Question about Whirlpool LEQ9858P Electric Dryer
Burnt smell when dryer running
Repairman here twice and according to him, all is functioning properly inside dryer....the smell is driving me nuts! All vents are clear. No painting or staining or any household work like that done recently. Any suggestions would be appreciated. My dryer is only 3 years old. Washer is 16 years old and running great! Thanks
  • theheckman05 Feb 28, 2009
    I just switched to Tide Total Care and prior to that used a Tide product. Don't think that's it.
    thanks for your input!
    Problem Solver:
It could be what your washing your clothes with.
Posted on Feb 28, 2009
Ge duet dryer smells and is rattling
what is your model number is then we can get started then
Sep 09, 2012 | Whirlpool 8579123A DUET DRYER DR REVERSAL...
What's your problem? burnt smell in clothes
I would check your exhaust line, because all the symptoms you are listing are caused by a restriction in the air flow.
May 19, 2012 | Maytag MGDX500XW Dryer
A bad smell (like a chemical) was coming from the frig but it was still working fine. Repairman couldn't find anything - other than saying it smelled like burnt wiring. Then a few days later, the...
There is a stile heater around the door opening and sounds like it shorted out. This would be the smell you noticed. The plastic door trim should have felt exceptionally warm to the touch
Aug 01, 2011 | Turbo Air MSR-49NM Refrigerator Commercial
Our dryer is overheating, after 20 25 minutes then we smell a burnt plasticy smell, then we let it cool down, start again, it goes for awhile, then stops, then again overheating, then the smell again.
Firstly, you need to stop running your dryer before you do any further damage,
As you haven't specified your brand or model of dryer, I can only give general advice. It's likely that your thermostat has failed in the closed (on) position. The thermostat cuts power to the element when your dryer reaches the correct temperataure.
Most dryers also have a thermal fuse to cut all power to the dryer if they overheat. This functions as a backup safety device and this only usually trips when the thermostat fails. Your dryer is stopping because the thermal fuse is cutting power, but as you can smell burnt plastic, it's likely some damage is being done before the thermal fuse trips.
Stop using the dryer, and check/replace your thermostat.
Please rate this solution if you find it helpful. Thanks!
Oct 31, 2010 | Dryers
Smells like burnt diesel or very hot smell
Can't help thinking that either you don't have the revised operating instructions, or the "Sensor Dry System" is not working properly. Download the revised instructions here [http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6231 ] and see if this helps. Otherwise have the sensors in the machine tested.
Mar 12, 2010 | Crosley CDG6000 Gas Dryer
Thumping noise (similar to shoes drying) and burnt smell
that one needs a serviceman to look at it too many variables as to cause
Jan 23, 2010 | Maytag Atlantis MDE6400AY Electric Dryer
The inside of my Kenmore Series 70 gas dryer smells like burnt popcorn/metallic smell. Do you have any tips on what is wrong?
you might have lint drawn into the air intake of the burner .. or air flow could be restricted by a clogged outlet tube .. in both cases you have to get inside the machine and clean it properly .. that should be done every couple of years anyhow .. the passagways inside the machne must be cleaned as well as the 3 or 4 inch hose that goes to the outside .. also make sure the flapper valve on the outside exhaust is free and not clogged by animals, grass or lint ..
Nov 12, 2009 | Kenmore 73952 Gas Dryer
Dryer Wont Start - Smells Burnt
check for shorts and something holding the fan also look at breakers
Aug 11, 2009 | Whirlpool GEW9200L Electric Dryer
My kenmore dryer will run then stop after a few minutes
this sounds like it is overheating all driers have a thermatic switch that will kill the drier if it over heats, probably wouldnt hurt to call out a repairman from sears on this one.
Dec 31, 2008 | Kenmore 62602 Electric Dryer
Back heating grate inside dryer has become dark like it's burnt
I used Bartender's Friend. You can find it at Home Depot. Its best to put it on a sponge, rub it on and let it set for about 5. Then scrub with a steel pot cleaner or copper one. It hard to do since the grid is in the back of the dryer but it came off!! Basically, clean it like you would a burnt pot or pan with the Bartender's Friend.
Sep 24, 2008 | KitchenAid KEYS850LQ Electric Dryer
Whirlpool LEQ9858P Electric Dryer Logo
148 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
