Question about Tomtom ONE GPS Receiver
I tried to connect tomtom to my computer as described in booklet but nothing happened.now icannot switch tomtom onagain
    Sergeant:
    Champion:
  • Tomtom Expert
  • 373 Answers
Try pressing the 'reset' button for about 10 seconds and retry.
Hopefully this will solve the problem for you
Posted on Feb 28, 2009
Tomtom go 720 won't start up
leave on charge for two hours, then if you have a sd card take the SD card out, hold down the reset button at the back of unit for ten seconds and then the 'on' switch for ten seconds.
STEP 1
Connect your TomTom to your
computer True True (``````````` (``````````` 0 95250 95250 clip_image002.gif via USB and open up your Windows Explorer and go to the drive. (It will be listed as TOMTOM (E) or some other drive letter).
Copy the Yellow Folders one by one to your PC. Ideally, save all the folders under a new folder that you name.
You may find that the folder ttntools and gns may not be copied. This is o.k. if they aren't.
STEP 2
Format your Tomtom via MY Computer.
STEP 3
Copy the Yellow Folders from the
backup True True (``````````` (``````````` 0 95250 95250 clip_image002.gif you made in STEP 1 back to the TomTom.
STEP 4
Open TomTom Home
Click on Upate Now.
Install the latest update onto your TomTom.
Once installed, switch your TomTom off, then disconnect if from the PC.
Thats it. From now on, make a full backup using TomTom Home prior to any updates.
Also note, that copying all the files will take some time.
Jan 31, 2008 | Tomtom GO 700 GPS Receiver
Nothing happens when i plug my usb cable into my computer with the tomtom ONE
start tomtom home if it does not start automaticlly when you turn on your tomtom and connect it to your computer..if you dont have tomtom home, you can get it HERE.
if its still not connecting try another usb cable although im not sure in that one disconnects from the home dock on the 910
( i assume your using the home dock because thats the only way a 910 will hook up to a computer)
Nov 04, 2009 | Tomtom GO 910 GPS Receiver
Tomtom will not connect to computer press yes on tomtom as instructed to connect to computer but nothing happens. need to install european maps
This is not a solution, it is a new problem
my tomtom was working fine until I connected it to my computer using the latest TomTom Home. It now flashes a white cross and TomTom Home says "No device connected". My TomTom is useless now and does not work anymore.
Oct 20, 2009 | Tomtom One XL GPS Receiver
I have connected to my computer but nothing happens.
I presume that you are using the docking unit, so plug it into a usb with the tomtom turned off, then when you turn it on it should boot up the tomtom home prog.
If that doesn't work, remove any existing tomtom home prog from your PC and try again.
Download tomtom home from your CD or from the website.
If you have aquired the unit second hand it may be blocked due to security reasons.
The only way to sort it then is to mail TomTom and give them your serial number and an explanation !
Apr 23, 2009 | Tomtom GO GPS Receiver
I have red x flashing have tried to reset think it;s frozen
On your device you may have a corrupt file that is causing the issues that you are experiencing. The solution to this is to completely remove the software from your device and reinstall it again as described in the steps below. Please ensure that you have the latest TomTom Home software installed on your computer:-
You can download and install the latest version of TomTom HOME from the following link:
http://www.tomtom.com/home
Once you have the latest version of TomTom Home installed, please follow these steps:-
STEP 1. Creating a Manual backup of your TomTom
• Charge your unit for at least two hours (preferably via the home charger)
• Perform a reset on your device (see: http://www.tomtom.com/6965 )
If you have not made a backup yet you can do so by making a manual backup of your TomTom. To do this, please look at the following web page:-
http://www.tomtom.com/3171#backup
• Connect your TomTom to the computer
• Open My Computer, you should see the TomTom as a removable drive, double click into it. (on a mac you will see the TomTom as a disk drive on your desktop)
• You will see a list of files and folders.
• Copy all of the folders on the TomTom, one by one to the backup folder.
• This can take up to 1 hour to complete depending on the device.
• If you get any error messages while copying, move on to the next folder and copy that to the backup folder.
• If possible, please make a note of any error message that occur while copying the folders, and make a note of which folder causes the error message.
IMPORTANT: We advise you to follow the next steps ONLY if you have made a successful backup of your device as described in step 1. If you are unable to complete step 1, please reply back with a list of yellow folders that you have managed to successfully copy to your PC and also reply back with any error messages that you receive at this point.
STEP 2. Format the hard-disk,
• Open 'My Computer'
• Right click on the TomTom icon (the device should be seen in drive E,F,G,H,I etc) and select 'Format'.
• Do a full format by selecting FAT 32 and click on Start, do not select 'quick format'. The TomTom is now formatted.
• Disconnect the TomTom from the computer and switch it on. It will load up with a red cross on the screen.
• Reset the TomTom with a paperclip in the reset hole for 30 seconds, see http://www.tomtom.com/6965 in how to do this.
• Once Reset, switch the TomTom off, disconnect it from the computer and then switch it back on again, it will still show a red cross on the screen.
