Question about Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense...
Smell coming from under my all refrigerator frigidaire
Terrible smell and we can't remove the drain pan
farfield
  • 462 Answers
SOURCE: Water on floor at front right of refrigerator
Yep got a wood floor 1/2 way up do to water leak.
First lets decide where your leak actually is.
Fact: If the drain pan is dry does not mean that the water being disposed of during defrost is not getting to the pan, It could also mean that the water that is reaching the pan is being evaporated like it is suppose to be. So we have to find your source of the water first then decide on what is causing it.
Areas to consider:
1"Inside" coming out the front from under the door? This is most likely a stopped up drain pan. A cold area that is not suppose to be cold like when you have a freezer coil that is suppose to be defrosting and is not... See below for a more complete ideas list of things to check under Possibility.
2"Outside not underneath" The corner of the door also could indicate (if you have water in the door) a worn out water line or a kink in it that has finally started to leak. Turn off the water to the refrigerator for 2 or 3 days and see if the problem disappears. If so you know whats going on and can approach it from the door area.
3"Outside underneath" The corner could also be where the water is running to from someplace under the fridge. The drain pan drain line is the most common. Inspect it and repair as needed, maybe its just not over the pan. A new house keeper not acquainted with this box may have knocked it out during vacuuming just put it back over the pan. IF The sealed system has had refrigerant added it could be from an over charge and frost on the suction line defrosting during a shutdown.
Possibility's:
1 There is a drain that carries away the water under the cooling coils. These coils are in the freezer section.
2 The damper going to the crisper( s) is open too far allowing cold air to cause condensate on the fridge wall or bottom.
3 The freezer section is not defrosting and there is a spot where the ice buildup is allowing conductive cooling into the refrigerator section and therefore is allowing condensation on the refrigerator wall or ceiling.
4 The refg section has a heater (possibly not positive) in the area of the door frame, or it may have a "power saver" switch. This switch and the heater (if it has a heater it may not have a switch) are designed to stop condensation on the refridg while running. I fit is placed in the "power save" mode it turns off the heater. But, if you live in extream humidity (Great lakes east side or Gulf coats Houstion...) the humid air will condensate water out and it will collect and settle on the floor.
5 Door gaskets are not sealing especially on the bottom of the door. This allows warmer air into the fridge section and it is condensation on floor under the crisper.
If you check all of these items and still cant find it please post back and tell me what you did find. So I can help you more. Please rate me as much as possible as Im trying to keep my average up and do the things that will actually educate and help people.
THANK you for using fixya and good luck..
Posted on Mar 22, 2009
  • 958 Answers
SOURCE: drain pan
yup..that's how it is. no solution but to pick up the dead mouse and clean the drain pan as is, where is.
you might send someone with a small hand to reach the pan completely. rinse it with soap and water to eliminate the odor. use gloves to pick up and clean the pan.
tnx 4 using fixya,
drcool
Posted on Oct 24, 2008
  • 531 Answers
SOURCE: Can't find drip pan and have a really bad smell
drip pan is on top of compressor
Posted on Apr 07, 2009
farfield
  • 462 Answers
SOURCE: How do I remove drain pan under regrigirator
The drain pan on most models is slipped in when assembled and may not be removable from your fridge unless the compressor-condenser assy is taken down too.
First find the pan by removing the back cover. Next use a good flash\light and look for a plastic pan underneath. Then look along the sides of the pan for the words lift here or some other type of direction on the pan. If none are given try lifting the pan and see if it will lift and slide towards you or not. If not then its probably made to just sit in place.
Hope this helps please rate me as high as you can and thanks for using fixya.
Posted on May 05, 2009
  • 2667 Answers
SOURCE: Water pooling under refrigerator have cleaned
take bottom kick plate off,look underneath on left side and have someone else draw some water and see if line is cracked
Posted on Nov 08, 2009
Model 610 - how do I locate the drip tray and how do I remove it? The power was lost after TC Marcia and products dripped in the fridge and freezer causing a terrible smell.
Hello;
My name is Peter. I am a retired field service refrigeration technician.
Plastic holds odors. The smell may not becoming from your drain pan, but more likely the liner.
What to do:
1.) Remove the shelves, ice bucket and crisper drawers and scrub them with a baking soda base cleaner.
2.) Scrub the liner walls.
