Question about Bosch Nexxt WTMC 3300 Electric Dryer
Bosch Nexxt Electric dryer tumbling but not heating up at all, I here rumors of a reset switch. Where is it located?
  • Anonymous Mar 30, 2014
    electric dryer 8 years old
Unplug the dryer first. Then remove the back cover on the dryer. You will find the red reset button underneath the dryer drum. If the button has been tripped, you will feel and hear it click when you press it in. I would suggest that you vacuum out any dust or lint that has collected inside the unit before replacing the cover.
Posted on Apr 26, 2009
Bosch nexxt 500 elec dryer has no heat to it
There is a switch located on the duct from the heating element. Which you are not able to reset, you have to replace it if it's defective. Do a continuity test on it and if there is no continuity then the switch has to be replaced.
Jan 04, 2012 | Bosch Nexxt 500 Dryer
Bosch nexxt 500 series dryer runs but stopped heating blows cold air and tumbles but just have no heat.
The heater element has failed,if electric dryer,. The element should be accessed at the rear panel.
If Gas heater...same but gas burner has failed to ignite.
Hope thes helps you
This help is free...Please find time to rate me.
Jun 28, 2011 | Dryers
The dryer is tumbling but not heating up. It worked fine before moving to the new house.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 07, 2010 | Bosch Nexxt WTMC 3300 Electric Dryer
My dryer does not heat up I pushed both reset buttons...
Welcome to FixYa.
Just to clarify your statement "dryer does not heat up I pushed both reset buttons..." are you referring to the hi limit cut out ( on the heater box ) and the emergency shut off switches ( next to the belt pulley ) you've reset already ?
examples
I'll assume you are unless you say otherwise since you've also stated the dryer will indeed tumble just not heat, correct ?
Have you checked the heating element for continuity following the reset attempts ?
If not, that is where I'd direct your attention going forward. With the aid of an ohm meter or a multi-meter, place a lead on each element terminal and you should have continuity.
If you're uncertain about how to go about this, send me an email at macmarkus@live.ca and I can attach a short .wmv file approximately 3.5MB ( there is no audio and it is directly from Bosch ) on "how to".
I'll watch for your reply. Good luck.
Regards,
Macmarkus :)
Oct 07, 2010 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Bosch nexxt 500 plus dryer does not heat up. I
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Apr 27, 2010 | Bosch Nexxt 500 Plus Dryer
My Bosch dryer spins but does not heat up. It is
Most likely it is the thermal switch that is located near the heating elements. This switch is the device that regulates the temperature. When it goes bad, it remains open usually. Short of a burned heating element wire, this is probably it. The only other thing it could be is the switch on the end of the motor. This switch turns on the heating element only if the motor runs. Check that too. Good luck.
Nov 28, 2009 | Bosch Nexxt WTMC 3300 Electric Dryer
Heats and turns but shuts off after about 15 min
This may be an indication of an internal duct restriction due to lint. If it is clean inside there may be a problem with the main electronic control board but the only way to know for sure is to do some electrical testing with a volt/ohm meter and the wiring diagram located within the appliance.
Go here for LG Dryer Parts: http://www.repairclinic.com/LG-Dryer-Parts
www.RepairClinic.com
Feb 03, 2009 | Bosch Nexxt WTMC 3300 Electric Dryer
Dryer not heating
Common faults -
1 The heating elements can fail (meaning open circuit)
2 There are cut-outs (T.O.C's) that might need resetting
3 The thermostats (stats) can trip out or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehave programs that can fail and circuitry although most should produce an errorcode showing you were the fault is.
5 Faultyconnections and burned wires may also be the fault.
Free tumble dryer repair videos
We have a Free full video library on appliance repair video’s
May 02, 2008 | Bosch Nexxt WTMC 3300 Electric Dryer
Dryer
I have a Bosch Nexxt WTMC 3300 electric dryer. The dryer doesn't heat up. This is the second time this has happened over a one year period. The first time it happened, the technician reset the thermal cutoff, but said he saw no reason why it should have tripped. Can you tell me how to reset the thermal cutoff or offer another solution?
Apr 25, 2008 | Bosch Nexxt WTMC 3300 Electric Dryer
I just had the same problem, motor runs but no heat. I had a fun time figuring out how take the front panel off, hint the rubber seal comes off easily. It looks like mine tripped the resettable over heat sensor. So far so good.
Jul 30, 2007 | Bosch Nexxt WTMC 3300 Electric Dryer
Bosch Nexxt WTMC 3300 Electric Dryer Logo
975 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