STEP 3. Restore the Folders to the TomTom
• Connect your TomTom back to the computer and make sure it is switched on
• Go to your backup folder on your desktop, double left click into it. You will see all of your backup folders.
• Copy the folders one by one to the TomTom by right clicking on the folder, select copy then open My Computer, double left click onto the TomTom drive and choose paste.
• Turn the device off (with the on/off switch) and disconnect it from the computer.
• Switch the TomTom back on.
STEP 4. Update your device
• Open TomTom Home
• Connect your device to the PC
• A list of updates should appear, if not, click on Update my Go
• Select only the program application update.
• Click on Update and Install.
• Once Installed, open TomTom Home
• Click on 'Device -> Disconnect Device'.
• Switch your TomTom On to complete the installation.
The Application is now installed, and your TomTom should now be working.
STEP 5. Run the Clear Flash Tool
• Close TomTom Home. (on a PC, make sure you close TomTom Home from the system tray in the bottom right hand corner of your screen by the computer clock)
• Download and run the clear flash tool from : http://www.tomtom.com/updates/clear_flash/clear_flash.exe Make sure your TomTom is connected to the computer and switched on when you do this.
* IMPORTANT *
If you have any issues with copying the contents of the TomTom to your PC and back again, please let us know and state what error messages, if any, that there are.
Please reply back with the details of what happens.
Jan 10, 2009 | Tomtom ONE GPS Receiver
TomTom Home
I had a similar problem when trying to update my dad’s old TomTom Go300. I bought a new map and downloaded TomTom Home 2 (as instructed on the website) but found that the Go300 was recognised by the computer it wasn't recognised by TomTom's own Home 2 software.
To cut a long story short I uninstalled Home 2 and downloaded Home 1 (from http://www.tomtom.com/plus/service.php?ID=17 Home 1 is the one on the right, listed as being the version of Home you use for Navigator 6).
Then when I switched the Go300 on it was recognised by Home1 - although the new map I had bought wasn't listed as being available for download.
However, I updated the Go300 with the available listed free updates, then switched it off.
Downloaded Home 2 again and switched the Go300 on - this time it was recognised by the computer and the new map I had bought was available to download.
So far so good - the only problem was the the postcode search facility was not the same as it had been - I could now only search the first 4 digits of the postcode. There is a fix for this on the tomtom website:
http://www.tomtom.com/support/index.php?Language=1&query=postcode&FID=9852
which I followed and which worked.
Hope this may be of some use to someone! It took me hours to figure it all out. But it's up and running now.
Redd
I read and read and re-read the TomTom website looking for any info that would help but came up with nothing. A few hours later and the air thick with torrents of language I didn’t think I was capable of I discovered that I needed to download Home1 first and let the Go300 connect to the computer via Home1 before it would be recognisable by Home2. Okay…
On the website, though, Home1 is listed as being the version you use if you have TomTom Navigator 6. It’s not even called ‘Home 1′. Confusing eh? Anyway, I downloaded that and from there found that I could get my new map onto my Go300. Once the map and other updates were installed and I had switched the thing off I then found that Home2 recognised it at last.
That had to be one of the most ridiculously long-winded things I’ve had to do on a computer, mainly because TomTom’s confusing advice on their website made the whole process so damn difficult. Perhaps they hoped I’d give up and buy a new one? Tsk.
Redd
May 17, 2008 | Tomtom GO 300 GPS Receiver
TT Home does not recognise connection
You definitely need software and maps on an SD card. The TOMTOM will not work without a card inserted. The card will contain MAPS , Map authorisation codes ( to show they are genuine TOMTOM maps bought and paid for ) , POI ( points of interest ), GPS fix data , voices ( for spoken navigation ) etc etc etc. ....................
PLEASE NOTE , TRYING A CARD FROM ANOTHER TOMTOM is very unlikely to work. Each card has an authorisation code that is generated via an algorithm inside each TOMTOM and is device specific.
However , trying a card from another tomtom might produce a diferrent result but still not work , at least this might prove that the tomtom is working OK before you rush out and buy a tomtom card.
Feb 02, 2008 | Tomtom ONE GPS Receiver
Tom tom 300
"My tom tom wonts switch on. I have reset it and still it comes on with a boom boom noise and shows the 2 hands on the screen. It also shows the loading bar at the bottom, but then it just freezes and nothing happens. can anyone help please ASAP"
Sound as though your Map data card is corrupt. Remove the SD card and check it with your computer using a card reader. Backup the SD card onto your computer. You can run either chkdsk or go to the drive letter under 'My Computer' right click and select properties, then tools, then check now. You can also try starting the Tomtom with the SD card out of the unit. It should show a picture of the Tomtom with a 'X'. You can also try copying the data on the SD card to another SD card.
Sep 12, 2007 | Tomtom GO 300 GPS Receiver
Tomtom ONE GPS Receiver Logo
41 people viewed this question
Top Tomtom GPS Experts
LP
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
