Question about Microsoft Windows Vista Ultimate Edition
Deleting a file from desktop .
I use windows vista home premium. I had cancelled copying a file from dvd.Then there was created a file image which I cant delete anymore.It also shows nothing about its property.Whenever i delete this file it shows "calculatig time remaining".It is not deleted then,it only shows "calculating time remaining".it never deletes. what should i do?
  • 564 Answers
  • Restart the computer and try to delete it.
  • get in to safe mode and try delete it.
  • Disable all the sevices and try to delete it.
  • try to delete it from command prompt.
Hope This Helps!!!  Please Don't Forget to Rate my Response!!! Thanks!!!
PREM
Posted on Feb 28, 2009
Sony laptop vaio vgn with windows vista has corrupted desktop icons
you could try going to recovery and repairing windows, this wipes ya windows files but then puts them back on without harming programs and files!
Feb 14, 2013 | Microsoft Windows Vista Home Premium...
I have one cd with windows vista home premium, and i can not activate him. what can i make ?
You have to have a valid product key to activate it. The product keys usually come packaged in the box with the retail CD. If you don't have the box, then sorry but you will have to either buy another copy or find some other means to obtain a valid vista home premium license key.
Mar 10, 2011 | Microsoft Windows Vista Home Premium DVD...
Vista home premium missing help files
Dont worry if you are missing help files...........just follow these steps...:-
1) get to someother computer which have windows vista premium running. try to find help files in c:/windows directory.
2) Once found copy it into usb and copy those files in your system at the same location from where you have copied them in other computer.
3) Restart system and its done.
Other way is to use vista recovery disk to copy system files ...
Hope it works well for you.........
Dec 24, 2010 | Microsoft Windows Vista Home Premium...
I Wanted To Make a BOOT CD For Windows XP But The Problem is That I Have Windows Vista and i Dont Know What To Do So What Can i Do
How to make a bootable Windows Vista ISO DVD media
  1. Put all 3 downloaded files (namely install.wim, boot.wim and an executable X13-49120.exe) in the same folder (for this tutorial, let’s assume the files are put on C:\ else you need to modify the path accordingly).
  2. Run the X13-49120.exe executable. Windows Vista Setup Preparation will create a new folder “Vista” inside the folder and will populate the folder with all necessary Vista setup files which takes up about 2.52 GB disk space.
  3. Exit from the Install Windows screen.
  4. Download CDimage 2.52.
  5. Extract CDimage from CDimage.zip to the C:\ root directory.
  6. Open a command prompt shell, and run the following command: cdimage.exe -lVISTA_EN_DVD -m -u2 -bC:\Vista\boot\etfsboot.com C:\Vista\ C:\Vistax86.iso
    Bootable Windows Vista x86 DVD ISO image in UDF format will be created as vistax86.iso in C:\ or any folder you specified above.
  7. Burn the newly create ISO with a CD/DVD burning software such as Nero or Alcohol 120%. Try to burn at low speed (i.e. 4X) and turn on verification to ensure that the DVD creation is fine.
Visit here for illustrative guide on using CDImage GUI version to make the bootable DVD ISO.
Create a Windows Vista ISO image and DVD with Oscdimg
Another possible way to create a bootable Vista ISO and DVD is by using Oscdimg CD-ROM and DVD-ROM Premastering Utility, available via WinPE (Windows Preinstallation Environment) via Business Desktop Deployment 2007 or Windows Automated Installation Kit (AIK).
  1. Complete step 1 – 3 as above.
  2. In the command prompt window, run the following command: oscdimg -bC:\Vista\boot\etfsboot.com -h -u2 -m -lVISTA_EN_DVD C:\Vista\ C:\VistaDVD.iso
    A VistaDVD.iso UDF DVD image will be created and can be used to boot the computer from DVD to install Vista.
  3. Burn the ISO image file by using last step above.
Visit the guide to create Vista bootable DVD using vLite.
Note: For 64-bit Windows Vista, download etfsboot.com and put it into “\Vista\boot” folder. Or users using WAIK (WinPE), the etfsboot.com can be found at %Programfiles%\Windows AIK\Tools\PETools\amd64\boot\ folder. So simply replace -bC:\Vista\boot\etfsboot.com with -bC:\Program Files\Windows AIK\Tools\PETools\amd64\boot\etfsboot.com when making 64-bit Vista DVD image.
Aug 02, 2009 | Computers & Internet
Recover deleted .GHO files
If you are seeing the file within the recovery software but it shows as 0 bytes then it was probably already overwritten on your HD. You should take a new image.
May 30, 2009 | Microsoft Windows Vista Home Premium...
I am using vista home premium with sp2 beta. I was having no problems until I recently decided to change the desktop backgroud. When I go to the Control Panel to change the image I get "Page failed to...
It seems ur vista is corrputed. Do one thing, put vista dvd and goto command prompt(run>cmd). type sfc /scannow. It will repair your corrputed windows files.
Apr 23, 2009 | Microsoft Windows Vista Home Premium...
Problem with deletig a file image.
Your system is either infected by virus or other malicious software. you have two options for this problem.1. You have to scan your hard disk with strong and latest spy ware if is not solving your problem then 2. you have to perform the low level formatting of your hard disk.
Best of Luck.
Feb 28, 2009 | Microsoft Windows Vista Ultimate Edition
Windows email
we'll need a bit more information on the computer, please..
Apr 07, 2008 | Microsoft Windows Vista Home Premium DVD...
Windows vista
How To Make Vista Bootable DVD with WIM Downloaded Files If you have purchased Windows Vista online and taken the delivery of the latest operating system via web download from Windows Marketplace, you would ends up with a few downloads with .wim and .exe file extensions. Rather than paying additional shipping and handling charges, you can burn or create a bootable ISO DVD image from downloaded Vista files with the following trick, where the .iso image can subsequently write to a DVD. The DVD created will be the typical 32-bit Windows Vista DVD that available in retail channel, and can be used to clean install.
1. Complete step 1 - 3 as above.
Mar 24, 2008 | Computers & Internet
Microsoft Windows Vista Ultimate Edition Logo
77 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
