Question about Vizio L32 32 in. LCD HDTV
The vizio 42 inch set..problem is that the set turns off after 1/2 hr to 3 hrs after turning on and can be turned on again by hitting the power button...what caused it to shut off
  • 718 Answers
If the sleep timer is not set, it sounds like the power supply board. As the unit heats up a component is failing or a crack circuit trace is opening up. Someone knowledgeable about electronics can isolate it by causing the problem and using a circuit cooler spray on the board.
Posted on Mar 05, 2009
When I turn on my 42" vizio all I get is the vizio screen no sound and the remote will not work to turn it off.after being unplugged for awhile (days) i tried it again and it worked fine until i shut
You will need to get a diagnosis done on the set. It could be a power supply issue or a main board issue. Your problem is between one of those two boards.
Apr 04, 2013 | Vizio VW42LF 42 in. LCD HDTV
Vizio 42 hdtv mo picture,no sound
Hi
Thanks for using FixYa. Please check the following—
1. Is Power board output +5V?
2. Is J1 (#19 in the right diagram)connector good?
3. Is DC-DC OK, check the voltage at J1 using a multimeter.
4. Is U4 (3.3V) working ok, U4 is an IC, you’ll need an IC tester or an oscilloscope to check this IC.
After checking this if it still doesn’t work then check P3 D-sub Input (on the D-board). See this schematic for details--
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Oct 17, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Vizio 42" lcd powers up with sound only - no picture
It sounds to me that the unit has a faulty inverter board which could be due to an overheated/bulged capacitor. I would send in a claim on it to the factory if it is still under warranty.
May 28, 2009 | Vizio VU42L 42 in. LCD TV
I turn on the tv and it has a blue screen and no
Just try to reset so picture will back to normal again, some LCD TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the LCD TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the LCD TV power button for five seconds.
4. Plug the LCD TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the LCD TV is responding again.
6. Turn off the LCD TV and reconnect the devices.
7. Turn on the LCD TV.
Hope it may help you;
Regards;
VOTIT
Apr 23, 2009 | Vizio Gallevia GV42LF 42 in. LCD...
Vizio vx42l hdtv back light
If backlight went out then sound should still work. Are there any indicator lights to show power is coming on anymore? Try unplugging for 30 seconds, hit power button a few times, then plug back in and try to turn on. This drains any capacitors of power to attempt to reset (basically clearing the TV's throat).
Can also try something on a different input. If current input is composite, S-video, or component, try using DVI or HDMI connection as this uses a different board in the TV. If that fixes it, then at least you can try to replace one board instead of entire tv. :)
Apr 06, 2009 | Vizio VX42L 42 in. LCD TV
Vizio 42 inch Lcd tv
You need an Vizio authorized TV repair guy to check out the problem for you.
Solutiondoct
Oct 12, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Hitachi 65F59A turns itself off
The power supply may be failing.
Sep 02, 2017 | Hitachi 65F59A Television
Plasma Vizio 42 inch
The main board of your TV is bad. I have seen a lot of TVs have the same problem.
May 31, 2008 | Vizio 42 in. LCD TV
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
Vizio L32 32 in. LCD HDTV Logo
394 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
