Question about Whirlpool MH3185XP Microwave Oven
Have a Whirlpool microwave oven, model MH3185XP. Just stopped wor
I have a Whirlpool microwave oven, model MH3185XP. Just stopped working - microwave, fan, lights, clock - everything. Power source is ok.
  • Anonymous Mar 28, 2014
    just stopped working-no power
  • Whirlpool Master
  • 9,086 Answers
In some Whirlpool models, there are more than one fuse, and two or more thermal devices which can interrupt power to the oven.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
have a Whirlpool microwave oven, model MH3185XP. J - d:%5cele%5crepair%5cmicrowave%5cge_hotpoint%5cmini_manual_behind_grille_small.jpgdee77f7.jpg
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Please write back with more details if you need further help.
Posted on Mar 02, 2009
My MH3185XP microwave oven will not turn on. Power is to unit. I changed the fuse inside key pad (clear fuse) but still no luck. Suggestion?
In these models, there are several fuses and two or three thermal cutouts / thermostats which need to be checked.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden behind the grille, which is very helpful when troubleshooting, testing, and locating components.
If you don't find your mini-manual, or if you want to look at it before removing the controller, you can download it here (just enter your full model number from the label on your oven).
Accessing some components for testing and possible replacement will require you to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download owner's manuals and installation instructions for several brands (including Amana, Frigidaire, Jenn-Air, Kitchenaid, Litton, Maytag, Roper, Tappan, Thermador and Whirlpool) here.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
May 27, 2010 | Whirlpool MH3185XP Microwave Oven
Hello, I have the whirlpool microwave oven, Model ...
logic board needs replacement if it cannot be reset.
Jun 17, 2017 | Whirlpool MH3185XP Microwave Oven
My Russell Hobbs microwave will not generate heat
If everything else is normal, the trouble may be a failed magnetron tube (the microwave source), problems on the control circuit board, or parts in the tube power circuit that are bad. It's also possible a door switch can be at fault, but this usually keeps something else (fan, turntable or light, most often) from running as well.
Microwave servicing is best left to professionals. There are potentially deadly voltages present, and a chance of microwave leakage if repairs aren't done correctly. Take the oven to a shop for an estimate, or just consider replacing it if it isn't a built-in, an over the range unit or a high-end countertop model.
Feb 02, 2010 | Microwave Ovens
I have Whirlpool Microwave oven Model MH6110XEB-0 that has completely loss power. The outlet it is plug itno is still good with power running thru the outlet. I do not have any manuals for the microwave,...
with any luck you have just poped the inline fuse,
if you remove the control board you should be able to see the tube fuse up by the fan motor
if not the whole thing will have to come down to reach it
Oct 14, 2009 | Whirlpool MH3185XP Microwave Oven
Whirlpool microwave MH3185XP: cancel button does not work
The symbol next to the Cancel pad means it would also be used to turn the Child Lock feature on and off.
But as it is, you have a failed membrane keypad.
Luckily, on these models you can replace the control panel frame with keypad all as one unit without doing any peel & stick.
Just remove your circuit board and drop it in the new frame.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
(There are 12 models which start with MH3185XP, so check the tag on your oven for the full model number.)
See reference number 3 on diagram number 3.
Jan 29, 2009 | Whirlpool MH3185XP Microwave Oven
Unit is completely shut down
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Jan 07, 2009 | Whirlpool Microwave Ovens
Whirlpool microwave Model # MH3185XP No power?
I just had a problem with mine and took the panel off and did find a fuse on the inside on the top portion of the unit. Try changing it and see if it works. Hope it helps.....
Dec 29, 2008 | Whirlpool MH1150XMQ Microwave Oven
After changing a blown oven light, the clock works but nothing else turns on, including the fan, light, microwave
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, linked here on Fixya:
http://tinyurl.com/yzjozk
Nov 27, 2007 | Whirlpool MH7135XE Microwave Oven
Whirlpool MH3185XP Microwave Oven Logo
517 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
