Question about Pioneer CDJ-800 Turntable
Turn on turntable the vinyl button doesnt wrk
They have just been moved from 1 house to another in the flight case & 1 works but the other 1 i can play cds on it but it wont change to vinyl & the other lights dont come on can you help please!!!!
  • 515 Answers
This is a tough one. Sounds like physical damage. You'll need to take it to a service center for repair.
- OPTiC
Pioneer DJ Repair Videos
Pioneer DJ Repair
Pioneer DJ Parts
DJ Parts
DJ Equipment Sales
Audio Video Accessories
Posted on Apr 30, 2009
Needle jumps on all new vinyl, but plays old records fine. New vinyl plays on other turntables without a problem. Do you have any suggestions?
Adjust the balance force up. This is a counterweight on the back of the arm. For most needles it is 1-2 grams.
Jul 06, 2014 | Crosley Audio Players & Recorders
Crosley CR249 warped table
Sounds like you need a new platter. Has the platter worked OK before or has it always been like this?
I suspect you might have to contact Crosley to see who supplies parts.
Jan 10, 2013 | Crosley CR249TA Turntable
Technics sl dz 1200 no vinyl play
is anybody have solution for this? i have the same prob...
Apr 11, 2012 | Panasonic Technics SL-DZ1200 Turntable
Hi. I have a Crosley CR40 mini turntable. When I turn on the power, the vinyl spins but when the needle is placed on the vinyl, the vinyl doesnt move anymore while the spinner underneath it is still...
It sounds like you have too much pressure on the tone arm. Check the underside for springs. You might be able to remedy the problem the old fashioned way. Tape a coin onto the top of the tone arm, as far to the rear as possible. This will eliminate some of the downward pressure onto the record.
May 07, 2011 | Crosley Stack-O-Matic CR40 Turntable
800 mk 1 plays in cd mode but once vinyl button is pressed play stops. even if I press the play button. The unit still jogs fwd and back just fine in vinyl. The case i use on occasion puts pressure(maybe...
You are almost certainly correct re "pressure switches"
Pioneer call this part "sheet switch" and it is a circular plastic "sandwich" of multiple contacts and when constant pressure is put on it, it tends to stick together giving the effect you are pressing it when you're not.
The part will cost you about £30.00 + fitting - unless you are confident enough to do it yourself
email me if you would like to order one. mail@technicsdjuk.com
http://stores.ebay.co.uk/methleykev
Jun 25, 2010 | Pioneer CDJ-800 Turntable
My Pioneer CDJ 800 MK 2 - will not play in the vinyl mode, the cue button is flashing _ if i take it out of vinyl mode it will play fine , do i need to reset it?
Does the unit play in vinyl mode if you turn the platter by hand?. If this the case the commom fault in the "sheet switch" which is under the platter and sensors the pressure when you press the platter.
The "sheet switch" and it is a circular plastic "sandwich" of multiple contacts and when constant pressure is put on it (i.e something is sat on it for a long time), it tends to stick together giving the effect you are pressing it when you're not.
May 14, 2010 | Pioneer CDJ-800 Turntable
Turntable wont spin
If everything seems ok with the power , there is usally a small microswitch that sends power to the motor when the tone arm is moved to the start of the record.
The switch might be bad or the lever that actuates it (connected to the tone arm) might be sticking. You may have to take the bottom cover off or remove the platter to see it.
Also make sure the belt is looped over the motor shaft. If the motor runs but the belt still doesnt turn, belt might be bad.
Mar 10, 2009 | Technics SL-BD22 Turntable
Operating instructions for Onkyo PL-25F turntable
I have the same problem with mine! If i budge the arm by pushing it to the left a bit, it seems to catch. i think the motor on mine is worn out and cannot get started on its own, but with help, it will slowly move on its own to the edge of the vinyl and drop into playing position. If that doesnt work for you, you might need to clean the belt for the arm motor, or buy a new motor.
Mar 08, 2009 | Audio Players & Recorders
Pioneer CDJ-800 Turntable Logo
140 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
