Question about Gaggia Classic Espresso Machine
Steam not working
On my baby gaggia the steam is not functioning at all.  The espresso maker works fine, but when I push the steam button nothing happens, doesn't even make a sound.  Is it the fuse?
    Novelist:
  • 137 Answers
I dont know your location, but you can check this sites mentioned above:
www.oemmeci.it
www.nuovaricambi.it
or you can check in car parts shops at your location, you should look at parts> sealings for brake pipes.... you request the sealing from rubber named VITON or SILICON.
Posted on Mar 28, 2009
We have a 4 month old gaggia titanium. Today, the steam wand stopped working. (It makes coffee just fine.) I've cleaned the steam wand. When I turn the steam dial, very little steam comes out and I hear a...
Sounds like the steam wand is getting blocked some where either at the metal end or in the parnello wand if you machine has one at the end of the steam wand, if both of those are clean then try this push in on the steam knob if that works then tap rod assemble or steam valve needs to be replaced, make sure to ask about the stainless steel valve instead of the plastic one.
Oct 06, 2010 | Gaggia Titanium Espresso Machine
Gaggia baby espresso machine-Steam button is stuck
The only thing that comes to mind is that the machine is in steam/hot water mode. Unless you replace the switch and turn off the steam light so that it sends the water to the correct location. Also you might want to remove the shower screen and make sure it is clean.
Nov 26, 2009 | Gaggia Baby Espresso Machine
Gaggia baby espresso machine - water comes out of steam wand but not group head. tried priming, cleaning
Remove shower and screw, then run brew button, if that works clean shower, if not remove allen wrench screws and clean diffuser and valve on spirng.
Oct 21, 2009 | Gaggia Baby Espresso Machine
Gaggia baby 18 momths old water coming through steam bit but no water coming through coffe bit any suggestions libby
HI
If you have a pre-grind button on your machine, push it but don't put any coffee in the brew unit. Push any of the coffee buttons, and see if water will come out then. If it does not, then you have a plugged brew unit and the brew head needs cleaning. I have directions for cleaning.
Jul 13, 2009 | Gaggia Syncrony Compact Coffee...
Baby gaggia steamer doesn't work
Does the machine brew hot coffee? If yes, then remove the parnello and clean the holes at the end of the steam wand. If that does not solve problem, then it is blocked where valve is connected to boiler, Try descaling machine. If no then the thermostat on the boiler has tripped and needs to be reset.
Jun 06, 2009 | Gaggia Baby Espresso Machine
Gaggia Classic Espresso Machine Logo
179 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
