Question about Sony Playstation 3 (PS3) Console
New hard drive on ps3
I have just installed a new hard drive on my ps3 but it just says "the system software can not be run correctly. Press the PS button to try to restart the system.
If the system can not be restarted, The system partition of the hard **** must be reformatedand you must reinstall the system software.
Insert storage media that contains update dater of version 2.60 or later, and then push the start and select buttons at the same time.
(I have already formated the new hard drive to fat 32 and backed up my existing files. I have also downloaded the latest update avalible for the PS3 on to my newly formated hard drive.)
Please advise
Regards Robert Smith
  • 2 more comments
  • robertsmith4 Feb 28, 2009
    i have already done this to the new hard drive. i have also tried loading it off of the old hard drive in a enclosure. but still when i turn it on it still shows the same message!!! please help!!
    i have the controller hooked up to the usb. i have the new hard drive in the ps3 which i have installed the 2.60 update and backed up my files still says the same message when turning on the ps3. or do i have to place the new hard drive into the ps3 start it then plug in a flash drive which contains the 2.60 update?
    i dont have a flash drive to save it to so i saved them to the new hard drive. i have also plugged my old hard drive into the pc to save the update on there but i will have to format it before the pc will recognise it but it contains all my files from my ps3!
  • Anonymous Mar 17, 2014
    it comes up systemsoftware cannot run correctly and that system storage must be reformatted and need to re install system software to connect with a storage MEDIA THAT CONTAINS UPDATE DATA OF VERSION 4.41 OR LATER
  • 2,653 Answers
You're almost there Robert.
What the PS3 is asking for is this:
PS3 Firmware 2.60
You've got to download it and then place it into two folders like this on an external hard drive or thumbdrive or cd if that's all you got.
If you look at the instructions you'll see what I'm talking about. Make sure the folder names are all capitalised or else it won't work.
Once you have this in place press START and SELECT on the controllers and it will allow you to format the hard drive.
Let me know if you get stuck or have any more questions.
Best of luck!
Posted on Feb 28, 2009
  • RescueTechLA
    RescueTechLA Feb 28, 2009
    There is only ONE way to do it. So let's try to figure out what we're missing.
    Have you got the PS3 controller hooked up via the usb cable?
    Have you already downloaded and placed the PS3UPDATE.PUP file in the folders like I said, PS3->UPDATE----(firmware) ?
    You've got to make sure the thumbdrive / external drive is plugged in with the correct files in place.
  • RescueTechLA
    Yes, you've got to have the NEW hard drive in the PS3 AND the USB Drive with the firmware update file in the folders like this:
    The folders have to be named in CAPS
    the ps3 firmware file goes into the UPDATE folder.
When playing ps3 it keeps freezing
Hard Drive
If your PS3 lags or freezes when loading content from the hard drive, the drive either lacks free space or is faulty. To create more space, try removing items from your hard drive or getting a new hard drive with a higher storage capacity. A faulty hard drive must be replaced.
PlayStation 3 Troubleshooting
Apr 21, 2014 | Sony Playstation 3 (PS3) Console
I try to download the new version of the system software 3.56 but i only get to 72% of it and it tells me error occured and gives me the number 8002f997
Try accessing the recovery menu 'safe mode'.
Press and hold the power button until the systems shuts off. (wait 2 seconds)
Press and hold the power button again until you here 3 beeps. Let go.
It should ask you to connect your controller via usb and press the PS button in
the middle of your controller. There will be a menu with 6 options.You need 6.
You will need to have the latest firmware on a usb stick. Download the firmware from the playstation official website onto a usb stick. Once prompted by your system you will need to insert the usb stick into the PS3. Good luck..
If this doesn't work:
Your HARD DRIVE (aka: Hard Disk), located on the left side of the unit, has crashed. You will need to replace the HD.
When you replace your hard drive, you will need to have the latest firmware on a
PS3. Good luck..
You will need 2.5" Sata Hard Drive.
