Question about Kenmore 63672 Convection/Microwave Oven
Microwave will not heat anything.
My microwave works as usual with the exception of it not heating anything. It wouldn't melt a tsp of butter in 2 mins! I've tried unplugging it in hopes of resetting but to non avail. I found the the center component for the turntable is missing as well.
  • cshieldsesq Mar 03, 2009
    My microwave does everything except heat. It does not make any strange noises or anything that leads to the problem. All lights come on, the microwave works, it just will not heat anything that is placed in it. I knew there was a problem when 1 tbsp of was still cold after 2 mins of cooking time.
  • William Miller
    William Miller May 11, 2010
    The turntable system
    consists of the motor, the coupler, the turntable support with rollers,
    and the tray.
    You can see and hear a video of how a turntable motor should
    sound when you rotate it by hand.
    If
    yours is not set to be off via the control panel, and it won't rotate
    or it sounds like it's grinding, etc., you may have a bad motor or
    plastic coupler.
    To
    replace either, you need to unplug power, then remove the bottom cover
    of the oven.
    The turntable is important to ensure even heating.
    When you hit Start to
    cook, do the inside light and cooling fan come on?
    Any unusual noises? Is
    it louder or quieter than usual?
    We have a sound clip of what a microwave should sound like when the cooling fan and high voltage section are operating here.
  • Kenmore Master
  • 19,396 Answers
If it is working but not heating, then test the high voltage capacitor,the rectifier diode.or the magnetron. If all this are fine, test the control board.If turntable is not running check also the door switch.
The diodeand capacitors can be tested. The capacitor must be allowed discharge before testing, or you risk to get electrocuted, evenif power is off.Capacitors can get discharged by shorting their two contacts.
Before replacing the magnetron test also the control board.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts.
You can also order from MicrowaveSvc , they also provide parts.
Posted on Apr 28, 2009
Everything working but no heat
Timer working but not heating - Microwave - iFixit
https://www.ifixit.com/Answers/.../Timer+working+but+not+heating
iFixitMy fridgadire microwave oven is not heating, it acts like it is heating by the timerworking and .... I have a GE Profile and everything worked but it would not heat.
Microwave Not Heating Troubleshooting Guide - YouTube
? 2:45
https://www.youtube.com/watch?v=_3SbJueEn1w
Aug 31, 2012 - Uploaded by Repair.com
If the water is not consistently warm, you've confirmed there's a problem. ..... Everything works except the microwave- it wontheat anything up. ... How to Fix a Microwave Oven - Simple Fuse Replacement - Duration: 18:04. by
Nov 28, 2015 | Electrolux E30SO75FPS 1000 Watts Microwave...
Runs but does not heat the food.
? 2:45
Allow the circuitry to dry out by avoiding stovetop cooking for a few days. .... it to microwave, but its just not warming up myfood at all, any idea on how i can .... Everything works except themicrowave- it wont heat anything up.
Microwave Diagnostic - Has Power Not Heating - GE ...
? 2:34
https://www.youtube.com/watch?v=E_iUYIV8wD0
Aug 9, 2013 - Uploaded by ApplianceVideo.com
Microwave Diagnostic - Has Power Not Heating - GE, General ....internals of a similar GE Microwave unit that would not heat food.... Sometimes it turns on, sometimes it doesn't. .... My GE microwave space saver does not heat but it comes on. ... What's Inside A Microwave Oven (Teardown / Taken Apart) ...
Nov 18, 2015 | Microwave Ovens
GE JVM1653BH01. Microwave will not heat. Ran for 5 minutes and didnt melt butter. All other functions work fine.
Sounds like a bad magnetron
From Sears $139.96 Itehttp://www.searspartsdirect.com/partsdirect/part-model/GE-Parts/Microwave-Parts/Model-JVM1653BH01/0432/0123370/G0703233/00001?blt=06&prst=0&shdMod=JVM1653BH01m # 73 on this diagram:
Jan 24, 2011 | GE JVM1653 Microwave Oven
The Microwave is heating up and appears to function normally. But food is not getting heated or cooked up despite any tempearture and power setting. Even water is not getting heated up and butter not...
If you can't get the food warm or hot, the problem is usually that the magnetron has gone bad. It's an expensive part to replace compared to the price of a new oven.
Jan 04, 2010 | LG Microwave Ovens
HOW DO I ROAST A CHICKEN IN A AC925CHS
Search the internet for “roast chicken recipe for microwave”
Here is one just in case you don’t find one:
Microwave Roast Chicken
3 lbs. chicken
1 tsp. salt
4 tbsp. butter or margarine
1 tsp. paprika
Instructions
Melt butter in a custard cup in microwave. Mix paprika into melted butter. Wash chicken (reserve giblets, these are best cooked conventionally). Sprinkle inside of chicken with salt. Cover ends of legs, tail, and wings with small pieces of saran wrap or wax paper. Place trivet on inverted saucer or small casserole lid in 12 x 7 inch baking dish. Place chicken breast side down on saucers. Brush with butter. Cover with waxed paper. Cook 12 minutes. Remove wax paper or saran warp from legs, tail, and wings. Turn chicken breast side up and brush with butter. Cover with wax paper and cook 12 minutes more or until meat thermometer registers 180 degrees (temperature will increase to 195 degrees during standing).
DO NOT USE MEAT THERMOMETER IN OVEN WHEN COOKING!! Remove chicken from oven; cover with aluminum foil and let stand 15 to 20 minutes before carving. Note: For other weights of chicken, allow 8 minutes cooking time per pound.
Jan 09, 2009 | GE JVM1860 Microwave Oven
Concern about age
I don't know the size of your microwave but if all you use it for is extremely limited to heating or melting, my non-tech solution is to get rid of it and purchase the smallest one they make.
Nov 09, 2007 | Microwave Ovens
Kenmore 63672 Convection/Microwave Oven Logo
184 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
