Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
I have a 600gd external Hard drive. I says its connected to the computer and its working, the light is on and everything and i can also hear it. But my computer isnt able to read it
  • Anonymous Feb 28, 2009
    I have the same problem can anyone help me.
    My WD 120GB hard disk is detected by all laptop but its not shown in mycomputer
  • Anonymous Mar 05, 2009
    WD 300 GB, no power plug, is recognized by all computers but does not open its folders. is there a way i can retrieve the data? Can anyone help?
  • 408 Answers
Have you formatted the drive yet?  If this is the first time you are using it, you have to format it.  If not, shut down the computer, unplug the USB and power cable from the hard drive...wait 2 minutes.  Plug the usb into the hard drive and the computer...then plug in the power cord to the hard drive.  Wait 30-45 seconds and then start your computer.  Hopefully that should fix your issues.
Posted on Mar 03, 2009
I dropped my drive and now the computer won't recognize it. The blue light is on with the red light. Help!
Sorry to hear that your drive is having trouble. When you start the drive, do you hear it turning?
Is this a external that you can remove the hard drive? You may try to power down the external, power it back up and shut down your computer. The conect the external and turn the computer on.
Let me know if you can hear the driver turning and it you can connect after going thru the process above.
Brian
Feb 05, 2011 | SimpleTech Signature Mini 320GB External...
We understand that your problem is: We understand that your problem is: Hello, I have Lacie porsche external hard drive. I also have a seagate firewire external drive which us working fine. Unfortunately...
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
Dec 18, 2010 | LaCie F.A. Porsche (301177) Hard Drive
SimpleTech 1TB External Hard Drive Silver My hard drive suddenly quit working. I plugged the hard drive in and powered on and the white power indicator light came on then just started flashing. The...
First make sure usb cable connected to harddrive is working fine.
try it in different usb ports.
Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers.
then check.
Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key.
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318}
And remove upper filter and lower filter.Then restart computer then check.
Try your harddrive in different computer if it is not recognized on another computer too then your harddrive has internal issue.
Let me know if you need further assistance.
Thanks for using FixYa
Jul 25, 2010 | SimpleTech 1TB External USB 2.0 Hard Drive...
I have a Maxtor One Touch 4 Mini 120GB External USB 2.0 Hard Drive, I've previously used it multiple times in the past, importing AND exporting data. For some reason though after using it on one computer...
try testing it in another computer. if you have the same problem. then there might be an issue with the drive.
to recover your data. unplug external drive from the computer and open the external hard drive case. remove the hard drive inside. with you computer off and disconnected from the wall open the case to your computer. look and see how the hard drive inside is connected in your computer and add the external the same way. you might need a cable to connect it. you can simply disconnect the cdrom and plug the hard drive instead. make sure the external hard drive is not touching any electronics inside the pc. now you can turn on the computer. give the computer a minute to detect the new drive and assign a drive letter. navigate to my computer and select the newly added hard drive. copy and paste all the data you want to save. after everything has been backed up format the external drive to clear any bugs that may be causing it to be recognised in its case.
when finished remove the hard drive, plug in the cdrom, close the case, plug back into the wall, and return external drive to its case.
Feb 28, 2017 | Maxtor OneTouch 4 Mini 120GB External USB...
Philips external hard drive not recognized by any computer
one of two problems , the interface or the unit , first start by
removing the outer cover to make sure the unit is connected
properly inside , then when connecting make sure you hear
the plug in sound of the USB low to high , a high to low sound
means the there is a problem with either the USB or the cord
second make sure you hear a noise or see a operation light
if so reboot the computer while the unit is plugged in , look
for icon in my computer , make sure you hear a spin up sound
if the unit spins up and down the units motor is malfunctioning
if there is a clicking sound the units heads need replacing if
everything sounds and looks good try taking the HDD out of
its closure set the jumpers to slave and hook it up inside of
a PC to troubleshoot if there is a problem with the closure
Jan 28, 2010 | Philips Computers & Internet
I have a WD1600 Extrernal Harddrive and yesterday my kids unplugged the outlet so everything powered down instantly. Once I plugged everything back p and restarted my computer the harddrive just spins up...
The hard drive could have been irreparably damaged. The chattering sound is the heads trying to find the beginning of the data sectors and can't. The drive will shut itself off automatically after a predetermined time period.
Jan 07, 2010 | Western Digital External USB 2.0 80 GB...
Dell latitude D610
This fault usually means the hard disk has failed or the disk controller, in most cases it is the hard disk that has failed.
Check the BIOS settings and see if the hard disk is detected, if not it is probably a faulty hard disk.
When you boot up the computer does the hard disk LED light flash and can you hear the hard disk spin up. If the hard disk is making a clicking noise then it is definitely faulty.
To test the hard disk another way, remove the hard disk and connect it to an USB hard disk adapter and connect it to a working computer's USB port. If this computer cannot detect this as an external hard drive and you can't open the folders and files, this confirms it as faulty.
To get the computer operational again, you need a new hard drive, Install Windows on the new hard drive with the computer's device drivers and your programs.
Sep 05, 2009 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
External hard drive wont stay connected to computer
This depends where the failure is.
If your controller board for the external casing or your power supply have failed the drive can be removed from the casing and placed in a new one($30-$40), then it should work fine. If the circuit board on the hard drive or an internal circuit for the drive has failed then you may require the help of a pro.
Reply back if you need a recommendation for a pro, include your location.
Chris
May 19, 2009 | Seagate (ST3160203U2-RK) (ST3160203U2RK)...
My computer stopped reading my external hard drive
Try the drive in a different USB port. If it still fails try another computer. If it still fails then it's possible the drive is bad. If the warranty has expired you may be able to find a tech savvy friend to remove the actual drive from the case and hook it up to another computer directly. If it recognizes fine then the case is bad. If it does not recognize the drive then the drive is dead.
You won't be able to retrieve the files on the drive unfortunately unless you use an extremely expensive service. These tend to run in the hundreds of dollars.
Nov 22, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
The hard drive won't boot up
the hard drive is dead ( dreaded click of ***** syndrome )
you can have that verified at a computer repair shop and if that is the case use a solid state hard drive as a replacement and not the spinning disc type as for the data you have stored , there are places than can recover it from the dead hard drive but unless you have it all backed up on an external hard drive or storage device then it is lost
Jun 04, 2017 | Adaptec 1 Bay ACS-100 (2177400) USB 2.0...
Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
83 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