Jan 28, 2011 | Sony Playstation 3 (PS3) Console
My ps3 has stopped working! It says: "Cannot start. Correct hard disk not found." Please, please, please can you help??? Many thanks, Mark & Michelle
Ouch, Bad news Mark and Michelle. This is a fatal error on the hard drive. Basically, the hard drive needs to be replaced :( Sorry
Aug 12, 2010 | Sony Playstation 3 (PS3) Console
My ps3 froze during the installation of firmware 3.01 and i can not do anything with it says to press ps button but nothing happens
Turn off the PS3 and then turn it on. Try to restore the PS3 to factory defaults. If that doesn't work then try to save any data you need off of the hard drive and format the hard drive. This will erase any bad downloads and firmware updates that the system was trying to do.
Apr 29, 2010 | Sony Playstation 3 (PS3) Console
How do i fix error 8002f1f9
1. reset ps3 to defaults using recovery menu. 2. begin installation using the same fw version. (hard disk must be formatted externally if u get error 8001002b)
3. when it hangs @ 73% or whatever. Shut down and remove the drive
4. begin the installation of the system inserting the drive into another ps3
5. after it reboots, press (PS), at the disclaimer shut down, remove the drive and put into the broken ps3
6. boot ask to format the drive...
Jan 12, 2010 | Sony Playstation 3 (PS3) Console
Wont start messages comes up saying correct hard disk not found
your hard drive may be dying. or the file system may be corrupted.
before you get a new hard drive there are some tricks to try.
#1 remove the HDD and boot it up without it in, then turn off and put the HDD back in and boot again.
#2 rebuild the file system in the recovery menu
#3 rebuild the database in the recovery menu
To get to the recovery menu you need to press and hold the power button when the ps3 is in standby mode untill you hear a double beep then release. sometimes the ps3 will go back to standby mode before it does the double beep if it does just release the button and press and hold again real fast and wait for double beep.
here is what mine does
ps3 standby(red light) press hold power...........beep...............beep.........standby again, release hold............beep..................double beep ..release power button.
from the recovery consol you can rebuild the file system and database sometimes when they are corrupted it has same symptoms as a dying HDD.
P.S. rebuilding the file system and database will not lose any of your ps3 data, other options will though like the restore ps3 and format HDD.
if the above tricks dont work try updating the firmware, if your at the current firmware you can re-install it from the recovery menu as well using a usb memory stick or a cd with the firmware on it.
if all that doesnt help it looks like its time to get a new HDD, but at least you can upgrade it to a bigger ps3 now. any sata laptop HDD should work. i think a 160gb HDD is only $50ish.
Oct 08, 2009 | Sony Playstation 3 (PS3) Console
When turned on msg says can't start correct hard drive not found
ok I have the best solution for you you need to do the follow in order to solve this problem ok My name is Juan and I am a ps3' proff so don't worry this is fixable in a portable usb card reader install the newer ps3 update go to sony and in your usb created a folder with the name PS3 in capital letters and inside this folder created another folder with the name UPDATE and download the update on this folder once you have the update ready connect the usb storage device to your ps3 turn the ps3 on and press the PS logo on your ps3 control then on the next screen press STAR and SELECT at the same time and the ps3 is going to start looking for the update follow the instactions and then some model on the next screen you have to press again SELECT and START at the same time but this time hold them for 5 seconds and the update will start after the update finish it will start normally if you have problems doing this call me at 706 529-0579 and ask for juan thanks
Mar 11, 2009 | Sony Playstation 3 40GB System Console
My ps3 tells me the hard disk is corrupted
Sounds like you might need a new hard drive. You could try to disconnect it and reconnecting it, but usually it does not fix the problem. just remember you need a 2.5 sata hard drive (might be a good thing, if you ever wanted more hard drive space).
Dec 13, 2008 | Sony Playstation 3 (PS3) Console
Ps3 40 GB upgraded to 160 GB but it won't work
yes very common problem with this must upgrade to a 60gbSATA
Sep 17, 2008 | Sony PlayStation 3 40GB System
Platstation 3 hard disk error
It should have formatted with your ps3, even if you formatted the HDD on your laptop it would have asked you the same thing, since the PS3 asks you that so it can install some folders for the pictures, games music etc.
your problem could be caused by faulty HDD installation, a faulty HDD or a broken ps3 that cant read HDDs anymore.
I would make sure the HDD is installed correctly, if that doesnt work I suggest buying a new HDD. If both of those dont work then you have a Ps3 that has a trouble reading HDDs
Aug 03, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
267 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
