Question about Microsoft Windows Vista Ultimate Edition
Programming problem... I wan t to access the system time by writing a c-program without using library function (such as gettime(), settime() etc. ). Please help, how this is possible?
  • 156 Answers
Hi Tulsi,
offcourse you can do it. But for this you must have knowledge of assembly programming, so that you can embed ASSEMBLY CODES in a C program using following way:-
ASM:
assembly codes
Alternatively you can fetch code simpling by opening and observing corresponding header files (system.h etc.) in a text editor like notepad.
you can refer to LET US C (Yashwant Kenetkar) for details.
for specific code you can contact me.
Thanks
Zulfikar Ali
ali_zulfikar@yahoo.com
09899780221
Posted on Feb 28, 2009
How to connect visual basic program book title to access without ado?
what exactly are you trying to do
you can use ado,ado.net or use the entire routine in programming
write like
dim con as connection
dim rec as new recordset
rec = con.open(<<<access provider library>>>,<<<mode>>>,<<<password if any>>>)
your logic
con.close
just search for access library
Feb 27, 2011 | Microsoft Mlf Visual Studio Enterprise...
1999 Chrysler Town and Country
Have you you tried just re-programming all of your remotes? I just added a "new" (from Ebay) remote and when re-programming, had to do them all. Here's how... 1. Using a functional key fob transmitter, unlock the vehicle and disarm the Vehicle Theft Security System. 2. Insert ignition key into the ignition switch. 3. Turn the ignition switch to RUN position without starting engine. 4. Using a functional key fob transmitter, press and hold the UNLOCK button for a minimum four seconds (maximum ten seconds) 5. While holding UNLOCK button, and before ten seconds passes, press and release the PANIC button. A single chime will sound to verify that the RKE module is set to receive the new Vehicle Access Code(s) 6. Within 30 seconds of the chime, press and release the "LOCK" and "UNLOCK" buttons on the transmitter at the same time. Then press any one of the buttons. The BCM will sound an abbreviated chime to acknowledge that the programming of the transmitter has been completed and was successful. 7. Repeat step 6 for all transmitters that will be used with this vehicle (up to 4 total) 8. Programming mode will last for 30 seconds. To get out of programming mode sooner, turn the ignition OFF. A single chime will sound to verify that the RKE module will no longer accept additional Vehicle Access Code(s) 9. When Vehicle Access Code(s) programming is complete, turn the ignition switch to the OFF position and verify RKE system operation using each key fob
Aug 03, 2009 | 1999 Chrysler Town & Country
I have "The procedure entry point _ismbspace could not be located in the dynamic link library MSVCR71.dll"
A DLL ("Dynamic Link Library") is a collection of subroutines (small programs) that can be used by many programs on your computer.This particular DLL is included with Version 7.1 of Microsoft's "C" programming-language.However, the appliation that tried to use the DLL is requiring a _newer_ version of that particular DLL.So, access http://support.microsoft.com to download and install the latest "runtime" library for their "C" programming language.
Jun 04, 2009 | Microsoft Windows XP Home Edition
Who to manuplate the date in java
Date arithmetic is relatively easy if you remember that time in JavaScript is measured in milliseconds. Use the date method getTime() to determine the number of milliseconds that have elapsed since the magic date of January 1, 1970. Use the setTime() method to establish a date you have calculated in term of milliseconds.
Danny Goodman, author of the JavaScript bible recommends that you set up some variables that build on each other to make it easier to do Date Arithmetic. Here is the variable setup that he recommends:
var oneMinute = 60 * 1000 // milliseconds in a minute
var oneHour = oneMinute * 60
var oneDay = oneHour * 24
var oneWeek = oneDay * 7
So for your case (date for 10 days after today), we can declare like this:
<SCRIPT language="JavaScript">
var today = new Date();
var mm= today.getMonth();
var dd = today.getDate();
var yyyy = today.getFullYear();
var oneMinute = 60 * 1000; // milliseconds in a minute
var oneHour = oneMinute * 60;
var oneDay = oneHour * 24;
var dateInMS = today.getTime() + oneDay * 10;
var TargetDate = new Date (dateInMS)
document.write("Today is: " + mm + "/" + dd + "/" + yyyy);
document.write("<br />");
document.write("10 days after today is: " + TargetDate);
</SCRIPT>
P.S.: If this information was helpful, please rate this solution.
Mar 12, 2009 | Microsoft Computers & Internet
Norstar CallPilot 100: need to change the time within the system to reflect daylight savings time
the time change goes off the system time to change system time press feature **7463 enter the admin password then press change and enter new time
Mar 09, 2009 | NorStar CallPilot 100
Programming the APS02BT2 remote
TO PROGRAM ADDITIONAL TRANSMITTERS:
1. Enter the vehicle, and turn the ignition key to the "on" position.
2. Press and release the valet push-button switch three times.
3. The dash LED will flash once, and the siren will "chirp" once, indicating the system is ready to accept programming for channel 1 or the arm/disarm and panic functions.
