Question about Waterrower M1 Hirise
Water rower tank leaks just beyond the half full mark
I would like to add more resistance on my water rower, but every time I fill it to more than half, I get puddles on my floor.
How to add antifreeze 2002 dodge intrepid
Open the container of antifreeze. Using a separate EMPTY gallon-size container, pour out HALF of the contents into the empty container, making sure not to spill any. Now, FILL the newly filled container with tap water. Fill the rest of the antifreeze with water, also. Now, you are ready to add antifreeze to your vehicle! Simply locate the radiator cap, (Don't touch it if it's hot!!) and unscrew it. Pour the desired amount of your mixed antifreeze into the radiator. Remember not to do this without proper knowledge!
Jun 26, 2016 | Dodge Cars & Trucks
Why does my water container fill up even though my machine is plumbed in?
This looks like a fault. The plastic tank has two reed switches that measure 'tank empty' and 'tank half full'. When the tank is empty the inlet solenoids (there are 2 for safety) open and water enters the tank but not so much to fill the tank to the half way level. In normal operation the level water in the tank will drop and then more water is allowed in. In your case it appears the 'half full' reed switch is being activated because the solenoids are not closing off properly and water is leaking in and filling the tank. If you do not empty it then eventually it will fill and leak into the leak. The problem can be caused by either low water pressure (below 145 psi) or sticky solenoid. If is the solenoid then the Miele solution will be to replace both solenoids. Alternately you may be able to remove, take apart and clean. Also check that you have a mesh filter at connection to tap. Also you can temporarily fix the problem by turning off the water at the tap and re-programming machine to 'turn off' the plumed water line. regards
May 31, 2014 | Miele Coffee System
Jetta mk2
The gasoline floater in your tank signals full or empty to your dash is stuck at that level.
Nov 23, 2013 | Cars & Trucks
My gas tank leaks and i need to take the tank out to find it
Leaks when it's half full - could be a seam leak.
Oct 02, 2012 | 1989 Chevrolet C1500
My sunfire overheats and leaks out overflow everytime i drivee it.i changed water pump,thermostat the fan is working fine and had a water pressure test done last mth
DID YOU BLEED AIR OUT THE COOLANT SYSTEM.TO BLEED COOLANT SYSTEM, FILL THE COOLANT SYSTEM THROUGH THE RESERVOIR TANK OR THE RADIATOR UNTIL THE FULL COLD MARK IS REACHED.BESURE TO USE 50/50 HALF WATER AND ANTIFREEZE.YOU CAN BUY ANTIFREEZE THAT IS ALREADY PREMIX 50/50.AFTER ADDING ANTIFREEZE TO RESERVOIR OR RADIATOR FILL RADIATOR TO FULL MARK OR IF YOU DONT HAVE RADIATOR CAP ON RADIATOR POUR ANTIFREEZE IN THE OVERFLOW JUG UNTIL COOLANT LEVEL STAY THE FULL COLD MARK.WAIT AWHILE UNTIL COOLANT LEVEL STOP DROPPING.NOW INSTALL THE RADIATOR OR OVER FLOW JUG CAP.START THE ENGINE AND ALLOW IT TO RUN UNTIL NORMAL OPERATING TEMPERATURE IS REACHED AND THE UPPER RADIATOR HOSE BECOME HOT.STOP THE ENGINE AND OBSERVE THE COOLANT LEVEL IN THE OVERFLOW JUG. THE COOLANT LEVEL SHOULD BE AT THE FULL HOT LINE.ALLOW THE ENGINE TO COOL UNTIL THE AMBIENT TEMPERATURE IS REACHED THEN CHECK THE COOLANT LEVEL IT SHOULD BE AT OR ABOVE THE FULL COLD LINE.ADD MORE COOLANT IF NECESSARY. WARNING BECAREFUL WHEN OPEN THE RADIATOR CAP OR JUG OVER FLOW CAP.USE A LARGE RAG OVER THE RADIATOR CAP TO KEEP FROM GETTING SCALDED.OPEN RADIATOR CAP A LITTLE AT A TIME TO KEEP FROM GETTING SCALDED.WAIT UNTIL ENGINE COOL DOWN BEFORE OPENING RADIATOR CAP OR OVERFLOW JUG CAP.WEAR SAFETY GLASSES.
Jul 12, 2011 | Pontiac Sunfire Cars & Trucks
My waterrower has a leaking seam in the plastic tank. I know its not that expensive to get it fixed, but its a big hassle...80 mile round trip in heavy traffic. Is it ok to use plastic sealant like you use...
I sealed my tank seal permanently and also fixed cracks on the bottom with Loctite PL Marine Fast Cure Adhesive Sealant. On the inside when the tank was apart I glued a heavy plastic patch directly over the cracks in the bottom. I made the patch from a flat section of plastic cut from an old refrigerator crisper drawer. After installation with the tank laying flat and level glue the upper side of the tank to the adjacent wood for stability. Wait a few days before filling. Photos are attached. Loctite 10 fl oz PL Marine Fast Cure Adhesive Sealant 2016891 The Home...
Dec 28, 2010 | Water Rower WaterRower A1 Rower
My radiator was not leaking until I filled up the resevoire. What could be wrong
possible your radiator tank has a leak in it up high and when you filled it, it simply raised the level to were the leak is at.filling your radiator or overflow absolutly will not damage your radiator.you already had a leak, that is why you had to refill it.
Apr 19, 2010 | 1999 Ford Explorer
Washing machine Water level will not fill beyond half full
if this is a commercial. thats as much water it gets. most of them are energy star
Feb 07, 2010 | Washing Machines
My engine was running hot so I replaced the
Hello there
no this hose that hangs there is a overflow tube and it is meant to drain out any excessive fluid that the tank cannot hold that is why when you fill up the tank only fill it up to the full line on a cold engine or just a half inch below this line on a warm engine and let the car run untill the temoperature is up to operating levels and check the level in the tank again and add if needed ok?
Rermber that water will expand when it gets hot and if the tank is all ready past the full mark it will overflow into the tube that hangs down from the side.
Hope that this is very helpful for you
best regards michael
Oct 25, 2009 | 2001 Mitsubishi Eclipse
Waterrower M1 Hirise  Logo
312 people viewed this question
Top Waterrower Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Tom Chichester
Are you a Waterrower Exercise and Fitnes Expert? Answer questions, earn points and help others
