Question about Zenith ZHD-311 300W Complete Home Theater Sound System, Progressive Scan System
The woofer is not working in my Zenith ZHD-311
Well it was working OK. When I tested the speakers all of them showed up OK including the woofer. It seems that my son changed the plave where it used to be and placed it in the floor, Wuen I go to SETUP all speakers are tested but not the wolfer. It is dead, test skips it. I have try reconnecting, full around with setup to no avail. Many thanks
  • 8 more comments
  • marciovp Feb 28, 2009
    I already checked. All five speakers are working ok. Only the woofer is not. I checked its connection too. They seem OK.
    The five speakers are working fine when I tested them. But the test doesn't go to the woofer. If I go there manually it says that there us none. It seems tha woofer is dead.
    When I go to SETUP the audio only gives me the choice to go into 5.1 Speaker Setup. If I go there ask test it goes from speaker to speaker OK. They are all on and working. But it skips the woofer when testing and if I go there manually the size says None and if I press test it goes from speaker to speaker but skips the woofer.
    I am almost sure that the problem is not in the wiring from the woofer and the amplifier. It could be instead that the woofer burned out. How I test the woofer?
    We have not been able to go to Surround Sound Options. When we go to SETUP there is only one choice 5.1 Speaker Setup. No other choice. If we go there the woofer is not the
    It seems we are not going to solve this...but to stay without the woofer is pain. We have a Sony Bravia TV
    It is getting too complicated. I guess beyond my capacity. Nothing that I thought or you suggested did work. I am not going to open the box. I am afraid. I do not think we will find the way to fix this.
    Yes this will be my last try. Will let it sleep overnight unconnected. Tomorrow we will see and then we decide if we should pursue this further.
  • marciovp Mar 01, 2009
    It was disconnected the whole night. This AM the same thing the subwoofer is not tested. Th test skips it. I guess I will have to open the box and perhaps now replace the cable that connects it to the amplifier.
    Thanks to you all...yes...I will have to take the subwoofer and the amplifier to a professional, a shop that deals with the LG (Zenith). By the way I contacted LG and they recommended replaqcing the cable in the subwoofer. Thanks to you all. I was good to have you around to make sure I was not missing anything...
  • 58 Answers
Press down on the cone and check if u hear the voice cold and if ur cone is not had from the center it means that ur sub is blone check that and also ur conections make sure (+) and (-) are conected corectlly
Posted on Feb 28, 2009
  • 479 Answers
If all the speakers are separately tested and woofer only is not working then this is the hardware issue with the woofer only.Please get it check with any professional.
    Sniper:
  • 113 Answers
Hi there,You need some different connector to connect the speakers.
Good Luck!!!
neo
  • nenotech_neo Feb 28, 2009
    There is a internal fuse in this unit.
    so check out the fuse first.
    and let us know further
    Good Luck!!!
    neo
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Offhand, it would appear to be a setting/configuration issue. Initially, reset the system if a button for such purpose is available in your version model. Alternately, or better yet, unplug from the mains for an extended period (or even overnight) to fully dissipate stored internal electrical charge.. The idea is to revert the unit back to factory defaults. Thereafter try again and initiate setup procedures as well as test all modes/speakers.
Good luck and thank you for using FixYa.
  • Louie  Role
    Louie Role Feb 28, 2009
    Appreciate the postback. Will look forward to your updates on any development (or even the lack thereof).
  • 6,784 Answers
The magnet may have been demagnetized by placing it on the floor. it could also be a separation within the cone, preventing the transfer of signal. I would start by checking the connector box on the back of the sub box. remove this and check all couple and grab points for separation.
  • Zenith Master
  • 19,396 Answers
If the woofer is dead, but the rest of the speakers are working fine then the problem is the wirings to the woofer speaker, the unit must be taken apart and the contacts soldered back again.
All other faults will cause different problems.
  • Ginko
    Ginko Feb 28, 2009
    The woofer does not burn out, it breaks, and if the digital board inside the woofer blows, then the unit does not start.
    The problem are the wirings inside the woofer, and the soldering joints to woofer speaker, one of them has lost contacts.
