Question about Sharp LC-65D90U 65 in. LCD Television
Sharp LC-65D90U Pwers on has backlight but no menu image/sound
Powers on all lamps but no video or sound. Menu functions/input setting don't come up? Help.
  • Anonymous Mar 21, 2014
    There art areas in the set up menu that show question marks instead of the function. what is the cause?
    President:
  • Sharp Master
  • 1,779 Answers
This is a main control module problem since you can't bring up the menu. I recommend contacting your local svc co.
Posted on Feb 28, 2009
Lcd tv screen goes black after a few seconds but sound still plays. The flashlight test will show the image for a short period of time but then it goes away and is completely black.
Hello... It sounds like you have a backlight failure, and the image going away during the flashlight test is due to the TV going into "Protection" mode. A service technician may be able to go into the service menu and clear the lamp error codes and get the TV working, or it may need the backlights replaced. I hope this helps...
Nov 17, 2017 | Sharp Televison & Video
Sharp lcd tv turning on, sharp logo comes up then it powers off
can be backlight issue. lamp defective in lcd screen. try to force on unplug tv .and then press and hold volume - channel+ and input buttons on tv while holding down these buttons then plug in in. will come on .its mean lamp defective.
Apr 25, 2017 | Sharp Televison & Video
I need a DUNKKD530UJ01. This is a top tcon board for LC-65D90U. Who has one?
Couldn't find your specificcion but maybe another T-Con board might work too
Try
Sharp DUNTKD530UJ01 (KD530, XD530WJ) T-Con Board for LC-65D90U
Sharp DUNTKD530UJ01 KD530 XD530WJ Con Board for LC 65D90U
Or call Shopjimmy see Contact/Helps on webpage
They know about EVERYTHING about parts!
May 11, 2015 | Sharp LC-65D90U 65 in. LCD Television
LC-37SH12U picture is upside down
Its somewhat common for this to happen and generally its an easy fix but since your set doesn't have the flip picture option your going to need to get into the service mode to fix this...below are the steps on how to get into the service menu on a Sharp TV...once your in there you need to look for either mirror image or H invert, and change that setting from on to off or off to on depending on what setting you have.
* While the LCD is on, unplug the power cable.
* Then while pressing the {INPUT} & {VOL -} buttons on the remote, plug the power cable back into the outlet.
* When it powers up you will see a little "k" appear in brackets.
* Then on the TV, press and hold {VOL -} & {CH -} down and release.
* The Service Menu will be displayed.
* Use {CH+} {CH -} buttons to navigate
* Use {VOL+} {VOL -} buttons to adjust the value.
* Turn the set off to exit the Service Menu.
Nov 06, 2017 | Televison & Video
Sharp Aquos Lc-65d90u verticle lines and srambled images in one section of screen. Is this the LCD panel and is it worth fixing?
Hello; If there is at least one vertical line that does NOT go FULLY from top to bottom, your LCD panel is cracked. This panel will cost much more than what you paid for the set. WII controllers are responsible for the death of many TV's.
Sep 30, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
LC-65D90U 65 in. LCD Television: when i am turn on just turn on the red light in th...
Call sharp back again and tell them you first want to register for aquos advantage program, which is free. By doing that your service will go much quicker with them. You then tell them that you want to get set up for service. They will have one of their authorized professionals come and fix your tv in a matter of days. If their tech cannot fix it, they will replace your tv free of charge as long as you are within your warranty.
May 16, 2010 | Sharp LC-65D90U 65 in. LCD Television
Got a sharp pn-455. Powers up, but no display, no
Do you have a remote? If not, while it powered up press input button on the front of PN455. What do you see?
Dec 01, 2009 | Sharp PN-455 45 in. LCD Television
My Sharp TV will only hear sound. No picture or images even from the tv menu setup option. Model# LC-19SB25U. About 1.5 yrs old. Converter box ok.
In most cases, you can reset the TV by leaving it unplugged for 30mins.
If this doesn't work, I believe the circuit board that supplies power to the screen maybe bad. They call this board a backlight inverter board. It would most likely cost more to repair than replace the TV .
May 27, 2009 | iLO 3200 32 in. LCD Television
No Picture
I doubt that your component has burned out. You may be looking at a repair issue here even though your unit is only 3 years old IF: you have tried connecting using different inputs, OR if you cannot bring up your sharp menu, or you list of inputs. If you cannot do those following things, you have a SERVICE issue on your hands and unless you purchased and extended warranty with sharp, its useless calling them. They will just tell you tough luck, and refer you to one of their authorized service centers. good luck
Feb 15, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp LC-65D90U 65 in. LCD Television Logo
136 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
