Question about Zenith P42W46X 42 in. Plasma EDTV
I have a zenith 42'' p42w46x picture problem
I have look for any obvious bad caps, found none! I have removed all boards and checked for cold solder joints. also clean dust off all ribbon connection, and reseated them. Sound is working fine!
Picture symptoms:
1) I have tried multiple inputs (vga, a/v, coaxial, s-video), with no change to picture. to me this rules out signal boards, as both failing would be odd?
2) if a source is plug in, the screen symptoms are different then when no source is plugged in. When source is plugged into screen, it is full screen and static with odd color patterns. when source ia unplugged screen changes to a black screen, excepted for a 7'' wide colored vertical bar (with some flickering) that randomly jumps around the screen.
3) My thought would be the main unit board (my experience is with lcd), but have read a lot that the y-sus and z-sus seem to fail???
Thanks for helping, in advance!!!!
  • 5 more comments
  • javswr
    javswr Feb 28, 2009
    Tv has been reset many times!!
  • javswr
    javswr Feb 28, 2009
    Thanks, I am looking for more then a might be. Regarding the z-sus and y-sus boards.
  • javswr
    javswr Feb 28, 2009
    IC stand for what?
  • javswr
    javswr Feb 28, 2009
    I do not have any schematics, for board trouble shooting.
  • javswr
    javswr Feb 28, 2009
    shopjimmy I have used as well as having manual zone bookmarked.
    Any idea's on which board I should focus on?
  • javswr
    javswr Feb 28, 2009
    what does y-sus board do and what does z-sus board do?
  • javswr
    javswr Feb 28, 2009
    Thanks for the input, this gives me a direction!
    Scholar:
  • 165 Answers
The 'panel' is what you look at or from the back the 'big' silver thing all the boards are mounted on. There should be a white sticker with the VS/VA voltage. In your case it would be the YDRVTP, YSUS, ZSUS, or the Y drive board which may or may not come on the Y sustain, Y sustain and Z sustain. But going back to the fact the Z sustain is bigger than the Y sustain which means the Z sustain does the majority of the processing, and the fuse is popped on the Y sustain, you need the Y sustain, Y driver, and Z sustain. Look at the plugs and check your VS/VA. You can also disconnect the sustain boards and read the voltages.
Posted on Feb 28, 2009
    Scholar:
  • 85 Answers
On y sus board.you focus on.
if its the case of picture problem then only.
  • 10,594 Answers
Do you have related service manual to test boards input / output voltage and signal?
I would recommend to test suspected boards in working same model TV to narrow down problem area. After confirmation of defective board, you can go ahead for component level repair or replace complete board.
  • 2 more comments
  • Shahid Electronics
    Shahid Electronics Feb 28, 2009
    Manual Zone for service manual and Shop Jimmy for board purchase.
    You should have schematics for trouble shooting because you are dealing with high tech TV.
    Service manual would help you to rectify problem area.
    y-sus and then z-sus to test.
    z-sus / y-sus receive the signals from DIF (Digital InterFace) and high voltage supply and output scanning waveform for Module.
    Sergeant:
  • 326 Answers
Its rare but in your case the board is faulty thats not possible.its just the ic on the main board supporting got faulty.get it checked at local repair center.its definately ic fault its gone weak or completely faulty.
  • 479 Answers
In case of CRT tvs and monitors definitely y sus and zseems are having the important role but dependenty if u are geetin no picture at all then this the boards issue and if picture is distorted one sided or shaking in one side then this might be issue with the Y-SUS and Z-SUS as well.
    Sniper:
  • 113 Answers
try to reset your TV.
unplug the TV for 30 minuts and check again.
Good Luck!!!
neo
42 in lcd zenith turns itself off
had a very similar situation with my Phillips 42 in. LCD TV.
Here was my Problem. The Power Supply Board. I opened it up( Warranty was Expired) and found several faulty capacitors on the PSB. Its pretty common. Major Electronic companies were sold faulty capacitors that fail in 2-5 years instead of 10-20 due to a lack of preservatives. It wouldn't surprise me if you have the same problem. TV will work fine for a few years and then just fail completely or slowly deteriorate.
