Question about Mitsubishi WS-55807 TV
Mitsubishi WS-55807 Won't Turn On
TV was working when I left the room; came back and it was off - I could hear clicking (like you hear when you would normally power it on/off), but the tv wouldn't come on. I unplugged and plugged back in and the green light on the front control panel would flash a few times then quit, and the clicking occured again. I left the tv unplugged all night, plugged back in today, and the green light flashed rapidly for a few seconds, I heard the clicking again, it stopped, and now I can't get it to respond at all by unplugging and plugging back in.
What's wrong, and is it worth fixing? This HD-ready tv is 6-7 years old...is it time to toss away and get a new HD plama or LCD?
  • Mitsubishi Master
  • 19,396 Answers
The TV is on protect mode. The clicking sound is the protection switchthat keep turning the TV off to prevent further damage, this happenswhen a fault had been detected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Alsoensure that the fault is not coming from a faulty receiver box sendingbad signal, check if you get same problem with no receiver boxor dvd connected.
If that does not work, and you keep having a flashingled on front of the TV, and tv turning off by itself after a while,that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1Theinternal circuits are jammed because of electrostaticcharges accumulating on capacitors, or because of a wrong voltage readby the main chip on your monitor controller board. this started theprotection circuit.
2 The protection circuit detected a wrongvoltage or abroken contact, identified an internal fault and kicked in, startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faultsthat can occur are a blown capacitor on power board, aconvergence IC has blown, or a fault on Digital board.
Check alsothe video cable or any external connection cable, if the cable is shorting, or the connector is bad, youcan get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
Posted on May 15, 2009
Mitsubishi WS-55807 Error Code 24 Vertical Deflection Failure. 5.
Hi. The service manual is in more than one part.
Schematics are in part 2 here:
Download Service Manuals for free
Jul 30, 2016 | Mitsubishi WS-55807 TV
How can do I connect my laptop to my Mitsubishi ws-55807?
Click here to downlaod the user manual to your Mitsubishi TV. It have all the details.
Apr 19, 2012 | Mitsubishi WS-55807 TV
Mitsubishi WS 55807 wont turn on
SECONDARY POWER SUPPLY IS OUT
Dec 05, 2009 | Mitsubishi WS-55807 TV
Won't come on
The power board has failed and will need to be repaired or replaced. you can remove this board and, replace individual parts and save a lot of money. You will be inspecting for swollen capacitors and resistors. also, look for discolorations on the board itself.
Feb 19, 2009 | Mitsubishi WS-55807 TV
Mitsubishi WS-55807 turns on but then powers back down after a few seconds
Good Day;
The fuses tell you that circuit has failed and was drawing too much current. No other test is needed.
Good Luck, big Irish.
Sep 04, 2008 | Mitsubishi WS-55807 TV
Mitsubishi WS-55807
Good Day, betsy;
Check all cables and try to reset by un[plugging for 3 to 5 minutes(from wall), plug back into wall.
Good Luck, big IRISH.
Jul 28, 2008 | Mitsubishi WS-55807 TV
Dm board (power supply) for mitsubishi rear projection tv (ws-55807)
Good day,
mohiuddin;
If the indicator stays on then you may have an DM PCB problem and to correct this do the the folowing:
SYMPTOM: Power LED does not stop blinking after plug in.
CURE: replace C9B01, C9B02,C9B10, and C9B11 (1000 uFD 16V) on the DM PCB. Replace them with part # 181P734030 (680uFd 16V).
The DM Board (PCB) is located on the very left side of the TV looking from back. Caution on removing Board and note what cables you disconnect to access the Metal Shielded Board.
Jul 22, 2008 | Mitsubishi WS-55807 TV
Mitsubishi WS-55807 TV won't turn on
It s a Power supply problem.If you are not familiar with electronic repairs take it to an authorized repair shop.
To get a service manual see link
Download Mitsubishi WS-55807, WS-65807, WT-46807, WS-55857, WS-65857, WS-55907, WS-65907, WS-73907 Service Manuallockmanualsdnw_en.gif
Login or Register to get access all drivers database.
Please be sure to enable cookies.
Feb 21, 2008 | Mitsubishi WS-55807 TV
TV won' turn on
Solder, solder, solder! Shut down circuits protect crts to avoid permanent damage. If any of the deflection circuits are defective, or intermittent, shut down occurs. I have not only seen bad solder on deflection circuits, especially vertical, but also intermittent connections on the yokes themselves. I've also seen shorted convergence ics cause shut down. Don't forget solder connections in the power supply.
Jul 05, 2007 | Mitsubishi WS-55807 TV
Mitsubishi WS-55807 TV Logo
306 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
