Question about Toshiba DVD Player
Toshiba DVD player is stuck on ''loading'' and will not play
The player turns on and opens the tray, but will not play any disc I insert. It just stays on loading.
SOURCE: Toshiba SD-3980
read that
Posted on Mar 23, 2008
it is the internal lazer light. if you communicate with coby they will fix it . it seems to happen quit often ed
Posted on Feb 02, 2007
SOURCE: Toshiba DVD SD-3980SU2 or SC2 player loads every disc as "bad disc"
Toshiba says:
Information for Owners of Toshiba SD-3980 and SD-K750 DVD Players spacer.gif To ensure the satisfaction of our customers and to maintain the integrity and quality of our products, Toshiba America Consumer Products, L.L.C. is issuing an important product update. This is not a safety issue.
Toshiba is committed to customer service and to continuously improving the quality of its products. It has come to our attention that certain DVD players bearing the model numbers SD-3980 and SD-K750 may at some point in their life stop playing discs due to a component part failure. In such case, the error message "bad" will be shown on the unit's display. Affected units will have "SU2" at the end of the model name (e.g., SD-3980-SU2), which can be found on the back of the unit.
If you own either of these models and experience the issue described above, please contact Toshiba Customer Solutions at 1-800-631-3811 for information on how to obtain a replacement unit.
Posted on Jan 18, 2009
  • 59 Answers
SOURCE: DVD stuck in DVD player will not eject
I just fixed one of this exact model SD-V392SU with same problem. This takes a bit of manual dexterity, but it can be done with some care and patience.
There is a small plastic nylon gear on the shaft of a miniature motor in the DVD mechanism. This gear is likely floating loose in the machine. It is what connects the motor's shaft to the rest of the mechanism to operate all it's functions which include opening and closing the tray and raising and lowering the laser and spindle motor that spins the disks. Be careful not to lose it once the lid is removed from the unit. It is quite small.
Unplug the unit and use a well lit area to work in such as the kitchen table covered with a large towel to protect the unit and the table.
There are 5 Philips head screws holding the lid on. One each side and 3 in the back. Remove those paying attention to where they come from. There is a subtle difference in the lengths of the screws. I use empty prescription bottles to keep things sorted when I work.
The lid can be removed by sliding it slightly backwards and tilting the rear of the cover upwards and back. Once the lid is off the unit, you must locate the small white nylon gear that has come off the shaft of the miniature motor that drives the mechanism. A good tip is to lay out a dark colored large towel to shake and dump the loose gear out and onto so you can more easily see it's white color.
There are 2 flat ribbon connectors and one 3pin mini molex connector connecting the DVD mechanism to the main board of the unit. Grasp the cables as close to the connector as you can get.and gently disconnect these by carefully pulling them out. All three are different, so you can't mix them up to put them back.
There are four screws holding the black plastic mechanism in the unit. One long shoulder style screw at the rear center of the mechanism, and three short screws with captive washers. Two of the three short ones are located one on each side of the mechanism towards the front face of the unit and one near the right hand side about three quarters of the way to the rear of the mechanism. A magnetized Number 2 Philips is the best tool for removing and replacing these screws as the two short front screws must be removed from rather tight quarters in the recesses of the unit. The magnet holds the screws on the tip so you can raise and lower them into position while removing and replacing them.
Once the three connectors and four screws are removed, you can lift the rear of the mechanism slightly and tilt the mechanism out of the unit. Once again, keep a sharp eye out for the loose little white gear.
Now that you have the mechanism out of the unit, you can manually eject the captive DVD.
First a little about how this mechanism works.
Look at the front face of the mechanism. You will see a white actuator bar that slides left and right. This is what raises and lowers the laser/spindle assembly. When the mechanism motor spins, connecting gears move this bar raising the laser/spindle motor assembly up. This causes the disk to be clamped against the top of the drive in play mode so the spindle motor can rotate the disk for the laser to read, The disk tray is basically locked when in this position and it can not slide out to give you the disk.
With the gear missing from the mechanism's motor, it will be possible to move that white actuator bar that raises and lowers the laser/spindle motor assembly. Note that there is a switch with three wires on it located on about front face center that is operated by that white bar. This switch tells the mechanism motor when it is loaded and unloaded so the motor knows when to stop spinning as it loads and unloads. Once the bar lowers the laser/spindle, the tray should be able to be coaxed out. Looking at the bottom of the mechanism, you may be able to spot the gear so you can assist the mechanism's white actuator bar, but with the motor's gear missing, the other gears can spin freely.
Once you have your disk out and you have found that little white gear, you can begin the actual repair of the mechanism.
Looking at the bottom of the mechanism, you can see the bottom of the motor the little white gear came off of. This is NOT the spindle motor that spins your DVD's Once you know where that motor is, you can imagine where the shaft of it will appear on the top. Viewing the top of the mechanism, there is a combination of gears that that little gear drives and you should be able to find the motors bare shaft pointing up. This, of course, is where that little white gear belongs.
Now there is two ways to put the gear back on the shaft. I removed the two other gears this one meshes with so I had a little more wiggle room. The other way, of course is to leave the other gears in the way. This makes replacing the small gear more difficult as there is less room for error in placing the gear.
