to the top, pull the thread tail to bring the bobbin thread up to the top.
There is a threading up diagrams at www.sewusa.com http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Elna_Sewing_machine_threading/Elna_Supermatic_threading_diagram.htm
for the old Supermatic but the bobbin holder design is almost identical for all the subsequent models such as the SU, TSP, Supermatic or Air Electronics like the Stella, Carina or Jubilee, the above is the same for all.
Sep 19, 2011 | Elna Sewing Machines
My elna sewing machine bobbin won't spin on top to wind thread around. The fly wheel spins though...I've been putting thread on the bobbins by hand.
If the fly wheel is going around then the clutch isn't disengaged to wind the bobbin, you need to pull out the flywheel on your model to disengage the clutch for bobbin winding.
Take thread from thread spool across to bobbin winder thread guide, then back to bobbin and thread the tail through the hole on top of the bobbin. Place bobbin onto spindle on top of machine and then push it against the stop to engage the bobbin winding motor. HOld the thread tail up and start winding slowly until the bobbin core has been covered including the starting point. Stop and trim off the thread tail with scissors. COntinue winding bobbin and give the thread a nudge if needed to wind evening top middle and bottom of the bobbin. A good smooth wind is important. Also don't wind at full speed and keep an eye on the thread reel that the thread is coming off, you don't want it bouncing around as this will **** the thread and stretch then relax it affecting your bobbin wind.
Obviously if you know this and the bobbin winding mechanisim is just not working, then it will need a service/replacement by an Elna repair person.
Aug 01, 2011 | Elna 2007 Mechanical Sewing Machine
On my elna supermatic 722010 sewing machine, the thread makes the bobbin pop out and the thread get tangled underneath. I have had it fixed twice, which is expensive. Should I just get rid of it and buy...
not unless you can find another swiss elna, like star series su. check bobbin in right way, holes on top to wind and load. you havent bought anothet type bobbin??? go to www.arizonaexpressionz.com and download a manual for supermatic. then read bobbin winding and threading carefully and rewinf bobbin and thread up again. make sure thread goes into tension spring all the way. bobbin should turn anticlockwise when yoou pull thread. also please brush clean bobbin holder area and check for any threads caught there. now a drop of quality clear machine oil in middle hole and gently run for 30secs to work in. do this every time you get your machine out. there are several oiling points shown in manual. oil them. these machines are quality but yours may need love tlc from a elna tech especially if it has not been serviced in a while. but a well maintained elna will out stitch a new plastic machine any day in my humble opinion. if you want to join yahoo group elna heirlooms, experts who service their own and share photos info manuals and love these vintage classics.
Jun 16, 2011 | Elna Sewing Machines
I was sewing a straight seam and all of a sudden the thread wouldn't pick up the bobbin thread anymore. Now I can't sew and have much to sew for a wedding in 5 days. Can I fix this myself? When I turn the...
If you can hear a click then I'd say the needle is touching some part of the hook mechanics which could mean timing is out. However, it is possible that the bobbin case has just moved a little so as first trouble shooting steps, I'd suggest the following:
clean out the bobbin holder area as per manual (ie. remove the needle plate, bobbin, sewing foot and needle, take out the bobbin holder, clean the race area out, then put bobbin holder back in as per your manual, there is usually a stopper and knob or two red marks to line up. This is held by a magnet so it is possible to knock it out of place during a jam up.
Replace needle plate, bobbin, sewing foot and put in a new sharp needle, flat shank to the back and make sure it is fully up into the holder, thread up and very slowly using the needle up and down button, test sew a couple of stitches again.
If no stitch formation or you can definitely hear/see something touching then I'd say timing is out and no, its not something fixed yourself; best left to a trained technician.
Apr 11, 2011 | Elna Quilter's Dream 6003Q
I have for gotten how to make the machine sew and im having trouble threading a bobbin for my moms machine elna 7000 i need a manual or a quick note to get started
YOu can down load a manual from here http://www.arizonaexpressionz.com/elna_instruction_manuals/Elna7000.pdf
Just remember to click the bobbin thread into the tension device correctly and hold the two threads behind the pressure foot when you start each seam - Elna top loading bobbins give great stitch quality but you just need to keep stray threads out or they'll jam up.
Also, you must use the Elna plastic bobbin that the manual specifies for this machine - the 5000, 7000 and 9000 were Elna Tavaro Switzerland's first foray into computerised machines and first released in 1986.
Also, please check the manual when you go to buy twin needles, there are two types now as computerised machines usually need the twin needles offset from the shaft position. They have red or black plastic block between the shaft and the twin needles - I think you need the red ones but just double check the manual to make sure. And you can't do all the wide stitches with a twin needle as it will strike the foot.
Hope this helps a little.
Jan 16, 2011 | Elna 2007 Mechanical Sewing Machine
How to thread bobbin on Elna SU
Please describe the type of bobbin you have. Is it held inside of a removable metal casing? Or is it a dropin type? Is the sewing machine what is known as a "freearm" which you can put a sleeve or trouserleg over or is it a flatbed type? When I know this I can help you further.(I used to sell sewing machines).
Jun 11, 2009 | Elna Sewing Machines
Sewing Machines Logo
222 people viewed this question
Top Elna Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