  • 10,594 Answers
Seems woofer is disable due to some wrong settings in home theater system.
Please check Amp Setup options and surround sound options to enable woofer.
    Genius:
  • 1,550 Answers
Check the connection between woofer and the amplifier section .
Also reset all previous settings and do test for woofer .
    Brigadier General:
  • 3,614 Answers
check the loose wire connection from your speakers and woofer.
    Top Expert:
  • Zenith Master
  • 64,034 Answers
The woofer is the hardest working speaker in the system and draws allot of amps for the voice coil that makes the cone move, these coils get overheated and burn out, u can replace just the woofer, pull the speaker out and test it, all u need is a 9 volt battery, touch the terminals of the speaker, the cone should thump, do this both ways, first positive to negative and then reverse, if the speaker is defective you can match it up with a new one from many onliine suppliers.
Speakers on cinema surround sound working on test only
More than likely the optical connection is defaulting to another source. The optical may have been intentionally assigned to another source and either needs to be reassigned or try switching the inputs on the unit until you hear sound...
Feb 04, 2014 | Logitech Z-5500 Audio Subwoofer Thx...
I change my dvd settings and the picture is scrambled. I can't see the screen; therefore I can't change settings back to original.
Try the old dvd reset.
Remove any dvd close the door and wait until its says no disk then press and hold the stop button 10 seconds.
Jun 12, 2011 | Zenith ZHD-311 300W Complete Home Theater...
Sound cuts in and out, sound doesn't work unless repeatedly turning on and off. What should I do.
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
May 19, 2011 | Zenith ZHD-311 300W Complete Home Theater...
I have a zenith model zhd311 home theater system that is installed in my camper that is not functioning properly..the am/fm part is fine, it will play a music cd but, when i insert a dvd, it comes back...
yes unfortunately your laser isnt reading for 1 of 3 reasons, dirty fingerprints etc on the disc, the laser is dirty,dusty or the laser is weak..clean the disc and or laser if still ng the laser is defective
Aug 31, 2010 | Zenith ZHD-311 300W Complete Home Theater...
Just need to know how to hook up to tv to get sound
If you don't have a cable box or satellite receiver, you will use the "Audio Out" or "Monitor Out" from the TV to any audio input on the receiver. It's just a standard RCA cable or if you have an "Optical input" on the receiver, use that. If you are using a cable box or sat, the audio would come from the cable/sat receiver by standard RCA, Optical, or Digital Coaxial, whichever your AV receiver will support. Hope this helps. If you need further help, post a comment and I can walk you thru it.
Sep 27, 2009 | Zenith ZHD-311 300W Complete Home Theater...
Rear speakers not working
Your FM tuner will only generate sound from the front sepakers. CD's, Tape, and I guess mp3 player, as well, will only play through the front speakers.
I've included a link for the manual. The audio on this rig is pretty complex. read through the info, especially pages 11,12,13, and play with the audio controls.
http://support.radioshack.com/support_audio/doc61/61792.pdf
Aug 16, 2009 | RCA RT2500 System
The progressive scan
I ended up calling support for this because I did the same thing. It's an ez fix.
Remove the DVD from the drive, close the door & wait until it says no disk. Press & hold the stop button for 10 seconds. Your screen should pop back up - voila!
Jul 30, 2008 | Zenith ZHD-311 300W Complete Home Theater...
Dvd
hold the play button for a lil bit it will come back
Mar 15, 2008 | Zenith ZHD-311 300W Complete Home Theater...
Hooking up home theatre system
Connect the cable box outputs to an open set of inputs on the receiver, and that should do it...accordianman
Dec 11, 2007 | Zenith ZHD-311 300W Complete Home Theater...
Language settings
You can change the languange on your BIOS settings..
Nov 01, 2007 | Zenith ZHD-311 300W Complete Home Theater...
82 people viewed this question
Top Zenith Audio Players & Recorders Experts
xalint1
xalint1
Jazz Boyce
Jazz Boyce
Level 1 Expert
Are you a Zenith Audio Player and Recorder Expert? Answer questions, earn points and help others
