Question about Homelite Consumer Products 9.0 Amp, 14 In. Chainsaw
I have a homelite 240-hg I cant get it started i
I have a homelite 240-hg I cant get it started i regaped the spark plug and cleaned same added new fuel at ration 32-1 to 50-1 still did not attempt to start what do you suggest to try this saw is about 18 yrs old
  • Anonymous May 18, 2009
    my homelite 240 has no spark can anyone explain why
  • Thomas F. Schneider May 11, 2010
    Does it have spark? Does it try to start if you spray a tiny bit of started fluid in the carb? Been siiting a long time w/o use?
  • 137 Answers
Try some starter fluid (eather) that wil give you an indication if it's ignition or a fuel problem.
Posted on Feb 28, 2009
Why won't my raining lawn mower not start?
Check oil level, take off the spark plug clean it and regap and or buy new one and regap. Take carburator off and clean it. Test coil and ignition switch. Clean gas tank and fuel lines. There could be a lot of other things to check. It could be a safety switch, dirty cables,bad battery or bad wiring. It could just be a loose wire that's not grounded.
Sep 04, 2014 | Murray Garden
I have a old homelite that won't start new plug fresh gas no spark
Most of the time on older engines, the carb needs to be rebuilt or replaced. Dont panic rebuilding is cheap an easy. The ports get clogged up sitting an varnish up. Try to clean out all orifices with small pieces of wire from steel or brass brush. Use carb cleaner to clean replace all gaskets an parts with kit. Dont forget to check fuel hose in tank they go bad often an should be replaced when carb work is done. Fresh gas an it should work
Mar 11, 2014 | Homelite Garden
Yard machine weed trimmer y25 will not start
Clean and regap the spark plug or replace it!! Spark is weak. Plug should NOT be wet unless engine is flooded or plug is not functioning properly!
Mar 02, 2014 | Garden
No spark on a 126T020675B2 Briggs 6.75 hp mower engine
gap needs to be 10 thousands of a inch done with a brass feeler gauge ..mag/flywheel has a spot with a magnetic field if you look you can see it it should make a 1/2 wrench stick to it if not replace mag/flywheel ..check key way also
Jun 05, 2013 | Mtd 22" Yard Machine Push Mower
Homelite 240 20" oil blowing out exhaust
Your machine need s a complete overhaul.Gas & oil out of exhaust is problably due to wear piston rig and camshaft.
Oct 25, 2011 | Garden
Weak spark,willnot start,changed plug
A weak spark can be attributed to a number of issue:
1. Wire from the magnetto to the spark plug is saturated with oil (clean well with degreaser)
2. Spark plug cap deteriorated. (most are not easily replaceable)
3. Spark plug fouled (insure you are using new)
4. Significant build up of rust on the flywheel (lightly sand rust off)
5. Bad Magnetto or CDI (especially if it has gotten wet or is cracked.) Note: (Cost typically prohibitive for replacement).
6. Spark plug gap significantly out of specs. (Regap to specs, retry)
If you are certain you have a weak spark, these are typical causes. Often, more likely problem is carburation, fuel filter and/or fuel lines - which are much easier and less expensive fixes! Hope for the fuel lines being cracked...Good luck :)
Sep 25, 2010 | Garden
I have a homelite blower model UT08580. I have replaced the tank (cracked) and the carburetor,I have spark but will not start... suggestions?
Make sure you have a new air filter, new spark plug and fresh fuel. Then get a can of starter fluid and a helper. Squirt some starter fluid at the air intake and start it. Have your helper continue to squirt the starter fluid to keep it going as this will clean out the entire combustion chamber. J.
Jul 31, 2010 | Homelite Garden
Diesel fuel in homelite leaf blower !
this is not a problem
you need to remove all the fuel
and remove your spark plug add new fuel and with the spark plug out pull it over many times to purge the system now install a new spark plug and you will be fine
Nov 25, 2008 | Homelite Consumer Products MightyLite...
Homelite Consumer Products 9.0 Amp, 14 In. Chainsaw Logo
404 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
