Question about Zanussi TC7102W Electric Dryer
Water leak on Zanussi tc7102 dryer
When i empty the water reservoir on my Zanussi tc 7102 tumble dryer the dryer leaks water onto the floor, there is a spring and a plastic part that becomes loose when you take the reservoir out of the machine. Any ideas how to fix it please?
I had a similar problem. There is a 'o' ring on the plastic part that keeps coming out. This 'o' ring is not big enough, you need to replace it with a thicker one, preferably one made from a harder material.
Posted on Mar 01, 2009
  • rooker77 Oct 01, 2010
    just wondered if you could elaberate on this a bit more i have exactly the same problem have taken apart but cant seem to get back together properly has use once and spring comes out of place and problem reoccurs thanks
Hi my miele condenser tumble dryer t294c has started leaking water from inside machine and leaking onto floor has anyone any sugestions of the problem I'm getting thanks
you should remove the cabinet then pour water in and jumper the door switch and run and check where and which hoses are leaking if any? check ur water pump for damage and leaks
Feb 28, 2015 | Miele Dryers
I have a Zanussi condenser dryer TC 7114 w. It stops half way through the cycle indicating the water tank is full, but it is vertually empty and the water is collected in back of dryer and then leaks all...
I have just fixed this as below - your leak may be easier to see if you turn the machine on its front - there is a rear valve with a rubber bung and underneath a rubber pipe with a metal clip - check both for leaks - http://www.fixya.com/support/t4079509-full_water_indicator_lit_continuously
Oct 04, 2010 | Zanussi TC7114W Electric Dryer
Zanussi tc7103w condenser dryer-water tank light keeps coming on when tank is empty or nearly empty-have found small plastic float and spring on floor behind dryer-where do they fit?
I had this problem. If you look at the valve on the plastic water tank, you will see that those parts are the same. They fit inside the tumble dryer to shut off the water from flowing onto the floor when the water tank is removed. The white hollow cylinders in the tumble dryer and the water tank push each other open. If you study the water valve on the tank you will see how it is put together. It is all held in place by a little 9mm O ring at the back of the valve. The ring gets tired after a while and pops off. The valve then falls apart and you find the cylinder and spring on the floor and the O ring still inside the dryer. I bought an O ring kit and reassembled the valve inside the dryer using a new ring. You will have to pull the dryer out, turn it upside down and remove the floor to do this
Sep 23, 2010 | Dryers
No heat from my tumble dryer
There should be 2 limits mounted above the heating element on back along with a limit mounted on the heating element. I have some repair video: HERE
Feb 16, 2010 | Zanussi TC7102W Electric Dryer
Why would a dryer be leaking water at the bottom?
look for a restricted vent . and a cold floor or room . this would cause condensation and would leak from inside / causing leakage on floor in or around the dryer .. hope this helps . pls leave feed back .. mm
Dec 12, 2009 | LG DLE3777 Electric Dryer
Zanussi TC 7114 W Condenser dryer leaking water
Maybe it's the water collector's upper side which leaks...
Apr 15, 2009 | Zanussi TC7114W Electric Dryer
Water leaking from back of m/c
You may have accidentally disconnected the pipe which takes water from pump to bottle.
Please post back if any assistance needed to access pump.
Thankyou for using Fixya.
Jan 23, 2009 | Zanussi TC7114W Electric Dryer
HOTPOINT AQUARIUS CONDENSER TUMBLE DRYER CTD40
There are three water reservoirs - one at the bottom behind the condenser, a second at the back bottom of the machine and then a third at the top which is the one you would normally pull out to empty.
There is a hole at the bottom of the filter in the first reservoir (at the back of the condenser) which leads to the second reservoir at the back. If the hole gets clogged up with lint/muck then the reservoir at the back does not fill up.
So to solve this, unplug the machine, take out the condenser (front left bottom of the machine) reach through to the back and mop up the spare water with a towel and check that the hole to the back reservoir - you can feel this it is towards the right side at the back of the machine is clear from muck.
Once you have cleared it, water will flow to the second reservoir and then (once you switch on the machine) up to the main removeable reservoir at the top.
Hopefully this helps. GB
Jul 09, 2008 | Dryers
Zanussi Tumble Dryer
Sounds like the condense pump is bad. Replace it, or look if there is lint in it. ;)
Dec 30, 2007 | Dryers
Not collecting water in the tank
I also have this problem and is leaking all over my floor underneath...i've only had it a day. the condenser is soppin wet and no water in the tank..i'm dead angry...anyone else have an idea how to fix this mother F*****...thanks...clair
Sep 21, 2007 | Zanussi TC7102W Electric Dryer
Zanussi TC7102W Electric Dryer Logo
738 people viewed this question
Top Zanussi Dryers Experts
Tim Whalen
Are you a Zanussi Dryer Expert? Answer questions, earn points and help others
