Question about Maytag Atlantis MDE7400AY Electric Dryer
Maytag Atlantis Dryer squeals
I Just need an assembly diagram of my Maytag Atlantis MDe7600AYW dryer. When the dryer is on it squeals really loud and I don't know if it's the belt, bearings, or felt bushings
    Genius:
  • 1,198 Answers
Try Repairclinic.com for help and parts. You are going to need heat resistant grease, and probably snap ring pliers.
Posted on Apr 28, 2009
Maytag Atlantis Dryer model MDE7600AYW. when on has severe sqeeking sounds metal to metal what part would you suggest I replace and can I do it myself. Or is a repairman needed.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Sep 01, 2011 | Maytag Dryers
My Maytag atlantis MDE7600Ayw takes nearly 3 hours to dry clothes. The back silver metal grill is very hot and it still tumbles, no weird sounds. Any suggestions?
sounds like your vent is clogged or there is lint clogged around the blower wheel. Make sure to check outside where it comes out and be sure all the exaust tubing is free of lint clogs.
May 01, 2011 | Maytag Atlantis MDE7400AY Electric Dryer
My Maytag Atlantis mde7600ayw will not turn on and tumble. The heating element does work. What could it be?
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer Repair ? The dryer will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Aug 24, 2010 | Maytag Dryers
My Atlantis Plus MDE7600AYW dryer is only producing cold air, possible solution?
could be a bad sensor that lets the heat come on. There are usually two thermostatic disks that control that check along the air path for them and see if they have continuity. (of course the first time my dryer did this it was because I forgot to turn on the gas. Also check to see if the glow bar is trying to light(it will glo)
Aug 10, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag atlantis model MDE7600AYW is making scraping noise
heatman101
fsh4w2
Jun 23, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
Replacing the belt for Maytag Atlantis Dryer Model MDE7600AYW. What steps do I follow ??
The belt can be replaced as follows.
1 remove top and front of dryer shell
2 belt goes around drum around motor pully then under tentioner wheel
3 replace front and top of dryer
(top pops off use a slotted screw driver)
Thanx for using Fixya Please take your time to rate me
Jun 10, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag gas dryer squealing
Hi, this is a belt issue. make sure the tension on the belt/motor is sufficient. adjust to specs. if the belt is fine, this will be bad bearings in the roller assembly.
Replace the rollers in this case.
May 21, 2009 | Maytag Dryers
My atlantis MDE7600ayw is taking two cyles to dry
Your heating element is going out. If your dryer is still under warranty, contact the manufacturer and let them know what's going on. They should send you a replacement part, or should send a technician to fix it.
Jan 20, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag Atlantis MDE7400AY Electric Dryer Logo
1,186 people viewed this question
Top Maytag Dryers Experts
Mike Cairns
Mike Cairns
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
