Question about Kitchen Ranges
My Jenn Air Convection Gas-Electric grill range model SVD48600 is electrically dead. Non of the buttons work on the switch membrane and the electric clock has no power. Circuit braker was checked and is fine. I replace the switch membrane 10 years ago. But I was able to read function error codes on the clock panel. Now I can't do that. I don't want to buy all of the parts unnecessarily. How do you troubleshoot?
  • john_diring Mar 01, 2009
    There is no fuse in the Oven. The clock was fading before it went dead.
    Top Expert:
  • Kitchen Ranges Master
  • 67,757 Answers
The main circuit board which controls system voltage is burned out, treplace the main board and check all connections to that board.
Posted on Mar 01, 2009
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Your described problem indicates that the low voltage supply of the SVD48600 is electrically dead. This low voltage supply converts the house voltage to usable DC voltages that the internal electronics uses. In most models (I believe including SVD48600s), the low voltage is achieved with the use of a small transformer, diodes and capacitors. Absence of the low voltage is indicated by no display/clock, non-functional electrical triggers and switches, sensors and everything electrical (as in your case). Unfortunately, the transformer and its attendant parts are integrated with the logic controller/relay board hence an entire assembly replacement is required.
Would appreciate updates on any developments. Good luck and thank you for using FixYa.
Posted on Feb 28, 2009
  • 564 Answers
Hope This Helps!!!  Please Don't Forget to Rate my Response!!! Thanks!!!
PREM
  • 3,037 Answers
Well, do you have a voltmeter? If so, then check the voltage at all of the main junctions. At the power supply for one inside the unit. and at the main circuit board. The main board is probably fried and possibly there is a fuse that could have blown but I don't know why one would have.
Benjamin
    Genius:
  • 1,550 Answers
First check the fuse in the oven .
  • SAM ANDERSON Mar 02, 2009
    The fuse is located inside the cover of the microwave oven.Check that .
    Also you could have a wiring failure or a failed electronic oven control board in the range.
    Check the continuity of wiring from the board to other parts .
Jenn-Air model svd48600. Gas stove top, electric oven. Why would the exhaust fan turn itself on whe either of the left burners is lit.
The switch for the optional grill attachment is activating...pull the tray/pan on the left side that holds the two burner grates toward the front...it should shut off. To correct the problem permanently, you'll need to adjust the position of the switch. The switch gets lose over time and slides on its mount until it gets out of range. The purpose of the switch is to activate the blower continuously when using the optional grill accessory. When you remove the left-side grates and the tray/pan the grates set in...you'll notice a protruding piece of metal on the front of tray/pan that fits into a hole in the cavity where the tray sits. Inside that hole is the switch that is out of position. Getting at the switch to adjust its position is not difficult, but you need to remove the upper front panel...KLS
Dec 13, 2009 | Jenn-Air Kitchen Ranges
Jenn-air electric range model JES9800AAB some kypad # not working
Unless they start working again after it has a chance to dry out the touch panel will have to be replaced. This happens when excess moisture gets between the very thin layers of the membrane.
eric
Jul 03, 2009 | Jenn-Air JES9800A Electric Kitchen Range
I am having a hard time trying to find new oven racks for a Jenn-Air gas electric grill range model #: svd48600. Have any ideas where I can find them?
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=svd48600
click this link, then choose your model, then on the left side under select diagram scroll down to # 7 oven, and presto.
Dec 04, 2008 | Kitchen Ranges
Error code
I have a jenn air range gas cooktop electric oven model # svd48600b the convection fan will not turn off and when you attenpt to use oven an error code F-3 appears and beeping sound what part is defective?
Aug 02, 2008 | Jenn-Air JES9800A Electric Kitchen Range
Jenn-Air Gas-Electric Grill Ranfe with Convection Oven M# SVD48600
if possible, squat down in front of the range and put your ear as close to the bottom of the control panel/top of the door when you close it. there is a small motor that pulls the door in when you use the self-cleaning function. perhaps that motor is running all the time? its quite, more of a humm. this could explain why its locking itself. other than that, my convection oven JennAir has a small fan in the back that runs when the oven is on, regular or convections mode. you can see this fan squirel cage in the back wall of the oven. if you were to pull the range out, you will notice (atleast on mine) that there is another much smaller fan on the backside of the range behind the removable metal panel. what the smaller fan is for, i have no idea. so there are two fans, plus if you have the down draft feature, thats 3 total. hope this helps somehow.
Jun 21, 2008 | Jenn-Air JES9860 Electric Kitchen Range
Jenn-air gas electric grill range
any power to unit at all?? clear, start, clean ,button?? what happens when you push them??? clock on?what happens when you try to set to clean again??? it should activate hte door lock latch at which point cancel and it should reset itself. with any luck! what happened thankgiving how was it fixed
Mar 14, 2008 | Kitchen Ranges
Don't know if the oven part of range is gas or electric
open the door on the left side low down you will find the model and serial number .
Visit the jenn-air website @ www.jennair.com or click
https://www.jennair.com/customer_care/contact_us.jsp
to email them and they can tell from the serial number and mail you back...
Nov 15, 2007 | GE JBP68 CleanDesign Electric Kitchen...
Kitchen Ranges Logo
143 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