Here are the solutions
1. Have it Repaired
2. Check for faulty caps and if you find some(budged or leaking) you know you have located a problem
Remove the board and replace the whole thing.
3. If you have some soldering skills you can replace the faulty caps.
Caps are very inexpensive, under a dollar in most cases. I replaced 4 for about $5.00
Hope this Helps.
Good Luck
Aug 19, 2010 | Zenith P42W46X 42 in. Plasma EDTV
I have no picture but i have sound any suggestions
Replace 6870QZE013C or 6871QYH053A (more likely).
The second is the Y-Sustain board, located to the left of your TV when looking from the back.
This is the one that usually burns and the fuse on it is likely shorted. Do not replace it, it will burn again.
Feb 04, 2010 | Zenith P42W46X 42 in. Plasma EDTV
Multiple vertical lines on screen.
Hi I am Vortash Although this is trademarked as a Zenith the manufacturer of this set is LG and the prefix P42W46X is one of their set product numbers and is actually one of their RU-42W46X 10/11/12 -series televisions . The problem you are describing may be either incorrect display setting or incorrect picture fomat letterbox .. 4.3 pan or 16.9 widescreen I am guessing you do not have the manual for this set and I have found one on this site http://www.safemanuals.com under the LG P46W46X prefix FREE it may help you to solve this.
Another problem it may be is a power supply fault , components under heat conditions cann change value and restrict power flow causing many different faults this is particuarly true of semiconductors prior to failiure ..Try adjusting the set according to the manual and if this does not cure the problem I am afraid you are going to have to get the set looked at by an engineer . Regards Vortash
May 27, 2009 | Zenith P42W46X 42 in. Plasma EDTV
42 zenith plasma picture cutting in and out with good sound.
if you feel the tv is worth fixing id say get it fixed.anyone that comes out to you is going to charge a bit more and it sounds like he knows what hes talking about...
Jan 19, 2009 | Zenith P42W46X 42 in. Plasma EDTV
Zenith P42W46X - no picture
if the lines covered the entiire screen, fist I would check to see if the TV's menu can be seen. If not then check the buffer boards. Next I would check the logic board
Jan 09, 2009 | Zenith P42W46X 42 in. Plasma EDTV
I have a 50" zenith 10 months i can hear how can i fix this
If the unit is only 10 months old, it should still be under manufacturer's warranty. Call and request warranty service. DO NOT open up the unit as that would void the warranty.
Keep us posted on what is found.
Thanks,
Dan
Aug 20, 2008 | Zenith P42W46X 42 in. Plasma EDTV
Zenith P42W46X 42 inch EDTV
common problems with these, usually customers here a loud pop. then the screen goes blank. I would try...
Some of these have a 4 pin test on the control board that you can jump with solder to get test pattern. If you get it to do that then these boards maybe good and would replace the control board. if nothing happens, then
the upper & lower drive also the Ysus and Zsus boards all at the same time.
last could be a defective panel.
hope this helps. p/n are on all the boards.
Jul 22, 2008 | Zenith P42W46X 42 in. Plasma EDTV
P42W46X Zenith Plasma - No Picture - Mostly Yellow on screen
Mine looks like too, but the line running across isn't on my set, picture looks like this, and the sound works fine. I took the tuner board all the way out and turned the set on and it did the same thing, then I unplugged the top wire on the board next to the tuner board and the screen went black. plugged it back in and the screen came back with the scrambled picture. Anyone know why? Bad mainboard maybe? the left of the tuner board?
Nov 25, 2007 | Zenith P42W46X 42 in. Plasma EDTV
Zenith 42" plasma p42w46x
I have just had the same problem. It affects both the component inputs but the A/V inputs are OK. If I disconnect the green input, the screen goes black and displays "No signal." Service guy came out and said the Y-board needed replacing. Haven't done this yet
Sep 01, 2007 | Zenith P42W46X 42 in. Plasma EDTV
Zenith P42W46X 42 in. Plasma EDTV Logo
348 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
