Question about Car Audio & Video
Changing steroes i have a 1993 ford fairlane with a alpine premium stereo system in it. I want to remove that radio and install an after market one in its place, the problem is that i dont know what wire does what and that the factory stereo has a sub woofer in it system and i cant find any trace of the amp so that i can get the rear speakers to work on the new stereo. I would appreciate some help. Cheers....
  • 4 Answers
Red(is power, Orange(is led power Black(is ground
Their should be a bunch of other wires with light colors that are your speakers. If this info don't match. Buy a power tester and ground it and test each wire.
Posted on Feb 28, 2009
Lost power to the stereo unit and the door dingers
you original car stero could have been creating a power loop and that may be the reason, or maybe you caused a shorth while removing the old stereo, check you radio fuses, hope this helps
Nov 17, 2011 | 2003 Oldsmobile Alero
My daughter has a 90 Thunderbird that had an original premium sound package. The stereo went kaput and she bought an after market replacement. I went to install it for her and unfortunately opened up a...
These cars have a factory amp system that will not operate correctly with an aftermarket stereo. You have two choices. You can either run new wires to the speakers your self which would bypass the factory amp. Or you can order the premium sound system Interface here http://www.myinstallkit.com/FORD/1990%20(90)%20FORD%20THUNDERBIRD%20Radio%20-%20Stereo%20Installation%20Kit.htm scroll about half way down the page.
Jan 25, 2011 | 1990 Ford Thunderbird
I am tryin to remove the factory radio from a 2000 Nissan Altima and install an aftermarket radio. but i cant seem to figure out a way to get the trim panel around the radio and HVAC module out. And i can...
  • disconnect the negative battery cable from the Altima's battery.
  • 2
    Pry up the trim panel surrounding the gear stick. The trip panel is held in place by plastic clips that will disengage when the panel is pried up. Use a flat-head screwdriver to pry up the panel. The panel doesn't need to be completely removed, just pried up enough to reveal two Phillips screws along the bottom of the radio trim panel.
  • 3
    Remove the two Phillips screws along the bottom edge of the radio trim panel, just above the gear stick. Remove the two Phillips screws from above the radio. Remove the ashtray.
  • 4
    Pry the radio trim panel loose with your fingers or a flat-head screwdriver and remove it.
  • 5
    Remove the four Phillips screws holding the radio in place. Set the screws aside for use later. Slide the radio forward and disconnect the wires from the back of the device.
  • 6
    Slide the cage included with your new stereo into your dash adapter. Slide the stereo into the cage and dash adapter.
  • 7
    Connect the wires from the dash to the back of your new stereo. All stereos have slightly different connections methods, so refer to the owner's manual accompanying your new stereo for the proper connection procedure.
  • 8
    Slide the stereo and dash adapter into the dashboard. Use the previously removed Phillips screws to mount the stereo in place. Replace the radio trim panel and gear stick trim panel. Reconnect your battery.
  • If you are putting a aftermarket stero make sure you buy a stero harness that plugs into the cars harness, on the back side of the harness you just installed will have open wires to conet to your new stero. If you cut the wires from your car to try to splice it to the new raido it can cause problems with the electrical system includeing making the transmission shift or act funny. you can pick the harness at wall-mart, car auido, best buy, or any car auido place.
  • Dec 22, 2010 | 2000 Nissan Altima
    I want to change the radio in the 2006 Ford Explorer
    go to auto parts store and get the ford stereo remover tool and if your going with an after market stereo it would be wiser and easier to buy the stereo wiring instalation kit to...with the remover tool you stick on in the 2 holes on the left side of the stereo and the other in the holes in the right side holes just push them in firmly than not very hard but with steady pressure pull the left one to the left and right one to the right and than while still pulling them apart slowly start pulling stereo out
    Nov 04, 2010 | 2006 Ford Explorer
    It seems as my stereo is locked up. I can't
    Your question is lacking some detail , is this a stock radio , after market , and what brand and model . Pictures can help , depending on the siuation code be s radio key is needed or if it's after market do you have a remote ? Try to change stuff with that , could be buttons inop or worst case it's just done. Good luck
    Aug 31, 2017 | Alpine CDA-9884 Car CD/ MP3 Player
    What kind of wire do I need to install Infinity reference series 605cs with a JL Audio 10" sub and a Alpine Flex 2 amp? Can I use my factory head unit?
