Question about Whirlpool GD2SHGX Refrigerator
GE PFSS6SMX french door fridge water dispenser not working
This is a brand new PFSS6SMX GE Profile french door refrigerator. The water dispenser was working for about a half hour after getting it installed. There was a slight leak at the top where the hose coupling comes out of the case to the door. I tightened the hoses and the dispenser continued to work fine. I then tried to use the water dispenser about an hour later and it malfunctions. It only spits out about an ounce of water, at pretty much the full pressure rate but then cuts back to a mere dribble. If I wait about another half hour it'll do the same thing. But in the interim it's still just the dribble. The ice maker appears to be making ice, just not much. The water that it spits out isn't particularly cold. Before I drag the service people out is there something I can check?
  • Bill Kearney Feb 28, 2009
    I asked this is in the wrong section, sorry about that.
  • Bill Kearney Mar 21, 2009
    The tapped fitting was there from the previous fridge and was not changed. It wasn't even turned off during the swap, as I used the whole house shut off instead.
    The problem turned out to be a kink in the line at the back of the fridge. I rearranged the line by using, of all things, a yardstick to push it into a better position when pushing the fridge back into the cabinetry. It's worked fine since.
  • 700 Answers
Check the fiting where you tapped the water for the uit. If its a saddle valve what happens is the the gasket closes down and restricts the water flow.
Posted on Mar 21, 2009
  • Todd Born
    Todd Born Mar 26, 2009
    glad that it was a easy fix.
Water Dispenser on GE Profile Bottom Freezer Refrigerator Not Working
When you press the water dispenser button, do you hear a noise like water is trying to come as usual. If so then your problem might be frozen chill water tank or failed chill water valve. If you don't hear the regular noise then the problem might be with the dispenser unit.
Nov 26, 2013 | Star Manufacturing GE Profile PFSS5NJX...
GE Profile PFSS5NJWA SS water dispenser not dispensing water. I tried changing the filter, but it still does not work. I also tried pressing the "reset filter" button. When I press the water...
We have the same model and just had exactly the same problem. The coil behind the fresh produce trays is frozen. There are 2 coils, one provides water for the water dispenser and the other to the ice maker. Looking into the fridge the water dispenser coil is on the right hand side. We unplugged the fridge for a couple of hours and the problem has been solved. Try increasing the temperature of your fridge by a degree or two.
Feb 17, 2011 | General Electric PFSS5NJXSS Stainless...
Brand new GE Profile GFSF6KKYCBB French Door with external ice and water dispenser. After filling a glass of water, pull the glass out and water turns completely off as expected. Two seconds later, the...
Sorry to read about your problem, I hope this helps you out.
factory defective, call in warranty service
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 22, 2010 | GE GFSS6KKYSS (259 cu ft) Bottom Freezer...
I've had a GE Profile side by side (model # GSS25SGPCSS) with in door water and ice dispenser for approx. 6 years. This week the in door water dispenser stopped working. I removed and replaced the filter...
I have the same fridge and the water line freezes up in the door on a regular basis. I have to use a hair dryer and slowly wait for it to melt. It takes about 30 minutes and then works fine for awhile. It has become quite a habit that I'm not thrilled about. Don't waste your money replacing the board or anything else. GE was no help and I'm now shopping for a new fridge bc of this issue. Needless to say that it won't be a GE! Hope this helps.
Oct 09, 2010 | GE Profile Performance 25.2 cu. ft....
WATER FLOWS TO ICEMAKER BUT NOT TO WATER DISPENSER,TEMPERATURE ON THE FRIDGE SIDE WILL NOT STAY AT 37
if the tempt gets to low it will freeze the water blater and you know what ., the control will have to be repl to stablize tempt . m m
Nov 20, 2009 | GE Profile PFS22 33" Artica French Door...
Water build up on inside of fridge door of ge french door fridge
humid air in the house. any time you open the fridge, house air is sucked in. when you close it, the fridge cools the air and moisture from the warm air condenses on any cold surface. also check to see if there is a gap in the seal.
Aug 26, 2009 | GE Profile Bottom-Freezer Refrigerator...
Water dispenser quit working on GE Profile French door 'frig.
The dispensers could be clogged with mineral deposits. If you look in your care manual it talks about a water vinegar solution that you pour into the top of the despenser, let sit, and then drain it through the back. I had a similar problem and it was because some of the water that was sitting in the top of the unit(where the gallon jug sits; under the black think) was full of frozen water which was blocking the water dispenser.
Apr 29, 2009 | Refrigerators
Ice/water dispenser drips after using
afraid that sounds exactly like the problem.brand new fridge call who you bought it from they should fix it for free good luck hope this solves your problem
Aug 24, 2008 | GE Profile PSW26P Stainless Steel Side by...
Whirlpool GD2SHGX Refrigerator Logo
358 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
