Question about Teac EQA-120 Home Equalizer
I have a yamaha rx-v663 receiver and a techical pro dual 10 band equalizer eq-b5100 and ican not get the equalizer hook up.
2 Suggested Answers
SOURCE: yamaha 5.1 receiverhookup to teac equalizer
record output from receiver to linein of eq,and line out from EQ to PLAYBACK of receiver Thank you very much albie 20
Posted on Sep 30, 2008
How do I connect my 901 equalizer /speakers to the yamaha rx-v633 receiver?
Sorry, it doesnt look like you can hook up an external EQ while still using the amplifier section of the yamaha. Instead, You would have to use the preamp out to go to 901 EQ, out of the EQ into another stereo amplifier, then to the 901 speakers. Personally, to power the 901's properly, I'd use another external amplifier. You will barley get 75watts per channel out of the receiver to power the 901's
Jan 03, 2015 | Yamaha Av Reciever Rx-v793 Cinema Dsp...
Yamaha rx v757 av receiver
tape out to line in on eq, line out from eq to tape in on receiver, use tape monitor switch to make eq work
Mar 14, 2014 | Audio Players & Recorders
I have a Yamaha HTR-5890 receiver and I am trying to hook up a Yamaha EQ-32 10 band graphic equalizer to the receiver. The frequency spectrum analyzer on the equalizer is working but the graphic...
must have the tape monitor to work the regular tape loop does not physically go back into the receivers processor.
only other solution is if the receiver has PRE out and ins use the PRE out to the EQ then back into the PRE in.
if you have the OUT but no in then the solution would be to go out of the EQ and into an external amp.
In my experience "young adults" like using EQ's to boast bass output.
If that's your goal a POWERED subwoofer is what you need.(check out polk audio direct on ebay)
Your unit is a 7.1 surround receiver the reason that it doesn't have the capability for an EQ is that it messes up the surround sound processor.
If the sound is not what you are looking for the issue more than likely is with the speakers. post a messege with what you want to achieve and I'll try to point you in the right direction.
Dec 29, 2009 | Yamaha HTR-5890 Receiver
How do I connect my Yamaha EQ-70 to my Yamaha RX-V2400 receiver?
from your receiver; R&L PRE OUT to R&L LINE IN of Equalizer.
And - from Equalizer R&L LINE OUT to Receiver MAIN IN.
http://www.yamaha.com/yec/customer/hookupdiagram.html?CTID=5010070.
Hope this helps!
Aug 10, 2009 | Yamaha EQ-70 Home Equalizer
I need to connect an equalizer (EQ-70) to a Yamaha RX-461 AV receiver which plays a Bose Acoustimass 6 Home theatre system. The Receiver does not have a tape deck. So ow do I go about it?
If your receiver has a TAPE IN you can connect the EQ to that, and it will work just fine. Or if you have main LINE OUT / LINE IN, you can create your loop there.
- OPTiC
Equipment Repair & Service
A DJ Pro Audio Co.
Dec 17, 2008 | Yamaha EQ-70 Home Equalizer
Hook up to Ritron EQ
record out-------equalizer in---------equalizer out-------playback in.
Sep 04, 2008 | Spectrum Technical Hifi EQ-B5100...
Conecting my EQ to my Yamaha reciever
your media out(dvd-cd-dat-deck player)-to equalizer in-and equalizer out to aux or cd in receiver.
Jul 17, 2008 | Yamaha EQ-70 Home Equalizer
Hi. i want to add a graphic eq to my pioneer receiver (home audio).
if the Eq has enough jacks to run every thing, that would go In to Eq an out to receiver, you were told correctly, for example cdplayer out - to Eq In - Eq- out to Receiver in
Nov 29, 2007 | Spectrum Technical Hifi EQ-B5100...
Equalizer hook up.
only hook up to tape monitor or else u wont get an audio signal . .....also hook all equipment to amplifier not eq ...it goes tape cd tuner and any type of external equipment to amp.then find tape 2 it sould be called tape moniter and have a separet botten for u to select it goes record to eq and play from eq
Aug 27, 2007 | Spectrum Technical Hifi EQ-B5100...
Teac EQA-120 Home Equalizer Logo
211 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
