FixYa.com
Tags:
Paragon Software NTFS for Win98  for PC
Speed reduction with Win2000/XP?
By Powe33 - usenet poster
I'm running Win98 (first edition) right now on a Pentium II (415 Mh)
with 192 Mo of RAM. I'm considering changing to Win2000 or WinXP, but
have been told that this will slow down my machine considerably. Is
this true? Just for reference, right now it takes less than 1 second
to open IE 5.5, less than 3 seconds to open Eudora 5.0 and less than 9
seconds to open Adobe Acrobat Reader 5.0. Thanks for any information.
Jill
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Aug 02, 2007
Inappropriate (40)
Melissa
Melissa - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
On 17 Jan 2003 12:33:45 GMT, (Eric Legge)
wrote:
Thanks so much for this information!
Jill
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
Perkins
Perkins - usenet poster
Rating: 0%, 0 votes
Jill,
Windows 2000/XP work best with 256MB of RAM, but you probably wouldn't notice
the difference.
Just be aware that problems could arise if you convert from using the 98 FAT32
that XP can use to using NTFS that Win2000 uses and XP can be converted to use.
Fixing Sluggish XP Performance
An extract from one of Scot Finnie's newsletters -
-- QUESTION: I am running XP Professional on a Pentium 4 Dell with Preinstalled
XP Pro. My applications include Office XP, IE 6, and MSN Explorer. My hard
drive's file system is NTFS. Performance is sluggish. What services should I
turn off to make the machine more responsive? -- Peter Luchansky ANSWER:
Because you have NTFS, I would first suspect that your performance issues are
related to small NTFS cluster sizes on your hard drive. When a hard drive that
was previously formatted with DOS tools (Fdisk and Format, creating FAT16 or
FAT32 partitions) is converted to NTFS, there is frequently a problem that
causes a tiny 512-byte cluster size under NTFS. That's the smallest cluster
size NTFS allows. I won't go into a long explanation, but it's also the slowest
cluster size. The solution is to convert the cluster sizes to at least 4K.
Many, many people have reported that doing so solved their performance problems
completely. Microsoft is aware of the problem, but really hasn't done much
about it. It's also not warning people not to convert to NTFS on Windows 9x
upgrades, which routinely result in 512-byte cluster sizes. This isn't just a
Windows XP problem, either. Windows 2000 users face the same issue. It's also
not just a problem for people who've upgraded to Windows XP and then converted
to NTFS either. Even some new PCs -- including name brand models (especially in
the early going right after Windows XP shipped) -- had this problem. The
DOS-based software tools some PC makers use to image new hard drives are the
culprit. If your new PC was purchased recently from a local system integrator,
for example, you could have this problem. Most major PC makers have resolved
this problem (on PCs sold in 2002), though. So far I have been unable to come
up with a reliable solution that doesn't require the use of a third-party
disk-partitioning utility. So the one I recommend is Paragon Partition Manager.
This product was developed by Russian programmers for the European market. You
can buy it on the Internet for about $40. What makes it different from most
other disk-partitioning utilities is that it can dynamically convert cluster
sizes under NTFS. The following article in Scot's Newsletter describes where to
get Paragon and tells you how to use it to solve the 512-byte problem:
# Before you rush off and buy
Paragon, though, use the instructions on this page to find out whether you have
the 512-byte cluster size: # If
your cluster size isn't less than 4K, then this isn't your problem. If you
already own PowerQuest's PartitionManager, you should read these instructions.
# While they don't work for
everyone, they could save you the cost of the Paragon product. Finally, there
are other disk partitioning utilities -- some of them available for free --
that may also do the job. I have not tested those products. But I wanted to let
you know they existed if you want to do your own research. I have personally
solved the cluster-size problem with both the Paragon and PowerQuest products.
--S.F.
Eric,
PC Buyer Beware!
Can you Help with these Software Utilities problems?
Software Utilities
i want to download audio driver...
for the intel inside I have... Answer This...
Software Utilities
Thanks Collieweb
I already installed the OS and... Answer This...
Software Utilities
Edit the Solution
Hi, Is there a way to edit the... Answer This...
Software Utilities
samsung pleomax webcam software
good day i have a samsung... Answer This...
Software Utilities
ip1880 Printer Driver for Win98
Hi, has anyone found an ip1880... Answer This...
Repair Service
Find Software Utility Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
