Question about Technics SC-DV290 System
I am not getting power to my sub-woofer that i added on sub works fine just no out put to it checked resistance getting nothing
  • Technics Master
  • 5,568 Answers
Nothing = zero or nothing = infinite?
If it is essentially zero, you are probably OK since the DC ohms of nearly any speaker measures very low resistance; they are rated in impedance which is a complex combination of  resistance (R), inductance (L), and a little capacitance (C) and becomes the 'Z' of the rating of (typically) 4-8 ohms.
If it is measuring open (a flashing display on any resistance range of a digital meter), then you probably have a problem.
You can safely take a single flashlight battery (or any 1.5 volt cell) and apply this by tapping across the input of your sub-woofer. If it makes a fairly loud 'click' then the speaker is functional.     If it passes the test, you have connection or output problems from your amplifier.
Posted on Feb 28, 2009
My powered subwoofer no longer works through the receiver
if you have your front and centers set to 'small' you want your Bass out to be subwoofer only, and the rca jack labeled 'sub out' is the only place to connect your sub to if you want to control the frequencies with your reciever. I dont know the brand of your sub, or the inputs on the back of it to advise you where to connect, but it sounds like it worked for you at one time, but suddenly it does not
Mar 05, 2013 | Audio Players & Recorders
Sub woofer is not working. it has orange flashing light at the back
Look at the connection of the sub woofer. The orange light indicates either there is some problem with the wire or the connector at the end of the wire.
Also make sure the pin or hole where you insert the sub woofer is working perfectly. You can simply check it by placing another sub woofer at that vary spot and see if it is working fine. If the hole is fine then the problem is either with your cord or your wire pin.
Oct 24, 2012 | Audio Players & Recorders
This isnt actually an alpine problem, but i am having trouble getting power to my c4 subwoofers. my amp is working fine and when i put my other subs in they work fine. when i put these new subs in they...
make sure if the amp work at 1 or 2 ohms you need to setup the same in the woofer.chek if the woofer is 2 or 4 ohms dual voice coil and how the amp work better
Sep 25, 2010 | Alpine Type-R SWR-1042D Car Subwoofer
Mirage LF 150 Sub Woofer. sub not working
within the sub amplifier is an electronic amplifier, that is shorted and blown a fuse. This is all internal. If you can dismantle this module, I suggest do so and any electrical/electronic individual will identify the part needed. you could also check on a replacement module-complete.
Mar 04, 2010 | Mirage LF150 Subwoofer
If i increase the sub woofer volume the voice distorts and gives a buzzing sound. it works fine on low volume
Your sub woofer is not mean for voice sound...check that you have connected the systen up properly and that you have put the sub woofer into its wn connection..if it is in the right connection the woofer could be blown.also try decrease the midrange hurts on the woofer
Jan 03, 2010 | Audio Players & Recorders
I have no sound to my woofers they were working just fine then stoped?? what is the problem
Check the fuses on the inline and the amp(s). Then check the power and ground for solid connections and the remote if needed. By process of elimination you should be able to find the fault in the wiring. If all checks on the above the problem would have to lye in the RCA's or speaker wiring. Also be sure to have the proper resistance in your subs (ie.2ohm,4ohm) and that the amp can handle that resistance.
Oct 04, 2009 | Power Acoustik MOFO-15 Car Subwoofer
Could a ground stop your woofer from working?
First check the speaker wire from the amp to the sub, see if it's connected right. Second check the rca cables that goes from your amp to the back of the deck. I f both wires are still connected fine try to replace the rca cables. If it still doesn't work the rear out put at the back of your deck, where the rca's are connected are bad. FYI deck is bad.
Nov 29, 2008 | Jl Audio 12W3 Car Subwoofer
Hi I own a Technics Hi-Fi system (Model SC-EH780) and would like to attach a subwoofer to it. I cannot find the subwoofer unit that is supposed to go with this system. Can you help?
Any powered sub-woofer will work with it. Check the back of the Technics, make sure there is an RCA output labeled "Sub-woofer" or "Woofer" or "Sub". If so, you can get any brand of powered sub woofer and it will work. A powered sub-woofer is one with an amplifier for the sub built into the box and you will need to plug it into an A/C outlet as well. The only exceptions to what will work with this unit is to make sure you are not buying a sub-woofer that is made to only work with the companion unit it is originally sold with. Many Panasonic and JVC sub woofers are like this. Just look for a sub-woofer that is not part of any system. Velodyne makes some really great sub-woofers that would work nice with yours, but they can be a little expensive, but they are very good.
If your Technics has no RCA output for the sub-woofer, you will need to make sure that whatever powered sub-woofer you buy has a speaker level input for it. Most powered sub-woofers have this feature, so that you may just run the front speaker outputs of the receiver into the subwoofer and then the sub-woofer will have a set of speaker outputs right below the speaker inputs so you can still have your front speakers connected to that and not loose anything from your system.
I hope I have explained this in a manner you will understand easy, if not just post whatever questions you may have right on this thread and I will get back to you as soon as possible.
It would also be appreciated if you could rate this solution if you no longer need any help from me. If you do require more help, please wait to rate this until we are finished. That way I do not get an undeserved bad rating when we have not even finished our communications.
By the way, A "Thanks for trying" and "Helpful" rating are really not good, they always end up lowering my overall score.
Dave
Nov 09, 2008 | Audio Players & Recorders
Wharfdale PC 10 subwoofer
Some basic trouble shooting is required here. First you need to see if it is a problem from your source or the sub. Try a different source to the sub-woofer and see if it changes the response. If still nothing on the sub, then most likely there is an issue with the amp or driver. Check to see if there is a fuse on the sub, if so, it could be blown. There could also be an issue with the auto switching circuit on the subs amp, in that case, it would need to be repaired in the shop. But before that I would check all of the connections to the sub, and also to the driver in the cabinet. If everything looks good, then put some type of source directly to the woofer to see if it works, if you get sound, then looks like the amp has a problem. Again a repair or replace issue.
john
Aug 20, 2008 | Wharfedale PowerCube PC-10 Subwoofer
Sub woofer problem
I would check the power input otherwise if brand new return for replacement
Nov 29, 2007 | Logitech Z-5300 Computer Speakers
Technics SC-DV290 System Logo
76 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
