Question about E-Machines eMachines Desktop PC
Monitor trouble I recently bought some old sierra games that say there compatable with xp. however when i try to play them my monitor goes blank and searches for frequency. i hear the sound in the background but no picture......i have an emachines and its only a couple years old......any idea how i can get a picture on these games.....
    President:
  • 2,653 Answers
Check the game settings requirements. You might have to switch your display resolutions in order to get the games to work correctly.
It's supposed to automatically switch but since it goes blank and searches for frequency that indicated a video related problem.
Posted on Feb 28, 2009
Pharaoh and cleopatra freezes constantly
Probably a bit late, but here are the best fixes I found:
First off, you want to:
*** Change compatibility to Windows XP (SP3)
*** Disable Visual Themes
*** Run as admin
Next you want to:
Download the pharaoh exe files (these are for modifying the resolution - this is what worked for me - I used the lowest res available, so I cannot comment on higher ones)
http://www.wsgf.org/dr/cleopatra-queen-nile/en
Or you can try this fix:
https://web.archive.org/web/20080721084339/http://www16.brinkster.com/salvage/thief/imagecfg.zip
"Download ImageCFG
Extract the .zip and place imagecfg.exe in your game's folder.
Create a batch file. First, open up notepad and paste the following.
@echo off
if not exist Pharaoh.exe goto end
if exist Pharaoh.exe.bak goto end
copy Pharaoh.exe Pharaoh.exe.bak
imagecfg -u Pharaoh.exe
imagecfg -a 0x1 Pharaoh.exe
pause
:end
Save as a .bat file and place it in your Pharaoh installation folder.
Run the batch file.
This will change the CPU affinity of Pharaoh so it will run on one CPU core."
This fix taken from here:
http://pcgamingwiki.com/wiki/Pharaoh
Mar 27, 2012 | Sierra Entertainment Pharaoh And Cleopatra...
I am not able to get the game to start up after instillation. I have 64 bit processor but using a 32 bit operating system, is there a upper limit to computer power that the game is able to be played on?
As this is quite an old game you may run into trouble trying to play it. The only thing I can suggest is to right click on the game icon, then click properties, then click the compatibility tab and select the tick box that says "Run this program in compatibility mode for Windows XP Service Pack 2". If this does not work then it is more than likely the game is not compatible with newer operating systems like Vista and Windows 7.
Hope this helps
Dec 20, 2010 | Simon & Schuster STAR TREK DOMINION WARS...
I am trying to install an old sierra hoyle solitaire from the CD, which loaded the game ok but when I open it it tells me that I require a 64 bit version. I have Windows 7. Is there a patch available?
you can try running it in compatibility mode, when installed right click the desktop icon, then go to bottom of list to properties, then on the thumb nails, look for compatibility look in the list for what ever program it was made for ie windows xp, windows 95, then try that there are more settings there which may help...hope this helps
Feb 17, 2010 | Sierra Online, Inc. Hoyle Classic Games 2...
Blank screen
run compatibility for win 98 not xp.
Aug 03, 2009 | Microids Still Life for Windows
Game comes on. You can hear it but you can't see it
Reinstall the game the resolution for the game maybe out of range for the monitor, this will set the resolution back to defualt. does the monitor say "out of range or out of frequency" when the screen goes blank? if so it is the monitor being incompatible with the current resolution setting. if you changed monitors recently this may be why. Otherwise it is not compatible with your existing graphics card
Jul 02, 2008 | Computers & Internet
Monitor turns blank after start of game
Try reinstalling the game. try to reduce the settings for the game in display options of the game, like trilinear filters, buffers , etc,etc... also check wether you have the updated version of direct x and check for your graphics or video card compatibility...
Kindly give a feed back to Improve my ratings and to see If it was helpful for you...
Thanks and Regards
Mar 28, 2008 | Computers & Internet
My 14" Likom monitor goes blank after installing WIndows XP
I assume your Samsung Magic CGB5607L is CRT monitor (Not LCD).
It could be the problem with "Refresh Rate" the monitor can't handle. Set the lowest resolution with lowest refresh rate. (800x600 @ 60 Hertz). in Display Properties
Nov 16, 2006 | Fuji FP-988D 19" Flat Panel LCD Monitor
E-Machines eMachines Desktop PC Logo
70 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