3 .) There are deodorizers especially made for refrigerators; One for the fresh food section and one especially for the freezer section. You can get these for any appliance store.
4.) Ok, lets check the drain pan.
a.) Unplug your unit or turn the main breaker off.
b.) Raise the two leveling screws in the front to allow you tp pull your unit out.
c.) Having enough room to get behind your unit, unscrew the bottom cover.
d.) Observe. You either have the terrible drain pan design, where the drain pan is fixed on the top of the compressor with hi-temp adhesive. Do not attempt to remove. Over time the adhesive dries out and the drain pan falls off.
The other type of drain pan is almost just as bad. You have to unbolt the compressor and other things to access. Do not attempt this.
What field technicians do when there is a drain pan leak, is repair the leak with duct tape and a high temperature silicone adhesive. In this case if there is an odor, sprinkle 1/2 cup of baking soda around the drain pan.
Feb 26, 2015 | Refrigerators
My Frigidaire refrigerator has a drain pan that is un remove able and has a bad smell how can I clean.
I appreciate your inquiry, friend!
If you would like to clean any dirt or debris from the drain pain you can use a vacuum attachment to get inside and clean any residue within the drain pan. You can also use warm water and bleach to help disinfect the drain pan prior to vacuuming it out. If that does not help you may want to consult with a professional technician for additional cleaning to be completed within your Frigidaire refrigerator. Best of luck! -Matt
Oct 19, 2014 | Frigidaire Refrigerators
How do I fix the smell coming out of engine area. everytime it turns on it smells.
Hello friend, thank you for your inquiry!
I understand that you are receiving a smell from the engine area of your Frigidaire refrigerator. I would recommend cleaning your drain pan area, you can do that by using water and bleach in a spray bottle then spraying it into the drain pan. Also, get a vacuum attachment to help suck out any debris located in the drain pan. You can also seek consultation with a professional technician for additional assistance if needed. I hope this helps. -Matt
Sour smell coming from back of fridge on outside
Check the drain pan under unit. Maybe something has got in there. May need to remove the back our go through the front. Can pour a very small amount of bleach our Lysol to kill in the drain pan to kill mold. Hope that helps.
Aug 18, 2012 | Hoover Refrigerators
My refrigerator is one year old. There is a bad
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} You may have had something drip and somehow get under the fridge. I know blood dripping from meat will smell. It could have dripped down through the defrost drain tube to the pan underneath. You can access the pan from the rear by removing the cardboard cover. If the smell seems to be coming from the pan, it's difficult to remove so I would just pour some bleach in it to kill any smell and you may can wipe it out from there. The drain tube may also have the smell in it so you can pour some bleach into it from the inside of the freezer at the bottom of the rear panel. You can move the fridge to see if anything is pooled on the floor that might smell.
Jan 06, 2010 | Whirlpool Refrigerators
Smell coming from Frigidaire Refrigerator outside the front panel. Can't find a drip pan so what could it be?
You can Remove rear access panel, then you will find evaportor pan built on top of compressor. Make sure the drain is not plugged and that there is some water in evap tray.
Nov 15, 2009 | Refrigerators
Water in refridgerator interior
You have a plugged drain in the freezer. Unplug and remove back panel in freezer. Under the evaporator there will be ice, thaw with hairdryer or steamer. There is a hole under the ice, that is the drain. Flush with hot water until it drains into outer pan. It may take awhile to get drain cleared.
Mar 20, 2009 | Frigidaire FRT21G3CW Top Freezer...
Drain pan
If u have 2 people u can lean the fridge back and the drain pan unscrews from the fridge from the bottom even though it says "non-removable
Oct 24, 2008 | Frigidaire FRT8B5EQ 30" 18.2 Cu. Ft. Top...
Model gss22jepa
i answered one problem like yours before, she told me, there's no way to remove the tray from the front nor from the rear.
she just pick up all the water using towels and tissues. she's just lucky to have small hands. she was very frustrated with the design where you can not remove the drain pan to clean it.
tnx 4 using fixya,
drcool
Oct 20, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
How do I clean my drain pan on my side by side refrigerator it smells
Hi. Thanks For The Question. Pull Fridge Away From THe Wall. Remove Back Panel Clean All Coils. Remove Drip Pan. Clean. Thanks The Appliance Doc
Aug 07, 2008 | Maytag MSD2656G Side by Side Refrigerator
Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense... Logo
133 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
