Question about Sony XM-1252GTR Car Audio Amplifier
When the red protection light comes on wat does that mean?? amp plays for 5 secs and tha stop while red is on, and my cars dome light dims at the same time
  • maqboolumair Feb 28, 2009
    hey thanks, where should i check for ground, im not to good with all this since it was professionally wired, but where do u sugest i check?
    hey thanks, where do u suggest i check for a ground? im nott good witht his stuff, i had it professionally wired. and the whole setup is like 2 yrs old
  • 4 Answers
If the red light is coming on It mean their is a grounding problem. Also check if the power and ground wire is not cut or broken.
Posted on Feb 28, 2009
I have an 06 kicker zx 1500 monoblock amplifier. The other day i was bumping it pretty hard and it just stopped playing so i stopped and then i stopped to look at the amp and the light was off but the...
Check the impedance of the speaker to be sure that it matches the output of the amp. Common error on this detail can cause the amp to overheat and shutdown/protect.
Jul 23, 2011 | Kicker ZX1500.1 Car Audio Amplifier
How to disarm or reset an alarm system for a 1996 Jeep Cherokee?
Hope this helps:- Factory Disarm Purple/Yellow (-) Driver's Kick Panel Black Connector at ECM -slice into this wire, & wire it to ground, this disables the alarm.
Cavity/Fuse Diagram (1996 Grand Cherokee, passenger side kick plate to find, Owner's Manual pgs 205-206): 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22
Row 1: 1-6 (left to right) Row 2: 7-12 Row 3: 13-18 Row 4: 19-22
1996 Jeep Grand Cherokee Fuse Panel (Passenger Side kick panel) Reply
CAVITY FUSE DESCRIPTION 1 -10 amp (RED) Radio 2 -15 amp (Lt Blue) Cigarette Lighter 3 -10 amp (RED) Rear Washer Switch, Body Controller 4 -10 amp (RED) Airbag 5 -10 amp (RED) Lamp Out Module, Overdrive Switch, OBD II 6 -15 amp (Lt Blue) Vehicle Information Center/Graphic Display Module Park & Side Lamps, Overhead Console Lighted Visor, Automatic Dimming Mirror 7 -20 amp (Yellow) Body Amp, Cluster, Body Controller 8 -20 amp (Yellow) Rear Wiper Motor, Flipper Glass Solenoid, Cargo Lamp, Trailer Tow 9 -15 amp (Lt Blue) Brake Switch 10- 10 amp (RED) Rear Window Defroster 11 -10 amp (RED) ABS Module 12 -10 amp (RED) Heater-Ventilation-A/C Control & Recirculation Motor 13 -15 amp (Lt Blue) Hazard Switch, Turn Signal Switch 14 -15 amp (Lt Blue) Spare 15 -15 amp (Lt Blue) Spare 16 -10 amp (RED) Right & Left Courtesy Lamp, Glove Box Lamp, Halo Lamp Cargo Lamp, Underhood Lamp, Dome/Read Lamp Right & Left Visor, Automatic Dimming Mirror 17 -15 amp (Lt Blue) Radio Illumination, Tail Lamp, Graphic Display Module, Park & Side Lamps, Headlamp Switch, Body Controller 18 -20 amp (Yellow) Spare 19 -15 amp (Lt Blue) Passing Light 20 -15 amp (Lt Blue) Radio, Heater-Ventilation-A/C, Vehicle Information Center 21 -15 amp (Lt Blue) Power Outlet 22 -10 amp (Blue) Airbag Module -------------------------------------------------------------------------------------
1996 Jeep Grand Cherokee Alarm, Remote Starter, Keyless Entry Wiring Information Constant 12V+ Pink/Black Ignition Switch Harness Starter Yellow Ignition Switch Harness Ignition Dark Blue/Gray Ignition Switch Harness Ignition 2 Red/Black Ignition Switch Harness (for AC) Accessory Black/Orange Ignition Switch Harness Tach Gray/White Coil Brake Switch White/Tan Brake Switch Trunk Pin n/a Works with Dome Light Parking Lights Blue/Red (+) Left of Steering Column or Light Switch Head Lamp Tan/Black Light Switch Factory Disarm Purple/Yellow (-) Driver's Kick Panel Black Connector at ECM -slice into this wire, & wire it to ground, this disables the alarm. Door Trigger Yellow (-) Driver's Kick Panel see notes Door Lock 5/Wire in Driver's Inside Driver's Door Orange/Purple Lock Pink/Black Unlock Door Unlock and Passenger's Doors Inside Passenger's Door Black/White L Pink/Black Unlock Horn Wire Gray/Orange (-) Steering Column Windows Up LF=Light Blue, RF=Brown/White, LR=Blue/White, RR=Gray/Black Doors Windows Down LF=White, RF=Purple/White, LR=Red/Black, RR=Green/White
• Cruise Control Information • Stereo Information • View all Jeep Vehicles
Dec 18, 2010 | 1996 Jeep Grand Cherokee
I have a 1996 Jeep Cherokee and the heater vents dont work.I have tried to find a picture of the fuse panel i can read but i cant..When you swith it to vents it only comes out of the defrost.Where can i...