    You can use the factory speaker wiring for the Infinity speakers you should purchase a amp kit which will give you everything to install the amp. See site below
    http://www.sonicelectronix.com/item_18428_Raptor+ISPKBL4-BG+by+Metra.html
    Well that all depends on the current audio system you have now is it just a basic or a premium factory system with a factory amp. Honestly you would get a better and cleaner sound if you change the factory head unit to a after market one which has preamp feeds and the higher the preout volt the better. Just make sure it is compatible with the amp volts input (Example 4v to 250mv) If you use the factory headunit you would have to by a high to preout adapter it connects to the exsiting radios speaker leads, but like I said before change the head unit you won't be sorry. Do not forget if you change the radio you need a radio install kit and the wiring harrness which converts the two radio plugs so you don't cut them so down the road you can remove the after market radio and just replug the factory right back in.
    Apr 16, 2010 | Infinity Reference REF 605CS Car Component...
    I need a wiring diagram for the stereo and eq of my 93 ford probe
    Digital Audio Compact Disc Player
    Section 15-01: Radio, Tape Chassis and Digital Audio Compact Disc Player 1996 Probe Workshop Manual
    REMOVAL AND INSTALLATION Compact Disc Player, Digital Audio SPECIAL SERVICE TOOL(S) REQUIRED Description Tool Number Radio Removing Tool T87P-19061-A
    Removal
    1. Disconnect the battery ground cable (14301).
    1. Remove the instrument panel finish panel (044D70). Refer to Section 01-12 for the removal procedure.
    1. Insert the Radio Removing Tool T87P-19061-A into the face plate holes until the tension of the tool locking into place can be felt. (There are tension clips that this tool pushes out of the way so the radio can pull out. Maybe you can insert 4 pins that will do the same thing.)
    1. Flex outward on both sides of the radio chassis (18806) simultaneously and pull the radio chassis from the instrument panel (04320) using the tool as handles.
    1. Disconnect the electrical connectors and the radio antenna lead in cable (18812) from the radio chassis.
    Mar 17, 2009 | 1993 Ford Probe
    Wiring diagram 1996 ford explorer premium sound radio f57f-19b165-ag
    Here it is.
    1996 Ford Explorer Car Stereo Radio Wiring Diagram
    Car Radio Constant 12v+ Wire: Green/Violet
    Car Radio Switched 12v+ Wire: Yellow/Black
    Car Radio Ground Wire: Black/Light Green
    Car Radio Illumination Wire: Light Blue/Red
    Car Stereo Dimmer Wire: N/A
    Car Stereo Antenna Trigger: Orange/Blue
    Car Stereo Amp Trigger Wire: Blue (If Equipped)
    Car Stereo Amplifier Location: N/A
    Front Speakers Size: N/A
    Front Speakers Location: N/A
    Left Front Speaker Positive Wire (+): Orange/Light Green
    Left Front Speaker Negative Wire (-): Light Blue/White
    Right Front Speaker Positive Wire (+): White/Light Green
    Right Front Speaker Negative Wire (-): Dark Green/Orange
    Rear Speakers Size: N/A
    Rear Speakers Location: N/A
    Left Rear Speaker Positive Wire (+): Gray/Light Blue
    Left Rear Speaker Negative Wire (-): Tan/Yellow
    Right Rear Speaker Positive Wire (+): Orange/Red
    Right Rear Speaker Negative Wire (-): Brown/Pink
    Sep 29, 2008 | 1996 Ford Explorer
    I need the colour wire description for a 2000 dodge caravan Im removing the the factory stero and installing after market stero and need wring diagram , what each wire is for ,speakers ,power etc.
    HI.
    In the caravan are 2 types of Radio.
    1. Normal sound system.
    1 Premium sound system.
    Note: If you don't want to cut the original wires,
    You can buy a harness connector to install the aftermarket Radio. The connector are made by aplication, and are plug in.
    The colour of the connector are the same colour with the Aftermarket Radio. Just you need to soldering or just put joint connectors.
    Normal: colour of wires.
    Pink = Battery voltage.
    Red/withe = Ingnition Voltage.
    Brown/red and Dark green. = Left front speaker.
    Dark bku/red and Voilet = right front speaker.
    Brown light blue and brown/yellow. = left rear speaker.
    Dark blue/orange and dark blue white = right rear speaker.
    Ground is a single wire behind the radio.
    If you have a premium sound. You need to use the front speaker out to connect the speaker on the door and the speaker on the dash. To complete the 6 speaker.
    OK... I hope this information work for you.
    Thank you , For use fixya. Rate please.
    Jul 17, 2008 | Car Audio & Video
    Car Audio & Video Logo
    98 people viewed this question
    Top Car Audio & Video Experts
    xxxxxx xxx
    Are you a Car Audio and Video Expert? Answer questions, earn points and help others