The gear closest to the front of the mechanism has a plastic hook that can be very slightly moved aside to allow that gear to come off it's shaft. Note the difference between the top and bottom of these gears so you know which way they go back on. Once the one with the hook holding it on is off, the other one can just slide off it's axle as it is held in place by the first gear you took off.
I used some Q-tips and alcohol to clean the shaft of the motor and the inside center of the little gear. Then I used a poor man's bearing mount (clear nail polish) and a plastic tooth flossing tool to apply a very thin coating to the inside of the gear and a Q-tip for coating the outside of the shaft to help keep the gear from coming off again. This must be very carefully applied as you don't want any excess nail polish running down the shaft of the motor and getting in the bearings of the motor. There is a special fluid called bearing mount for fixing pulleys and gears on shafts, but I didn't have any of it or the commercially available thread lock. Bearing mount is basically just very thin, watery thread lock like fluid.
I used the small pick end of the tooth flossing tool to position the gear over the motor's shaft and then pressed it back on using a small screwdriver. The gear is very light, so the tackiness of the nail polish was enough to hold it to the tooth pick's curved pick end. Give the nail polish at least an hour to dry before attempting to move the mechanism. Now that the gear is in place, things can't free wheel any more and you don't want to stress the gear before the polish has had a chance to dry.
Once the gear is pressed back on the shaft of the motor, you put the other two gears back where they came from and it's ready to go back in the unit.
Tilt the front of the mechanism down slightly as you slip it back into position. Note that the back end of the mechanism has a small recess where the rear supporting post fits into. All the holes for the screws should be lined up before you start putting them back in. A good tip is that I always turn the screw counterclockwise or reverse after placing it in the hole and wait for it to thump or click down again before turning it clockwise in. That way I know the screw is seating properly and won't cross thread. It turns back in very easily or I reverse again.
Hold the ribbon cables as close to the end as you can as you put them back in their sockets. There is a small amount of reinforcement near the ends of the ribbons to assist in plugging them back in. Otherwise, it's like shooting pool with a rope. :o)
Replace the lid with the rear of it tilted up and slide the front under the face of the front bezel. Everything should fit nicely and the screw holes should all line up. If it doesn't, you've got it wrong, try again.
That's about it. I hope this helps.
Posted on Feb 22, 2009
  • 5603 Answers
SOURCE: My DVD player stays stuck on loading. How can I
If all DVD's you try act the same, I would clean the read head. If that doesn't work, then drive needs to be serviced. Hopefully nobody smked cigarettes near the unit as that coats the optics. Clean the read head VERY carefully with a Q tip and 99% isoprophyl alcohol. Ensure that no fibers get stuck around the read head... it is VERY fragile.
If only one disk won't finish loading, then the disk itself is probably bad and the drive is OK.
Posted on Jan 03, 2010
Testimonial: "Very helpful. We had a small kitchen fire that put out a lot of smoke, so that was probably the problem"
How unlock a Toshiba sdv398kc dvd?
Toshiba SD1200 / SD1600 / SD1700 / SD210E / SD2109 / SD2150 / SD220E / SD2800 / SD3750
