Question about Altec Lansing VS3251 Speaker
How to connect the altec lansing speakers
hi,
i have bought a altec lansing VS3251 speakers from my someone,and i don't get how to connect them because i only have the wires i mean to say the three PIN wires and i dont get how to connect it to my computer , I mean to say i can only connect one Speaker and One Subwoofer.it would be grateful if you help me out....
5 Suggested Answers
early1234
  • 871 Answers
SOURCE: surround wont work
try and download sound softwares from majorgeeks.com.
hope this works.
Posted on Jan 14, 2008
  • 4 Answers
SOURCE: What's the volt & amps of Altec Lansing AVS300 2.1 speaker system
Your adapter is Part No. AVX300-A6859, Model No. 9701-00748-IUND.
Or You could get a universal that is rated for output of 18volt DC, 650ma, Center Positive.
I have used a 15volt DC, 900 ma with no problem, but I never run the volume high.
Good Luck
Posted on Dec 04, 2008
  • 3 Answers
SOURCE: Altec Lansing ATP3 Speaker System Not Working
try to replace the power-amplifier TDA7377
Posted on Mar 08, 2009
SOURCE: need wiring and 9pin connector diagram
Dell (Altec Lansing) A425 Subwoofer Pinouts
This is a standard female DB-9 serial port.
Here are the pinouts.
Pin 1 = Left Speaker Out +
Pin 2 = Left Speaker Out - (Common Ground)
Pin 3 = Left Line In +
Pin 4 = Right Line In +
Pin 5 = Left/Right line In - (Common Ground)
Pin 6 = Right Speaker Out +
Pin 7 = Right Speaker Out - (Common Ground)
Pin 8 = Power A
Pin 9 = Power B
Jumper (short) Power A to B to turn on.
If you want a volume control you need to put one on the inputs. You will buy buy a stereo volume control or potentiometer.
Here is some info on how to do this.
http://g4tv.com/screensavers/features/43665/Pump-Up-The-Volume.html
Cheers!
Posted on Mar 24, 2009
SOURCE: Can the Altec Lansing VS3251 5.1 work with a Xbox?
Because this system is made to work with the PCs, it has a 3.5 mm stereo input. The 360 has rca cable outputs. Fortunately, the signal is the same and all you need is a 3.5 mm to rca y adapter that you can find at radioshack or any local electronics store.
Posted on Apr 16, 2009
The remote of my Altec Lansing vs3251 doesn't work anymore? Why? How can i fix it? :(
Did you get a solution of this problem? I am also facing the problem.
Aug 11, 2011 | Altec Lansing VS3251 Speaker
Can I connect this to my tv? If so how-can't figure out how.
Sure, if your TV has some kind of audio outputs (and volume controls) for the "audio 5.1 inputs" you see in this picture.
http://rosario-cavite.olx.com.ph/altec-lansing-vs3251-5-1-speaker-rush-3-8k-19-days-old-iid-24919817#pics
You COULD adapt the probably-present stereo audio from your TV for use with the front channels . Stereo.
May 12, 2011 | Altec Lansing VS3251 Speaker
Altec Lansing VS3251 rear left channel not working
Sounds like you "blew" the left channel. Make sure your connections are good, and all positives and negatives hooked up the way they are meant to be. If it still does not work, take it to be repaired. Call around first, with the AND serial number. Get repair estimates, ask about the "bench charge"
Apr 11, 2010 | Altec Lansing VS3251 Speaker
I have connected my philips 5.1 channel dvd player properly with Altec Lancing VS3251 speaker 5.1.There is audio output from the front speakers but there is no audio output from the rear left/right and...
to get 5.1 you need to have an optical/co-axal/hdmi input in to the speakers to get 5.1 and then the dvd player must have one of them as an out put
hope that helped
Jun 18, 2009 | Altec Lansing VS3251 Speaker
Apr 14, 2009 | Altec Lansing VS3251 Speaker
My philips dvd player 5.1 have female ports at back side for audio but i have the sound system of LG which has simple naked wire to connect .
Philips DVP 3256 has 6 outputs which takes in RCA connectors
Altec lansing VS3251 has 3 STEREO outputs.
Buy 3 nos of STEREO (female) to RCA (male) cables
1. Connect the Altec's green wire to first stereo-to-RCA cable. RCA ends to DVP 3256's Front left and Front right
2. Connect the Altec's black wire to second stereo-to-RCA cable. RCA ends to DVP 3256's Rear left and Rear right
3. Connect the Altec's orange wire to third stereo-to-RCA cable. RCA ends to DVP 3256's Centre/Sub woofer. Interchange RCA ends if the Subwoofer sounds dull.
Good Luck
Jan 29, 2009 | Altec Lansing VS3251 Speaker
Surround wont work
hope this works.
Jan 05, 2008 | Altec Lansing VS3251 Speaker
Altec Lansing VS3251 Speaker Logo
264 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Brian Sullivan
Brian Sullivan
Carlos L. Burgos
Carlos L. Burgos
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
