Question about Sony Car Audio & Video
AMP shuts off
My Sony Amp shuts off when volume or bass is turned up slightly. I have a XM-ZR 604. I have 2 12in Kicker subs that are rated at 1200 watts and the amp is 600.
    Novelist:
  • 110 Answers
Your problem could be in the fact that you are trying to overdrive the amp. sony will not carry a 1 ohm stable load and if your speaker are 4 ohm speakers wired in series then you cant drive the bass your looking for. try using soundstream tarantula amp or new hifonics block mono class d amp with about 1000 watts rms. what kicker subs do you have? that will also make the difference in amp choice. im running tarantula on 4 polk momo 4 ohm 12's and has broke my back glass in my jeep twice one time was for a show. oh well let me know. happy boom boom. i'll be glad to help
Posted on Feb 28, 2009
Not enough bass. should i run a capacitor.adjust my amp and what to set it at for max performance
Turn up the gain on your amp until you get the amount of bass you want or until the sub starts to distort. If you do this and you are still unhappy with the bass, you will need a bigger amp or better subs.
Dec 04, 2013 | Sony Xplod XM-1252GTR 2-Channel Car...
My sony xplod 1200 whatt amps red light keeps coming on all the wires are good when it gos to hit it gos red
check your ohm load on the sub and see if your amp can do the same, That is why every time it shuts off into protection mode. Check your gain level on the amp to this is not a volume knob for your amp, It is to get both the amp and cd player on the same page. Hope this was helpfull
May 19, 2010 | Sony Xplod XM-554ZR Car Audio Amplifier
Amp goes into protection
make sure the impedance is right for the amp you're using. If you're using a 4ohm amp and a 2ohm sud that may be the problem. It may be overdriving the amplifer which is bad and can cause damage to the amp. Hope this helps.
Jun 01, 2009 | Kicker 12" Solo X Subwoofer S12X - 5000...
Sony xm-D9001GTR mono and kicker 4ohm dual voice coil
its a good amp but dont power ur amp at full put it at about half power
May 27, 2009 | Sony XMD9001GTR Car Audio Amplifier
Got a 12"kicker L74ohm sub and sony xm-D9001GTR mono amp
Hello juan_penaloz,
The Kicker L7 has an RMS power range of from 50-750 watts and a maximum power handling capability of 1,500 watts so your Sony amp will power it OK. A more powerful monoblock like the Alpine MRP-M1000 or the Kicker 08ZX750.1 would provide even more power and could operate safely at 2ohms.
You have the voice coils wired properly for the Sony amp. It's OK to have the sub impedance higher, but you definitely do not want it lower than the 4ohms the amp is rated at in bridged mode.
Hope this helps.
May 26, 2009 | Sony XM-1252GTR Car Audio Amplifier
I have a Sony Xplod XM-1652Z 1000 W. I am using it to power my 2 Infinity 10" subs with 1052 watts on each Max. My problem is that when i turn on the volume too high the subs would stop working. My friend...
Sony audio products are not worth the buck, you will be facing worst problems in the future, my advice is just to change the amps. It is causing the problem, it cant handle frequencies when volume is turned up. and it may say 1000 watts but actually this is the peak rating your amp can handle thus meaning that it couldnt handle constant high volume usage, try crunch, kicker or hifonics amp, and look at the RMS rating on the amps when shoping.
Mar 31, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Sub volume stays the same
in the back of head unit u might have 2 pre outs try swicthing them if u dont then on the amp u should have nobs turn them all the way up
Jun 16, 2008 | Kicker CVR12 Car Subwoofer
Sony Xplod XM-1652Z Car Audio Amplifier cuts out when turned up loud
The best thing to do is to get a amp that is more watts than your subs, not the other way around, speakers are known to handel a lil more power but amps cant produce more power than they are capable of... your ground wire should be thick also, say 6 to 8 mm or so, and its best to put in a cap and an equalizer.
Cheers
Dec 19, 2007 | Sony Xplod XM-1652Z Car Audio Amplifier
Protection light
You cannot parallel two subs AND run them on the Bridge. You must have at LEAST a 4 ohm load on the bridge, and 2 4 ohm subs in parallel equals TWO OHMS. BAD!!! Move each sub to it's own channel or your amp will soon fry.
Sep 10, 2007 | Sony XM-2002GTR Car Audio Amplifier
Protection mode override
If you have your subs wired to the amp in a bridged configuration, try wiring one to each stereo channel instead. Also, make sure your ground wire is secure and connected to a clean, solid metal part of the vehicle body with the paint scraped off. If this doesn't work, disconnect both subs and try connecting only one at a time; one of the subs may have a problem that is shutting down the amplifier.
Mar 11, 2007 | Sony XM-2002GTR Car Audio Amplifier
Car Audio & Video Logo
198 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