4. You can assign any of the three transmitter button functions listed below to channel 1.
a. Pressing button #1 on the keychain transmitter.
b. Pressing button #2 on the keychain transmitter.
c. Pressing both buttons simultaneously on the keychain transmitter.
5. Press and hold the selected choice a, b, or c above, until the siren emits a long "chirp" to confirm that programming of channel 1 was successful.
6. Press and release the valet push-button switch one time.
7. The dash mounted LED will flash 2 times, and the siren will "chirp" indicating that the system is ready to accept programming for the unlock/panic channel.(If you desire one button to control lock & unlock, move on to step 9)
8. Press and hold the selected remaining choice a, b, or c above, until the siren emits a long "chirp" to confirm that programming of unlock channel was successful.
9. Press and release the valet push-button switch one time.
10. The dash mounted LED will flash 3 times, and the siren will "chirp" indicating that the system is ready to accept programming for channel2, or the pulsed ground output for remote trunk release, remote car starter, etc.
11. Press and hold the selected remaining choice a, b, or c above, until the siren emits a long "chirp" to confirm that programming of channel 2 was successful.
12. Press and release the valet push-button switch one time.
13. The dash mounted LED will flash 4 times, and the siren will "chirp" indicating that the system is ready to accept programming for channel 3, or the additional pulsed ground output if available on your model. NOTE: If the program switch is operated again, the circuit will recycle through the program mode. In other words, press 1 time to access the lock function, 2 times to access the unlock function, 3 times to access the start function. When programming is complete, simply turn off the ignition switch to exit the program mode.
ERASING TRANSMITTERS IF THEY HAVE BEEN LOST OR STOLEN: NOTE: Before you begin to erase the lost or stolen transmitter(s), have all transmitters available that you wish to remain programmed. These will be used during the program process to identify transmitters that will continue to be used.
Enter the transmitter program mode:
1. Turn the ignition switch to the “ON” position.
2. Within 10 seconds, press and release the valet/program switch three times. (Siren emits 1 short chirp indicating channel 1 has been entered)
3. Within 10 Seconds, press and hold the ARM or ARM/DISARM but-ton of the first transmitter you wish to remain stored into the control unit until a single chirp is heard from the siren.(Repeat this for each transmitter you wish to remain stored in the control unit).The receiver stores up to four transmitters. To be certain all transmitter slots in the receiver are occupied with transmitters you wish to continue to use, and all others are erased, you will have to fill all four receiver slots. If in step 3 you identified one transmitter, you will have to fill the additional 3 slots. If in step 3 you identified two transmitters, you will have to fill the additional two slots, etc...
4. Press and hold any unused button or combination of buttons until a long chirp is heard from the siren. Release and press the button or button combination again and again until all remaining slots are full. NOTE: The button or combination of buttons entered will also control the armor arm/disarm function until additional transmitters are added. All unwanted transmitters are now deleted.
Feb 28, 2009 | Car APS02BT2 Transmitter for...
Write into excel format
Your code does not save in access format it just makes a copy of existing file. You need to open table by table and export data using csv format.
It can be done using access OLE to export, or
write some VB code to access the database tables via ODBC and save row data to csv file
Feb 17, 2009 | Microsoft Visual Basic Professional...
You can use ADO or SQL to open the excel file directly (provided it is constructed correctly, ie fields names) and write the data to it without Access.
That might be eaiser thatn converting it from Access to Excel, if that can even be done.
Feb 17, 2009 | Microsoft Visual Basic 6.0 for PC
MySQL Database
THE SYSTEM REQUIRMENTS ARE
MySQL Tools
1. A SQL server : This is an engine which provides access to your databases.
2. Client programs for accessing the server : A program allows you to enter queries directly and view results
3. A client library for writing your own programs : You can write your own programs into the client library using C.
Recommended Hardware Requirements For Mysql Installation
  1. Pentium V processor
  2. 128 MB RAM
Note that MySQL can be installed on a platform with as little as 32 MB
RECOMENDED SOFTWARE TOOLS for better performance
IT is recommended to have at least 128MB memory.
You can freely download MySQL from the website http://www.mysql.com MySQL runs on many varieties of UNIX, as well as on other non-UNIX systems, such as Windows and OS/2. MySQL runs on hardware from home PCs to high-end server. MySQL can be installed on Windows XP, Windows Server 2003, Red Hat Fedora Linux, Debian Linux, and others
Sep 08, 2008 | Sun MySQL
Microsoft Windows Vista Ultimate Edition Logo
54 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