  1. Insert DVD with foreign region code
  2. Wait for the error message to appear
  3. Press M (Memory)
  4. Press 1
  5. Press PLAY
Toshiba SD120E / SD125E / SD220E
  1. Get the multi-region update disc for the SD220E (
  2. Write it in DAO mode
  3. Switch on DVD Player
  4. Press SETUP
  5. Under the Picture option change Pal/Auto setting to Auto
  6. Press SETUP
  7. Insert the update CD
  8. The following images are displayed: ?'Nabe the Wiz?' and then ?'FIN?'
  9. Remove CD
  10. Switch DVD Player On/Off
Toshiba SD240 / SD350E / SD3960 / SD3980
  1. Open the disc tray
  2. Press 2, 4, 0, 3, 9, 6, 0
  3. Select region using ENTER (9 = multi-region)
  4. Close the disc tray
  5. Power off
Toshiba SD3109
  2. Insert foreign DVD
  3. Close the disc tray
  4. Press STOP before the error message is displayed
  5. Press "T" twice
  6. Enter a time of one second
  7. Press PLAY
Toshiba SD43HK
  1. Turn on the player (without a disc inserted)
  2. Press ENTER
  3. Press 8, 4, 2, 6, 9
  4. Press ENTER
  5. If the player doesn't turn off automatically, turn it off
Toshiba 23HLV84 / SD-24 VLSL / D-KR2 / D-R1 / D-R2 / D-R255 / D-R4 / D-VR30 / D-VR4 / MD13N1 / MD13N3 / MD13P3 / MD14FN1 / MD20FM1 / MD20FN1 / MD20FP1 / MD20P1 / MD9DM1 / MD9DP1 / MW20FM1 / MW20FN1 / MW20FP1 / MW20FP3 / MW24FM1 / MW24FN3 / MW24FP3 / RD-X2 / RD-XS34 / RDXS30 / RDXS32 / RDXS52 / RSTX20 / RSTX60 / SD1008 / SD100X / SD106E / SD114E / SD1209 / SD1209 / SD114E / SD1209 / SD1300 / SD130E / SD1402 / SD140E / SD145E / SD1850 / SD1900 / SD2006 / SD2008 / SD2108 / SD214E / SD22VE / SD22VL / SD245 / SD248E / SD24VB / SD250E / SD2600 / SD2650 / SD2710 / SD2715 / SD2805 / SD2810 / SD2815 / SD2850 / SD320V / SD324ES / SD34VL / SD35VF / SD36VESE / SD3860 / SD400V / SD412V / SD4205 / SD44HK / SD4960 / SD500E / SD5205T / SD5907 / SD5915 / SD5980 / SD6915 / SD9100 / SDH400 / SDK200 / SDK220 / SDK330 / SDK350 / SDK530 / SDK730 / SDK740 / SDK750 / SDP1000 / SDP1400 / SDP1500 / SDP1600 / SDP2500 / SDP2600 / SDV290 / SDV291 / SDV390 / SDV391 / SDV395 / SDV396 / SDV593 / SDV65HT / VTD1420 / VTD1431 / VTW2185
Dec 17, 2016 | Toshiba Televison & Video
Hyundai 320-A dvd player codes
Hyundai DVD-320A / DVD-360A / DVR-510C
  1. Method 1:
  2. Turn on the player (without a disc inserted)
  3. Press 7, 7, 0
  1. Method 2:
  3. Press 7, 7, PLAY
  4. Select region (0 = multi-region)
  5. Press SETUP
  1. Method 3:
  2. Open the disc tray
  3. Press 3, 8, 0, 0
  4. Select RC (0=codefree)
  5. Press SETUP
  6. Close the disc tray
Apr 20, 2016 | Hyundai Televison & Video
My dvd player tray does'nt open when it should and when i insert a disc to play, it only plays for a few seconds then it stops but the disc continues to spin
The laser pickup unit of your DVD player may either be faulty or dusty. Just put in a cleaning disc into it and play it for at least three times, and check. If it does not help you, the laser pickup unit of your device should be replaced with same type and number. Just check the loading belt too. OK.
Dec 16, 2011 | Zenith XBV443 DVD Player/VCR
DVD w ill not eject from my Toshiba DVD player...Screen says open but the door never does
You will have to change the loading tray drive belt. For which you have to remove the top cover and then unscrew 4 screws that hold the disc mechanism and turn it upside down.You will see a small belt on a pulley which has to be replaced. Do all this only if you have access to replacement belt. In some players if you look at the bottom under the drive mechanism you will find a ****. Insert a thin screwdriver and push a plastic lever in the direction indicated with an arrow. The loading tray will eject the disc. Only some models have this feature. You have not mentioned the model # of your player.
Aug 08, 2011 | Toshiba DVD Recorder
Does not play when disc entered nor when play is selected. (XD-E500KB)
Push in the plug connected to the "Video Out" jack on the rear of the Dvd to ensure it is connected firmly. Check the connection at the back of the TV as well.
Press the "Source" or "Input" button on the TV remote to verify the television's input is set to the DVD connection.
Press the "open/close" button on the front of the DVD to open the disc tray. Insert and test different DVDs to determine if the problem is with a specific disc, or if the player will not operate.
Eject the DVD tray and insert the DVD laser lens cleaner. Close the tray and wait a few seconds for the cleaning disc to load. Press "Play" on the front control panel to spin the disc through the cleaning cycle.
Remove the cleaning disc, insert a DVD and test playback operation. If the machine still will not play discs, the main receiver unit may require internal repairs best left to an experienced technician.
Feb 02, 2011 | Toshiba Televison & Video
Toshiba DVD player doesn't retract or load media. DVD carrier is stuck in the out position
There is a rubber band on the motor that opens the tray out to load the disc, somehow that must of slip off the motor. Or the motor itself went bad.
Oct 11, 2009 | Toshiba SD-5700 DVD Player
Toshiba sd 4800 dvd plater not opening and playing
There is a small belt that has become worn or has broken. Open the DVD palyer, press the open key push on the silver disc, the tray will open, . On the tray pul the two tabs up gently, remove tray. Belt is located there
Oct 04, 2009 | Toshiba SD-4800 DVD Player
How do you put on a dvd?!
i take it all set up the dvd to tv.?
turn on the dvd player with the remote .
press open on the remote
insert the disc dvd out of the box
close tray
press play to watch dvd
when finished
press open take out disc and close disc tray and turn off dvd player .
May 24, 2008 | ASUS DRW-1608P2S DVD RW Dual Layer Burner
Dvd video player
Your DVD player is having a problem reading the disc. This is what is accounting for the pausing and the slow loading times...especially if it plays other movies without hitches. Even if the DVD is cleaned, some scratching on the disc will prevent it from being viewed properly. Blockbuster shoudl give you another disc to try of the same movie if you ask. Also, you can try getting a cleaner for your DVD player to remove dust and help it read discs better.
Dec 26, 2007 | Toshiba SD-3980 DVD Player
Toshiba DVD Player Logo
683 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