Hope this helps:
1996 Jeep Grand Cherokee Alarm, Remote Starter, Keyless Entry Wiring Information Constant 12V+ Pink/Black Ignition Switch Harness Starter Yellow Ignition Switch Harness Ignition Dark Blue/Gray Ignition Switch Harness Ignition 2 Red/Black Ignition Switch Harness (for AC) Accessory Black/Orange Ignition Switch Harness Tach Gray/White Coil Brake Switch White/Tan Brake Switch Trunk Pin n/a Works with Dome Light Parking Lights Blue/Red (+) Left of Steering Column or Light Switch Head Lamp Tan/Black Light Switch Factory Disarm Purple/Yellow (-) Driver's Kick Panel Black Connector at ECM Door Trigger Yellow (-) Driver's Kick Panel see notes Door Lock 5/Wire in Driver's Inside Driver's Door Orange/Purple Lock Pink/Black Unlock Door Unlock and Passenger's Doors Inside Passenger's Door Black/White L Pink/Black Unlock Horn Wire Gray/Orange (-) Steering Column Windows Up LF=Light Blue, RF=Brown/White, LR=Blue/White, RR=Gray/Black Doors Windows Down LF=White, RF=Purple/White, LR=Red/Black, RR=Green/White
• Cruise Control Information • Stereo Information • View all Jeep Vehiclesairconman.jpg
Dec 16, 2010 | 1996 Jeep Grand Cherokee
I have a JL total mobile audio T500.1 mono amp and it was playing then all the sudden it stopped and the power light which is usually green is now red and stays red and no sound comes from the subs any...
This happens when the amp goes into protection mode. 90% of the time, it means there is a short or has another issue inside the unit and has to be fixed or replaced. Hope this helps and good luck!
Jul 09, 2010 | Jl Audio Car Audio & Video
I have a sony wega kdf 60x5955 about 5 years old. while watching it the screen goes black and sound goes out the green light blinks once a sec. for about 30 sec. then the screen and sound comes back. dose...
There is about 2 or 3 things Lamp, Lamp Fan if Fan stops runinng then TV will shut off to protect Lamp and the Ballast Board is what turns Lamp on.Go to this website online Encompass Parts type in your Model number which is KDF60XS955 They list everything you need Service manual you can download for FREE These are the part number for (Lamp- A-1085-447-A) & (Ballast Board 1-468-875-11) Call them at 1-800-638-3328
Dec 08, 2009 | Televison & Video
Same problem i have a 486 bridge green light before now red.
IF THE RED PROTECTION LIGHT STAYS ON MAINLY MEANS THAT ITS BLOWN, I HAD THE SAME PROBLEM BUT MY PROTECT LICHT DIDNT COME ON, IF U HAVE A WARRNETY ON U CAN USE.
Jun 18, 2009 | Nitro BMW-486 Car Audio Amplifier
PROTECTION LIGHT
Disconnect the speaker wires and the RCA cables from the amp. If the protection light still comes on, the output transistors have likely failed.
Nov 02, 2007 | Lanzar VIBE531 Car Audio Amplifier
Red LED "Protection Light is on" What is the problem
The red light means the amp is in protection mode. A few things can cause protection mode..... First disconnect the subs completely from the amp, and turn it on, if it powers up you have blown subs. Also try checking the main power wire at the battery...sometimes the current your meter is seeing is backfeeding from the remote wire, so your main power line could be blown at the fuse under the hood. hope this helps
Jul 17, 2007 | Crunch BlackMaxx BMX2250 2 Ch 1000W Amp...
Power light
This could be a DC offset condition. Check you manual for what this means. Or other condition. First Disconnect the Subs and try it. If it still goes red then disconnect the RCA's and try it again. If the Led continues to go red after the click then the Amp is hosed. The Click you hear is an internal relay that cuts the subs in after a dely so you do not get the turn on THUMP of the radio at your subs.
Jul 08, 2007 | Hifonics Titan TX 8805 Multi-Channel Amp...
Sony XM-1252GTR Car Audio Amplifier Logo
452 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
