A few parts should be interchangeable. Most of them will not be however since the Grand Cherokee underwent a complete re-design for 1999. Some engines and transmissions will switch out. The rear axle in the 97 was commonly a Dana/Spicer 35. This was replaced with a larger rear differential in 1999 for increased towing capacity. The wheels should interchange ok, power steering system was pretty much the same and as long as the hydraulics (supports) on the hood are the same length they should work
SOURCE: 1999 jeep grand cherokee all time four wheel drive will not engage
Sounds like the splines on your transfer case gear are ground down
SOURCE: REPLACE 97 JEEP GRAND CHEROKEE REAR WHEEL BEARINGS
What you do is push the axle inboard in which gives you access to the clip and use a magnate to remove the clip.
SOURCE: Jeep grand cherokee 247 Transfer case Interchange ?
if the shifter is the same and they have the same front driveshaft then yes
SOURCE: Rear Axle Seal Replacement
remove rear tires, then remove brake calipers and rotors, then remove the 4 nuts (each side) that hold the axle shafts to the axle tube (located around the axle tube behind the backing plate) then using a slide hammer pull the axle shafts out, next using a die grinder and an air hammer get he retainer collar and the bearing off (without damaging the axle shaft) then remove the seal and the outer race which will still be in the housing. next put it all back together, make sure the plate with the studs is still on then slide the seal, bearing, then retainer on (all new parts) and using a press push them all the way back on. then is simple reassembly.
SOURCE: open rear window 1997 jeep grand cherokee lorado 4wd
There is a button above the license plate you have to push up on it make sure the door locks are unlocked.
