Question about Pioneer TS-A6962R Car Speaker
How do i wire 6x9 from the back shelf to the head unit using new wire where do i wire it on the head unit?
    Problem Solver:
  • 5 Answers
If you are going to place the speackers into the rear shelf than you can run your wires along the underside of the shelf,then towards the back of the rear seat, then run it down the length of the seat, when you reach the bottom you will need to try to pry the backrest portion seat foward just enought to get the wire thru to the front, then you will need to get either a phillip or slotted screwdriver, open the back door and at the bottom unscrew the trim from the bottom of the door way,run wire thru do the same with the front door, then run wire behind the trim around or near where the emergency release handle is at, run wire behind instrument panel towared your deck. when you go to wiring up the deck and speakers check on the deck to see if it has a wiring diagram on it if not: most decks come as follows ( white wires front right ,blue or purple rearl left, brown front left, grey rear right red is + black is - yellow is constant +( always on so your deck is able to stay programedwith your presets and audio settings and clock)one single blue or purple wire is the remote for your ampif the colors dont match the ones on your deck then hook up your deck to the power only when the deck comes on go ahead and set your speackers to only the rear right speacker and take your wires from your speacker and touch them to the wires on the back of the deck, once you hear the audio coming thru go ahead and mark this as right rear or rr then using the same speaker change the settings to rear left speacker and do the same as with the other one mark it rl and do same for front speackers
Posted on Feb 28, 2009
Cd player wont load ?
is it the original unit ? if so they fail .mine failed twice once under the 5 years cover then just outside .so i bought a better unit and replaced the speakers and added a small under seat ken wood sub .the sound quality is excellent if you have some basic DIY car electrical knowledge its a easy job to do just take ypour time many new head units come with DIN wiring so will fix on without any extra wiring you may have to add a live just take from cig lighter its easy to get to .there are you tube videos to help you ..the speaker that came with the car will need to be changed because they will sound poor with a new head unit .i used 6 and half inch hertz speakers and a 6x9 kenwood sub with an alpine head unit ..its very nice quality sound .
Feb 20, 2014 | 2005 Hyundai Tucson
How do i install 6x9 speakers in a 1995 oldsmobile cutlass ciera?
No brackets are necessary...I believe you are talking about replacing the rear speakers located in the rear wondow shelf...Of course the speakers mount underneath the window inside the trunk...You can remove the rear seat and pull the interior trim back to view the top side of the speaker mounting...The opening is already cut for the 6X9 speaker...You can mount the top underneath the window cloth material like the factory did, or no need to remove the interior cloth if you use new top speaker covers, usually come with the speakers. Hope this helps.
Sep 06, 2012 | Cars & Trucks
VT Commodore 6x9 Speaker install
Hello taz_is_1,
Sure, it's OK as long as the new 6X9's are the same impedance as the door speakers.
Unless there are already wires and cutouts for rear shelf speakers, the installation will be pretty involved. And while I'm not sure of the Holden product, it's sister versions, Chevy Lumina and Omega, does not have such cutouts or wiring.
Wires going into the door interior for window controls, locks, and speakers will all be in a bundle and go from the vehicle frame into the door through a flexible rubber connector with grommets on both sides. You'll need to run your wires from the disconnected door speakers back through the same grommets to avoid pinching and damaging them. After you get them back into the vehicle interior, you can run them under the trim or carpet to the trunk area under the rear shelf. If you have never done such work before, I recommend you get someone who has to help you. You'll need to make an appropriately sized cutout to mount the 6X9's. And depending on the material, you may need some kind of reinforcement and/or spacers. Also, look out for anything underneath the trunk lid that may come into contact with the speakers. There's usually 2 metal rods than span the width of the trunk and run almost directly under the shelf. They will have to clear the speakers in order for the trunk to open and close properly.
It's more work than a simple speaker exchange with a good pair of aftermarket speakers. And the benefit is minimal. A really good set of 5 1/4, 6 1/2, or 6 3/4 Alpines, Bostons, or Infinitys will sound better than a mediocre set of 6X9's any day and you don't have to cut everything up to install them in most door openings.
Hope this helps.
Sep 07, 2009 | Pioneer tsa6970s 6 x 9 3W Speaker Car...
1999 Audi A4 Rear Speakers
The large block is a factory amplifier - in your car (as was in mine) you had a partially-amplified system. The front speakers were driven at speaker level from the head unit, but the rears were fed a line-level signal from the head unit to the amp, which then boosted to speaker level. The harness then sent the speaker level signal to each rear speaker.
What you can do is fit your new head unit. The fronts will interface perfectly with no issues. For the rear, run new wires from the adapter harness at the back of your head unit, back to the new rear speakers, and connect them directly. Then everything will work as it should.
Dec 17, 2008 | Alpine DDW-F30A Car Speaker
Rear speakers in audi 1999 audi a4
You don't want to fit that - it's the factory amplifier for the rear speakers (the rears are amped, the fronts are not). You need to run new wires from the head unit back to the new rear speakers so that the speaker-level outputs from the new head unit are used to drive the new speakers.
Dec 16, 2008 | 1999 Audi A4
Stero works with engine off
Some wiring may be crossed between the Ignition wire and the 12V battery wire. Check the wires behind the head unit. The head unit could also be going. Hope this helps!
Aug 03, 2008 | Pioneer DEH-1600 CD Player
Fitting car speakers
direct to front s out from sterio have to match up know were your old ones go a wire harness for your car says all labeled nice were to go weird colers in such ok get that match it up to back of head unit wireing it direct ok postive on + negitive on - ok its notto hard if u dont know colers u call deler they tell u the coler codes for your car write it down ok
Jan 22, 2008 | Denon AVR-3805 Receiver
Peugeot 106
you could use existing speaker wire from original speakers.and or just run new wire thru plastic kick panels , thru plastic base boards theh thru plastic rear kick panel ,thru rear seat ...
Dec 08, 2007 | Audio Pro 15PLB76 15 Inch 800 Watt Woofer...
Head unit is on but no sound coming out
I Had That Happen To Me Its A Ground Problem. Check The Negtive Speaker Terminal And The Ground Wire Runing To The HeadUnit This Should Fix It.
Dec 17, 2006 | Kenwood KAC-9152D Car Audio Amplifier
Pioneer TS-A6962R Car Speaker Logo
3,782 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
